Inadvertant IMC - DG1000, Manawatu, New Zealand
Old November 21st 20, 10:59 PM posted to rec.aviation.soaring
Andy Mackay
Default Inadvertant IMC - DG1000, Manawatu, New Zealand
Nothing to add, but danger close
https://youtu.be/TH7UXgT4Txs
Old November 22nd 20, 05:36 PM posted to rec.aviation.soaring
2G
These guys were in violation of NZ's cloud separation rules from the get-go, and the instructor was curiously behind the curve during the whole flight.. They are very lucky to have survived. The narrator touched on what equipment and training would be required for them to be legally where they were at any point in the video, and they had none of that (it was not made known if the instructor had the cloud flying training - if so he should not permitted the student to get them into that position).
This is confirmation of my position that gliders involved in ridge (in the close vicinity of clouds) or wave flight should have an artificial horizon and the pilot must be trained in its use. I have gotten trapped above the clouds on a wave flight and had to make a 7,000 ft descent thru the clouds w/o any instruments other than the basic ones and certainly no training in instrument flight. I did it by flying a constant compass heading at a constant speed, making minimal control movements. At the time, artificial horizons were large, power hungry devices and never used in gliders. Now, they are small (at least some of them) and energy efficient. The easiest way to get instrument training is in a conventional power plane, and the most realistic time to do it is a moonless or cloud covered night away from any city lights.
Tom
Old November 22nd 20, 06:40 PM posted to rec.aviation.soaring
On Monday, November 23, 2020 at 6:36:29 AM UTC+13, 2G wrote:
These guys were in violation of NZ's cloud separation rules from the get-go, and the instructor was curiously behind the curve during the whole flight. They are very lucky to have survived. The narrator touched on what equipment and training would be required for them to be legally where they were at any point in the video, and they had none of that (it was not made known if the instructor had the cloud flying training - if so he should not permitted the student to get them into that position).
No argument there.
I've heard this view from a number of pilots. I disagree.
In the case in the video they where only just over 1,000ft clear of the top of the hill they were soaring. Are you suggesting they deliberately enter cloud that close to terrain? On a day windy enough to ridge soar?
Or are you suggesting that after they inadvertently enter cloud they fire up the instruments, change mental gear, and soar clear.
I'd suggest that the more realistic option is to know the conditions, always stay clear of the cloud, always have a clear escape route.
Your instrument flying skill learnt in smooth air several years ago and not kept current by regular refresh will be unlikely to save you in a high pressure situation where you must do the right thing right now in high winds and likely turbulence.
Phil Plane
(Only caught above cloud a few times and always amazed we don't see more serious cloud related accidents. Those gaps disappear quickly and cloud can be sneaky)
Old November 22nd 20, 09:29 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
wrote on 11/22/2020 10:40 AM:
No argument there.
Phil Plane
I was astounded at how casually they flew beside clouds when they had so little ground
clearance! I would never do that while ridge soaring. The times I've been in wave with clouds
below, there was always 6000'+ or so ground clearance, often even well downwind, and I've
routinely carried a 57mm T&B to help me descend through the clouds - just in case. Never needed
it.
Old November 22nd 20, 10:45 PM posted to rec.aviation.soaring
2G
No argument there.
Phil Plane
If they had followed the specified cloud clearance regs already in place the incident likely would not have occurred. But nobody's perfect and they do make mistakes and find themselves in situations that require this equipment and training (it happened to me). Clouds can form spontaneously, especially during wave flight, so you can be clear of clouds and, then, suddenly find yourself in the clouds. Flying with an artificial horizon is not particularly difficult: you just treat it like a real horizon. It is more of a mental exercise of knowing that your life depends upon that instrument and you must totally trust what it is telling you. How much recurrent training is required depends upon the individual. If you think you need annual refreshers, then by all means get it. The training I got was on a cloud-covered night away from city lights and with a hood for extra measure. The instructor put me into several upset attitudes from which I had to recover solely using instruments. That was one of the best flying lessons I ever had.
I would never recommend intentional cloud flying so close to the terrain, equipped and trained or not (other than in an emergency, which I once had and was glad I had the training to handle it).
Tom
Old November 23rd 20, 12:11 AM posted to rec.aviation.soaring
2G
No argument there.
Phil Plane
Tom
The video has now been blocked from viewing.
Tom
Old November 23rd 20, 12:18 AM posted to rec.aviation.soaring
George Haeh
Outside controlled airspace, I believe the air regulations in various countries only require "clear of cloud" when below 1000' AGL.
Turning upwind into cloud brings on some navigational challenges, even if you have the instruments and skills.Turning back in cloud to parallel an invisible ridge or try to regain visual in a strong wind before smacking a rock is a crapshoot. Any airway in a mountainous region has a minimum 2000' AGL clearance over terrain.
In defense of the pilots, the camera has a limited view. My impression is that it was severe clear above until sink put them into the soup.
Old November 23rd 20, 12:43 AM posted to rec.aviation.soaring
This happens more often than you might think.
At a club where I used to fly there is a chief flight instructor who does this on a regular basis. Apparently the entire board of directors at that club is scared ****less to call him out on it. He did it three times with students two of whom are not rated at all in the space of a single day. He's an accident waiting for a chance to happen.
Even with an appropriately equipped and certified aircraft there's a difference between being instrument rated and instrument proficient.
Old November 23rd 20, 12:56 AM posted to rec.aviation.soaring
2G
Well, it definitely wasn't "severe clear" above them as the video showed clouds well above their altitude. The specific glider cloud clearance regulation is (http://gliding.co.nz/wp-content/uplo...AP-AL-26.pdf):
104.55 Clearance Below Cloud
Notwithstanding 91.301(a)(2), the pilot of a glider, above an altitude of 3,000 feet and above
a height of 1,000 feet, but below an altitude of 11,000 feet, shall fly no closer than 500 feet
below cloud within Class E or G airspace.
This allows a glider to fly closer to cloud than the 1000 ft otherwise permitted in these
circumstances.
Note that this says BELOW the cloud - there is no regulation for flying ABOVE the cloud in this manual. In the general regulations, the clearance is 1,000 ft when above 3,000 ft MSL (https://www.caa.govt.nz/assets/rules...olidation.pdf), which they weren't complying with at any time in the video.
Tom
Old November 23rd 20, 01:50 AM posted to rec.aviation.soaring
Matthew Scutter
Artifical horizons aren't typically complex instruments requiring a spinup period anymore - I have it on an LX9000 and an AirGlide S only a single knob rotation away at any given time, and whenever I'm even slightly nervous about my situation I put it on the display. The AirGlide S has the airspeed on the display as well, so even an untrained pilot should be able to keep the horizon level and the airspeed roughly constant.
Particularly at the moment, smoke is a real hazard to VFR and it's difficult to predict when thin smoke may become much thicker in the cruise.
It's a shame that they're not more affordable and ubiquitous, but I would be concerned pilots would acclimatize to the protection they offer and end up in cloud more often...
No argument there.
Phil Plane
Inadvertant IMC in DG1000 Andy Mackay Soaring 2 November 22nd 20 09:51 AM
Inadvertant PTT - Where do you put your hand? ContestID67[_2_] Soaring 19 April 20th 11 07:50 AM
DG1000/2 Frank Whiteley Soaring 10 December 12th 08 05:14 PM
Inadvertant IMC Ol Shy & Bashful Piloting 12 May 26th 08 02:03 PM
Trailer hitch inadvertant disconnect Bill Daniels Soaring 5 July 16th 04 03:17 AM
