how roll fuselage/engine package
Old May 5th 05, 11:11 PM
Dick
Default how roll fuselage/engine package
Having a "better G" idea, decided to hang my engine on M1 fuselage without
wings in order to have the ability to roll it outside the hanger for breakin
efforts.
After struggling with several versions of a wooden framed, wheeled "wagon",
a thought occurred that I may be "reinventing the wheel" (as usual).
Has anyone out there found a method to move the "engine on fuselage without
wings" or move a completed plane with one wing removed?? The M1 has main
gear on the wings, not on the fuselage.
Thanks, Dick
Old May 6th 05, 06:12 AM
Highflyer
"Dick" wrote in message
m...
without wings in order to have the ability to roll it outside the hanger
for breakin efforts.
"wagon", a thought occurred that I may be "reinventing the wheel" (as
usual).
without wings" or move a completed plane with one wing removed?? The M1
has main gear on the wings, not on the fuselage.
Thanks, Dick
In order to move my Piper Apache fuselage around the hangar while I have the
wings off I made up a little cart. It is basically a frame with two ends
and a bottom mounted on large heavy duty casters. I stretched a length of
carpeting about three feet wide across the frame ends to make a wide carpet
saddle that the fuselage lays on. When I park it I put a two by six through
the spar openings and take a bit of a strain on it with the jacks. That
steadys the fuselage in the sling. The third wheel on the ground also
steadys it fore and aft. It looks kind of like an old bedstead with carpet
slung from the headboard to the footboard and the airplane across the bed!
Highflyer
Old May 6th 05, 02:16 PM
Dick
Thanks, the 3' carpeting sling and stabilizing 2x4 thru spar openings is a
good idea.
"Highflyer" wrote in message
m...
usual).
Thanks, Dick
the wings off I made up a little cart. It is basically a frame with two
ends and a bottom mounted on large heavy duty casters. I stretched a
length of carpeting about three feet wide across the frame ends to make a
wide carpet saddle that the fuselage lays on. When I park it I put a two
by six through the spar openings and take a bit of a strain on it with the
jacks. That steadys the fuselage in the sling. The third wheel on the
ground also steadys it fore and aft. It looks kind of like an old
bedstead with carpet slung from the headboard to the footboard and the
airplane across the bed! :-)
Highflyer
Old May 6th 05, 09:40 AM
guynoir
I don't know what an "M1" is. I think you you plan on mounting your
engine to the fuselage, then mounting the fuselage on some sort of
wheeled table so that you can move the assembly around, and also run the
engine (not while you're moving it around, of course). And you want it
to be simple, cheap and easy to build, made out of 2 x 4's held together
with drywall screws and duct tape.
I happen to know a very simple solution, much simpler than building a
custom carriage. This method has been thoroughly tested and it really
is the way that at least 99% of successful aircraft builders do it.
Attach both wings and the landing gear to the aircraft, and then hook up
all engine and airframe systems before running the engine. That way the
aircraft is easy to move around on its own wheels, you have a safe
engine test stand for engine break in, and you're running the aircraft
as a complete system, the way it was designed to work. Why would anyone
want to do it any differently?
Skystar Aircraft, manufacturers of the Kitfox, almost went bankrupt when
a runaway 182 went through their hangar. The A&P mechanic decided to
test run the engine without installing the pilot seats. He had the
throttle linkage backwards. When the engine ran away from him, he lost
his balance in the unfurnished cockpit and became a baggage compartment
passenger while the 182 made a full throttle tour of Skystar's hangar.
$300,000 in uninsured damage for Skystar.
That sounds like the kind of adventure you're preparing for.
efforts.
Thanks, Dick
John Kimmel
Naturally, these humorous remarks are all entirely my own opinion, based
solely
on rumor, supposition, innuendo and damned lies, and should be
interpreted in a
spirit of fun. My memory is faulty, also.
Old May 6th 05, 02:26 PM
Dick
Midget Mustang, single seater experimental.
There are 2 other planes crammed into the hanger and having wings installed
is not an option at this time. The builders on the field have broke-in
engines on a fuselage without wings several times previously. Safety of
course is most important. I find builders innovative and some, basically
cheap (myself).
Hence the 2x4 approach. Although my stand has no duct tape, we did race a
formula Vee back in the 60's and sometimes used duct tape for securing body
skin at 95-100 mph..
"guynoir" wrote in message
I don't know what an "M1" is. I think you you plan on mounting your engine
to the fuselage, then mounting the fuselage on some sort of wheeled table
so that you can move the assembly around, and also run the engine (not
while you're moving it around, of course). And you want it to be simple,
cheap and easy to build, made out of 2 x 4's held together with drywall
custom carriage. This method has been thoroughly tested and it really is
the way that at least 99% of successful aircraft builders do it. Attach
both wings and the landing gear to the aircraft, and then hook up all
aircraft is easy to move around on its own wheels, you have a safe engine
test stand for engine break in, and you're running the aircraft as a
complete system, the way it was designed to work. Why would anyone want
Skystar Aircraft, manufacturers of the Kitfox, almost went bankrupt when a
runaway 182 went through their hangar. The A&P mechanic decided to test
run the engine without installing the pilot seats. He had the throttle
linkage backwards. When the engine ran away from him, he lost his balance
in the unfurnished cockpit and became a baggage compartment passenger
while the 182 made a full throttle tour of Skystar's hangar. $300,000 in
usual).
Thanks, Dick
John Kimmel
solely
on rumor, supposition, innuendo and damned lies, and should be interpreted
in a
Old May 6th 05, 10:49 PM
guynoir
I still don't understand why you want to break in an engine on a
non-flying aircraft. What's the point? You're going to have to finish
putting the aircraft together anyway, and it will probably be days,
weeks or months between the assembly and actual airworthiness. Why not
run the engine then?
cheap (myself).
John Kimmel
solely
interpreted in a
Old May 7th 05, 12:04 AM
Dick
I don't know if you're pulling my leg or not,but..
some reasons a
Running the engine gives a lot of personal satisfaction; debugging the
instrumentation and operating parameters as actually connected to the planes
panel and not on a test stand; something to do while awaiting parts,
whatever; can figure out exhaust and mufflers layout; can figure out cowling
fit; can solve any heating/cooling problems; etc, etc..
Boils down to my project and whatever makes me happy G
I still don't understand why you want to break in an engine on a non-flying
aircraft. What's the point? You're going to have to finish putting the
aircraft together anyway, and it will probably be days, weeks or months
between the assembly and actual airworthiness. Why not run the engine
then?
installed is not an option at this time. The builders on the field have
broke-in engines on a fuselage without wings several times previously.
Safety of course is most important. I find builders innovative and some,
basically cheap (myself).
body skin at 95-100 mph..
John Kimmel
solely
in a
Old May 7th 05, 02:30 AM
larsen-tools
See........ Dick is a dick.
some reasons a
planes
cowling
non-flying
then?
some,
a
John Kimmel
solely
interpreted
in a
Old May 7th 05, 08:14 AM
guynoir
Your reasons for running the engine suck. A proper, deliberate and
methodical approach to finishing your aircraft will result in a finished
flying aircraft in the minimum time and with fewest problems. Disasters
like the Skystar incident are rare, but pursuit of instant gratification
is all the invitation needed.
I agree with your reasons for having the engine mounted on the fuselage.
You have already figured out a way to support the fuselage with the
engine on it, since you have the fuselage completed and the engine is
mounted on it. It seems to me that there is no obstacle to your
completing the aircraft. Final debugging can be done with the wings and
landing gear installed, as has been the usual practice for everyone else
who's ever built a midget mustang or mustang 2.
some reasons a
John Kimmel
solely
interpreted in a
Old May 7th 05, 06:12 PM
I was originally going to suggest making a structure that would bolt to
the ends of the main spar fittings, but that could impart stress on
those fittings that could damage them. The bed/carpet sling idea is
OK, except that you will be running the engine, not just moving the
assembly around. How about making a wood structure that "sandwiches"
the wing stub ( say about a foot outboard of the fuselage sides ) Think
of the "clapboard" that the movie industry uses before each "take" of a
scene. Cut out the shape of the airfoil between (2) 2 x 8's. Hinge
the 2 x 8's on one end and bolt them together on the opposite end.
Then extend a vertical board on the forward end of the structure and
put casters/wheels on the end. You could arrange the casters far
enough forward that you wouldn't have to add weight to the tail with
the wings removed. Make one for each side and maybe secure each
structure to the other one for rigidity. Of course making the whole
thing stout as hell and protect the wing. Might work.
Neal
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 July 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 June 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 March 1st 04 08:27 AM
