Glider Electronics Experiment #1 - electrical crosstalk demonstrated
Old May 1st 20, 07:17 PM posted to rec.aviation.soaring
Richard Lancaster[_2_]
Default Glider Electronics Experiment #1 - electrical crosstalk demonstrated
Hi all,
I got a bit bored and started filming some glider electronics experiments. I am attempting to pitch them to be interesting and understandable even if you don't know much about electronics.
First up:
Available he
https://RJPLancaster.net/
Best regards,
Richard
Old May 1st 20, 07:57 PM posted to rec.aviation.soaring
Very nice and well presented topic. Thanks.
On Friday, May 1, 2020 at 12:17:03 PM UTC-5, Richard Lancaster wrote:
Hi all,
First up:
Available he
Best regards,
Richard
Old May 2nd 20, 02:51 AM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Dang!
Learned something there, let me tell you.
I'm going to check my wiring after that demo.
I keep picking up Linda Rohnstat on my radio, is this why?
Nick
T
Old May 2nd 20, 06:10 AM posted to rec.aviation.soaring
2G
On Friday, May 1, 2020 at 10:17:03 AM UTC-7, Richard Lancaster wrote:
Hi all,
First up:
Available he
Best regards,
Richard
Well done, Richard. Electrical interference is a tough subject even for electrical engineers, such as myself. You presentation is an intuitive approach, which is much more understandable than, say, equivalent circuits. Keep it up.
Tom
Old May 2nd 20, 11:22 AM posted to rec.aviation.soaring
Thanks all for the positive comments.
Got asked on the UK glider forum for a description of what the video was about. So in case anyone is debating whether to sink their time into it, here's a quick abstract:
"Electrical crosstalk is a type of interference where the signals carried in
one set of wires "talk across" into another set of wires. This video sets
up a simple glider electrical harness, talks about how crosstalk might
occur in it, demonstrates it occurring and illustrates the magnitude of the
consequences to the pilot."
Best regards,
Richard
Old May 2nd 20, 03:41 PM posted to rec.aviation.soaring
Richard Livingston
Nice demo of cross talk. Last year I fixed a problem in our glider where the microphone wires were not completely shielded, as in your demo, and were picking up signal from the radio speaker wires, also not completely shielded. The result was intermittently the radio would squeal during transmit due to feedback from the speaker back into the microphone. It was intermittent due to the wires shifting slightly every time the canopy opened/closed. Shielding both the speaker and microphone wires fixed the problem.
Rich L.
Old May 2nd 20, 06:07 PM posted to rec.aviation.soaring
Setting up these experiments I was intriged by how much small relative movements in the cables when they are bundled together, even at a single point in the cable run, can change the crosstalk. Will try to show that and the effect of distance in the next video if I can pull off a clean demo.
Richard
Old May 2nd 20, 11:32 PM posted to rec.aviation.soaring
Rich L.
Such feedback could only occur if the radio had the (mis)feature of echoing the signal from the mic to the speaker. Kind of lets you know you've got the PTT pressed and it's all working, but not really necessary. With that happening, you may also get acoustic feedback, from the speaker back into the mic, even without crosstalk in the wiring. Maybe that feature can be turned off somewhere in the radio's settings?
Old May 3rd 20, 12:25 PM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
where=
we=
shie=
transmit=
intermi=
opened/close=
=20
Rich L.
echoing=
got
that
t=
tu=
Many radios have this foldback feature for use with headsets and intercoms.
But yes, it could cause acoustic feedback. But this does not satisfactorily
account for the above fix.
What would seem more likely is that the poor sheilding has allowed
cross-talk from the antenna cable to the speaker cables which has allowed
the RF to feed back into the radio box where it caused meyhem. The speaker
does not need to be active for this to happen.
The section on supressing cross-talk is going to be interesting because
there are so many possible causes.
Tim.
Old May 3rd 20, 02:13 PM posted to rec.aviation.soaring
Experiment #2 is just going to look at the effect of cable type on the type of noise seen in experiment #1.
Experiment #3 on-wards, if I manage to keep making them, will look at other types of noise.
Best regards,
Richard
Electrical continuity of control linkages and electrical instruments son_of_flubber Soaring 7 June 26th 15 05:09 PM
an interesting in flight experiment a[_3_] Piloting 58 October 24th 09 03:20 PM
Glider electronics for sale NXS Soaring 4 July 19th 05 01:40 PM
A small experiment Mike Borgelt Soaring 16 May 6th 05 07:41 AM
