Another E glider concept
Old August 17th 20, 01:21 PM posted to rec.aviation.soaring
Dan Marotta
Default Another E glider concept
The chines are improve handling at Mach 3.Â* Don't you remember the SR-71?
And didn't the ending credits say that it was a Master's Thesis in
design or something similar?
On 8/17/2020 5:40 AM, Martin Gregorie wrote:
On Sun, 16 Aug 2020 20:04:19 -0700, Marc Ramsey wrote:
On Sunday, August 16, 2020 at 6:19:27 PM UTC-7, wrote:
If you mean the fins on either side of the nose clearly marked
"sensor", likely angle of attack vanes. Not very useful when the
motor is running...
Not thinking about the sensor fin.
at 0:25 in the video. The horizontal line mid screen a few inches below
the canopy. Looks like a transition between a flatish underbelly and
vertical cockpit upper side. Looks like the chines under a boat?
I see what you mean, the odd transition between the upper and lower
fuselage profile that extends to the tail. Perhaps structural, or for
style? I find it hard to believe it does much for the aerodynamics
except produce a bit of drag.
Graphical artifact?
In the top view just from the right it looks as though it sticks out as
far as the sensor does and is blurred, while from the top left it only
seems to extend a cm or so and in other views it just looks like a
blurred line along the fuselage.
Dan, 5J
Old August 17th 20, 03:23 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Ventus_a wrote on 8/16/2020 6:14 PM:
Jonathan St. Cloud;1027640 Wrote:
https://www.youtube.com/watch?v=ZIYU2zkGQFQ
Interesting concept although on first look got to wonder if he was
dreaming of an updated, stretched and powered 2 seat Salto that could
fly him to fame and fortune (just kidding about the fortune)
I hope someone will read the thesis and tell us the goal of the concept. It does
make me wonder if the current FES could be adapted to a three blade propeller,
with all blades external as they are now. Slightly higher drag when gliding, but a
50% increase in power capability by the propeller (or more ground clearance and
some power increase).
Old August 17th 20, 08:58 PM posted to rec.aviation.soaring
Per Carlin
The Main factors for power from a propeller are diameter, pitch and rpm, not the number of blades.
An increase from 2 to 3 blades gives at best about 10-15% more drag if the remaining is constant. However the efficiency of the propeller drops by 5-10% and this is a major drawback in electrical propulsion system for gliders.
Old August 17th 20, 09:39 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Per Carlin wrote on 8/17/2020 12:58 PM:
I think something is missing in your explanation: for example, 3, 4 and 5 blades
are common on airplanes, and wind turbines routinely use 3 blades. My
understanding is tip speed is the ultimate limit on the power a propeller can
absorb, so adding a 3rd should 50% more power capability.
Take a look at this bad boy - Five blades!
https://hartzellprop.com/are-more-pr...blades-better/
The Hartzell site also discusses reasons for choosing more blades
Old August 18th 20, 01:01 AM posted to rec.aviation.soaring
Cumungus
When the propeller spins backwards in the demo reel, confidence that the engineers will make an airworthy aircraft is instantly flushed down the toilet.
Old August 18th 20, 02:01 AM posted to rec.aviation.soaring
Dave Nadler
That feature is for backing into your parking space.
Old August 19th 20, 02:42 AM posted to rec.aviation.soaring
Bob Kuykendall
It looks like this is a masters thesis project for a curriculum in industrial design. Of course, much of it is not functional in the ways that are important to soaring flight. But there are some interesting design concepts here that we should not dismiss out of hand.
We have to be careful about rejecting ideas that seem impractical, especially when advances in various technologies can be combined in ways that make the orthodoxy irrelevant.
The next time you find yourself yelling "get off my lawn!," stop and reflect whether the lawn is really yours.
--Bob K.
Old August 19th 20, 06:19 AM posted to rec.aviation.soaring
2G
--Bob K.
Don't confuse this with a real, aerodynamical design concept, because it is not. You will end up chasing your tail if you do.
Old August 19th 20, 03:33 PM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
Or for landing downwind on golf courses..
Old August 19th 20, 04:31 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Chris Wedgwood wrote on 8/19/2020 7:33 AM:
That's an interesting idea, sort of the modern tail parachute like I had on my
H301. It was enormously powerful, but not controllable, just deployed or not. An
electrically powered propeller could be used to provide adjustable drag from zero
to "a lot". The design issue is keeping the propeller from folding backwards when
you want it to produce drag.
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [4/5] - "Eclipse Concept Jet 4.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [3/5] - "Eclipse Concept Jet 3.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [2/5] - "Eclipse Concept Jet 2.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (0/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
