Landout at Class C or D tower-controlled airport?
Old June 3rd 20, 07:39 PM posted to rec.aviation.soaring
Roy B.
Default Landout at Class C or D tower-controlled airport?
David,
I agree with you that "intuitively, landing at an airport is safer than a land out" but the reason I challenged your statement that ""did you know that nearly 50% of glider landing fatalities happen during off-airport landings?" is the risk that the new pilots in this forum may think that stretching a marginal glide to an airport is "safer" than a properly executed off field landing. And it's not safer at all.
What the data (and particularly the 2018 SSF data cited in your last post)shows is that most of the off field landing accidents were landings that were rushed: rushed because the pilot was thermalling low and made a last second effort to land, or rushed because at the last minute the pilot realized he was not going to make the home airport, rushed because the pilot changed field selection at the last minute, or rushed because the pilot got low and had no "plan B" . Two of the landings were on highways with resulting damage from road signs and barriers. 3 were tree strikes during botched rushed landings.
That's not an indictment of off field landings per se (which when properly planned and executed are quite safe). Rather its an indictment of poor and late aeronautical decision making.
Let's not give the newbies the impression that they should be scared of a well planned and carefully executed off field landing - in favor of an even scarier marginal glide back to the airport.
ROY
  #42
Old June 3rd 20, 09:51 PM posted to rec.aviation.soaring
On Wednesday, June 3, 2020 at 10:36:19 AM UTC-7, wrote:
On Wednesday, June 3, 2020 at 5:10:30 AM UTC-7, Roy B. wrote:
David:
What is the source or reference for this statement?
"did you know that nearly 50% of glider landing fatalities happen during off-airport landings"
I've studied glider accidents for years and have not seen that - unless you are calling low level thermalling stall/spin ins, ridge terrain strikes, and similar accidents as "off airport landings"
Admittedly, a properly executed pattern,approach and landing into a soft field can cause glider damage - but a fatality? Those (in the hundreds of cases I have studied) are quite rare. What I have seen is that the real killer in our sport is low level thermalling - especially in wind/gusty conditions. But that's not a "landing accident".
ROY
My observation came from Soaring Safety Foundation Safety Reports. In most years, we have slightly more on-airport landing accidents than off-airport. In more recent times, there have been a few years where off-airport landing accidents actually exceeded on-airport accidents. For example in 2017/2018, the SSF reported that "more landing accidents occurred during off airport landings (62%) than landings at the home field (38%). https://www.soaringsafety.org/accide...ual_report.pdf
SSF statistics aside, I think it's pretty intuitive that landing at an airport is safer. Therefore, I'd always choose a suitable runway (wide enough!) over an off-airport landing.
I think that many glider pilots are unfamiliar and uncomfortable with towered airports. Please know that public airports are there for all pilots, even glider pilots, to use. You won't discover a ditch or fence on short final... you won't damage any crops... you won't have any trouble getting the glider out.
David, thanks, that's an interesting statistic. Is it for fatalities, or any accident? I suspect that a higher accident rate for off-field landing is not so much due to the unknown surface, than to the extra demands and stress on the pilot. In that case, a landing at a strange airport may induce a similar level of stress.
  #43
Old June 3rd 20, 10:11 PM posted to rec.aviation.soaring
jfitch
David:
ROY
The problem is, an off field landing is always going to involve extra stress and many unknowns, unless it is one you have landed at before (recently) or have at least walked. I've no doubt this contributes to failure count, but it is part and parcel of the process. The surface is only one of a miriad of unknowns: is it long enough? is there turbulence or wind shear? what direction is the wind? is it downhill or uphill or side hill? are there wires? is there berm or higher than expected vegetation? All of these concerns are absent or at least mitigated at an airport.
I'd agree that landing at a known field with known surroundings and known conditions should not be much more dangerous than an airport, even if the surface itself is suspect. But that is a small part of the difference. A new to you airport can generate a bit of stress, but nothing like a field you are about to see up close for the very first time.
  #44
Old June 4th 20, 02:39 AM posted to rec.aviation.soaring
George Haeh
One of the undisclosed advantages of an off airport landing is the (usual) lack of conflicting traffic.
Another hidden advantage of an ancient IFR rating is knowing how to talk to ATC.
Most Class D towers are happy to know how to reach the blip on their radar repeater.
But ATC can get a headache when every glider within 20 miles starts reporting position when they mention an unknown glider in a certain sector. Same for the pilot of concern who is trying to get a word in edgewise.
Private airport or small field for landout? Charles Ethridge Soaring 62 May 31st 20 06:46 PM
Control Tower without class D Danny Deger Piloting 16 May 17th 07 01:16 PM
Security at a class D tower Dallas Piloting 63 April 30th 07 11:12 PM
Have you been to an airport where the people in the tower are consitently rude? LowApproach_SoCal Piloting 15 August 23rd 04 04:19 AM
Tower with only Class G Airspace Jeff Saylor Piloting 8 May 10th 04 09:53 PM
