Circle to land question
Old May 17th 05, 02:18 PM
Dave Butler
Ron Rosenfeld wrote:
If you don't have the runway in sight prior to the MDA, you may NOT be able
to make a successful landing using normal maneuvers (a requirement to
operate below the MDA).
I'm sure Gene understands what you are saying, but for my benefit, could you
elaborate a little on this statement? Why is this true?
Thanks.
Dave
I miswrote a bit. In addition to what others have written, what I really
meant to write was that "if you don't have the airport in sight prior to
the MAP (missed approach point) ..."
And the reason for that has to do with geometry. The MAP may be too close
and to allow for normal maneuvers to land. (And using normal maneuvers is
a requirement of 91.175)
Sorry about the confusion.
Cool. Thanks for the clarification. Dave
  #32
Old May 23rd 05, 11:32 AM
If you want to provide your real email address I'll send you an old IFR Refresher article
about circling.
A Lieberman wrote:
On Mon, 16 May 2005 15:08:09 GMT, Gene Whitt wrote:
Hi Gene,
First and foremost, thanks for hosting your awesome website! Some of my
comments in my "newbie" sense of the IFR world.
---Circling approaches are an option to be avoided in times of reduced
visibility
This would be tough to avoid at an airport like mine. Maybe rephrase:
IF POSSIBLE Circling approaches are an option to be avoided in times of
reduced visibility. Precision approaches should be the preferred choice if
available.
---You must choose the circle before descending below its MDA
Can you clear this statement up? I am not sure I understand it.
---Circling at night, in low visibility and exposed to disorientation is a
lost poker hand
I would rephrase the last part ....a potentially loosing poker hand.
---By keeping your distance from the airport until turning final you avoid 'killer'
bank angles
You may want to add to this statement, keep in mind winds aloft direction
may push you closer to the airport then you intend.
Allen
  #33
Old May 24th 05, 03:33 AM
A Lieberman
about circling.
Hi Tim,
is a valid address. Look forward to seeing it!
Allen
  #34
Old May 24th 05, 04:22 AM
John Clonts
wrote in message ...
about circling.
I'd like to see it too please-- jclonts at hot dot rr dot com
Cheers,
John Clonts
Temple, Texas
N7NZ
Confused about great circle navigation xerj Piloting 7 July 10th 04 05:38 PM
R in a Circle (Airport Surveillance Radar) on VFR charts Jeff Saylor Piloting 66 May 12th 04 04:05 PM
Great circle formulae, True cource and actual heading Sims Piloting 27 October 11th 03 01:55 PM
Defensive circle Dave Eadsforth Military Aviation 23 October 9th 03 06:13 PM
NACO charts - why have a reference circle? Bob Gardner Instrument Flight Rules 5 September 6th 03 01:15 PM
