Pipistrel Earns First Electric Aircraft Type Certificate
Old June 12th 20, 03:30 PM posted to rec.aviation.piloting
Larry Dighera
Default Pipistrel Earns First Electric Aircraft Type Certificate
https://www.avweb.com/aviation-news/...e-certificate/
Kate O'Connor June 10, 202020
Image: Pipistrel
Pipistrel’s Velis Electro became the first-ever fully electric
aircraft to receive its type certification on Wednesday. According to
the European Union Aviation Safety Agency (EASA), which granted the
certificate, the certification process for the aircraft was completed
in less than three years. The Pipistrel E-811 engine used on the
aircraft became the first EASA-certified electric aircraft engine on
May 18, 2020.
“The type certification of the Pipistrel Velis Electro is the first
step towards the commercial use of electric aircraft, which is needed
to make emission-free aviation feasible,” said Pipistrel Aircraft
founder and CEO Ivo Boscarol. “It confirms and provides optimism, also
to other electric aircraft designers, that the Type Certificate of
electric engines and aeroplanes is possible.”
Designed primarily as a trainer, the two-seat Velis Electro has a
cruise speed of 90 knots, 600-kg (1320-lb.) maximum takeoff weight,
172-kg (378-lb.) payload and endurance of up to 50 minutes plus VFR
reserve. It is a fully electric derivative of Pipistrel’s Virus SW
121. Slovenia-based Pipistrel says it has plans to deliver 31 Velis
Electros in 2020.
https://youtu.be/GC7ydEpVNfA
Video: Pipistrel
M & D jet receives EASA Type Certificate [email protected] Soaring 15 December 6th 15 01:36 PM
Pegase Type Certificate change? Mark628CA Soaring 0 May 16th 15 05:59 PM
Stalking the elusive Type Certificate Pat Russell[_2_] Soaring 7 December 31st 14 12:48 AM
L13A Type certificate holder Bruce Soaring 7 August 19th 10 07:01 PM
Parachute Required by Type Certificate [email protected] Soaring 1 April 27th 09 11:15 PM
