Blow out static port
Old May 4th 05, 05:35 AM
C.
Hi group,
There are larve in my static ports again.
Disconnect the static line as close to the static port blockage as
possible and blow out (not toward the instruments).
Depending on the type of bug, you may not have any other choice but
compressed air. There's some type of larvae that find the tiny static
hole in my pitot blade to be just the right size for growing. They
build some kind of goopy cocoon in there. Every time I've blown them
out it took more that 120 lbs. of pressure to get them to budge.
Good luck,
OWE!!! John, 120 psi? That sounds like overkill. But if that's the
only way you can get them to budge... What kind are they? I have a
PA28-180 and it sounds like I'd hate to get those.
Especially since everyone seem to be forgetting one thing:
The rules say that if you open the static system AT ALL, you have to
reperform the IFR certification test. Ka-ching -- $100 or so down the
tube.
Chuck
N7398W
Old May 4th 05, 12:48 PM
Thanks Chuck,
Knowing myself, I'm completely capable to forget something like that,
whatever I try.
On the other hand, from the little experience I have I know a plane
flies perfectly well with blocked static ports :-(
So, I'm not too worried about that, since I only fly day-VFR.
But I'm going to try your suggestion anyway.
-Kees
Old May 4th 05, 05:03 PM
Robert M. Gary
I just recently saw an episode of "Air Emergency" that talked about an
Air Peru flight (I may have the details wrong). Basically a 757 take
off at night over the dark ocean and no static system. The pilots never
figured out the problem. They knew their instruments were wrong but
they assumed ATCs altitude readout was correct (which it wasn't the
transponder is also served by the static system). In short, the cause
was a $1/hr aircraft washer who put duct tape over the static ports
before washing the plane. Boeing ended up sending a lot of money to
family members. The interesting thing is that the 757 maint manual says
to only use special Boeing tape (bright orange) when coving up static
ports.
-Robert
Old May 4th 05, 07:46 PM
Dave Butler
ports.
Yeah, I've seen that episode. It's always troubled me that the pilots never
figured out the static ports were blocked, and didn't know the transponder
altitude was based on the static pressure. I've wondered whether that part was
true, or whether the truth was altered for dramatic effect. It's just
inconceivable to me that they didn't know these things. 'course, I wasn't there.
Dave
Old May 4th 05, 07:56 PM
Mark Hansen
ports.
Dave
If this is the same episode I'm thinking of, the co-pilot did figure it
out, and told the pilot that the corrections were not going to work.
The Pilot basically told the co-pilot to keep his place.
If I remember correctly, this brought up new rules regarding the ability
of the co-pilot to take control from the pilot in such cases.
Mark Hansen, PP-ASEL, Instrument Student
Sacramento, CA
Old May 4th 05, 09:37 PM
Don Hammer
ports.
-Robert
Yes and nobody knows that McDonalds sells hot coffee and you shouldn't pour
it on your crotch.
With the ability of skumbag attourneys to convince a hand-picked dufus jury
that the evil big company needs to pay the dead and injured, no matter who
is wrong, things like that will continue and all us consumers and
stockholders pay. Besides, it's a bunch easier to file suit against a US
company than a foreign airline.
Case in point - In the firestone tire suit for over $1B, the parties to the
class got a coupon for $40 or so off their next set of tires. The lawyers
got the rest.
How many of you non-attourney smokers benefited from the tobacco suit? I
know one lawyer that purchased a $30M Gulfstream with his part of the
settlement. You think the companies paid for this? Nope - us consumers.
Even if you don't smoke your insurance bill went up and mutual fund went
down.
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old May 4th 05, 09:38 PM
Robert M. Gary
Mark, where do you fly out of. I'm in Sacramento too.
-Robert
  #29
Old May 4th 05, 10:20 PM
Yep, when 60, 80 and 100 lbs. didn't work, I just kept bumping it up.
BTW - when the clog finally lets loose, it's like some sort of
explosion. I've never been able to tell what kind of bugs they were,
since the only thing that comes out is a big blog of orange goo. I
just know that whatever they are, they do their nesting here in central
AZ in June and July.
tube.
Fortunately, that's not a problem for my VFR bird. If I had to
re-certify every time it happened, that would just be adding insult to
injury :-) Usually, the tennis ball I keep on the pitot blade does a
good job of keeping them out, but every time I've forgotten to put it
on during the nesting season, I've been hit.
  #30
Old May 4th 05, 10:34 PM
Mark Hansen
-Robert
I'm currently flying out of Sacramento Executive (KSAC). I'm in a
Part 141 IFR training program with Sky Walk, Inc., a local FBO there.
Sacramento, CA
Is my static port leaking? Derrick Early Instrument Flight Rules 2 August 15th 04 01:13 AM
Why a static port? Paul Mennen Owning 11 August 19th 03 04:58 AM
Is a static port a precision thing? Larry Smith Home Built 8 August 12th 03 10:26 PM
Static in KX-165A Chad Lemmen Owning 3 July 21st 03 09:57 PM
Canard static port location Paul Lee Home Built 1 July 12th 03 02:55 AM
