Four people died aboard a 172 that crashed at Coney Island today
(http://www.nytimes.com/2005/05/22/ny...2crash.html?hp). According to witness descriptions, the plane approached the shore at low altitude, turned sharply, and then plummeted vertically. The witnesses had the usual confusion about "stalling" and interpreted the crash as a loss of power, but it sounds like it may have been a classic stall resulting from inadequate airspeed during a steep turn. Coney Island is close to a section of airspace where the Class B has a floor just above 500', so it may be that the plane hadn't climbed much above that altitude, and tried to turn abruptly away from the shore in order to avoid overflying a built-up area too low. --Gary |
The class B floor is 500? Sounds like a recipe for some sort of
airspace version of scud running, which in turns sounds like a great way to have unrecoverable stalls/engine outs, controlled flight into terrain/water. Most unfortunate, my best wishes to the families affected. |
Or was showing off, hope that wasn't the case. But it does show the
dangers of low, slow steep turns. |
"Ben Hallert" wrote in message
oups.com... The class B floor is 500? Sounds like a recipe for some sort of airspace version of scud running, which in turns sounds like a great way to have unrecoverable stalls/engine outs, controlled flight into terrain/water. It's a twelve-mile-stretch of the Long Island shore, just a few miles south of JFK. It's actually quite fun to fly there at that altitude--I've done it several times. An engine failure wouldn't be especially bad because there's a beach to land on (or you can ditch just offshore if the beach is too crowded). You do, of course, need to avoid stalling (or especially spinning). --Gary |
Ben Hallert wrote:
The class B floor is 500? Sounds like a recipe for some sort of airspace version of scud running, which in turns sounds like a great way to have unrecoverable stalls/engine outs, controlled flight into terrain/water. Actually over Coney Island the floor of Class B space is at 1500 ft (I'm looking at my NY chart). It's hard to tell from the ground how high the airplane is. Unfortunately it sounds like a classic stall/spin. You can see the tail number in the NYT photo.. Most unfortunate, my best wishes to the families affected. Yes. Very sad ![]() ....richie |
oups.com... Actually over Coney Island the floor of Class B space is at 1500 ft (I'm looking at my NY chart). Right, but just nearby the Class B is 500'(+). If the plane came from there, it might still have been quite low (or it might've been low anyway just to get a better view). --Gary |
I'm not a pilot but I was wondering why this plane went down "nose first"
??? I'm thinkin', don't these things have some gliding ability ??? i guess the pilot must've been too low to recover ..... Having an engine quit on you is bad enough luck ..... but having it happened when you just happen to be at a low altitude is even worse luck ! ("Gary Drescher" wrote in message ... wrote in message oups.com... Actually over Coney Island the floor of Class B space is at 1500 ft (I'm looking at my NY chart). Right, but just nearby the Class B is 500'(+). If the plane came from there, it might still have been quite low (or it might've been low anyway just to get a better view). --Gary |
"Ernest C. Evans" wrote in message
... I'm not a pilot but I was wondering why this plane went down "nose first" ??? I'm thinkin', don't these things have some gliding ability ??? i guess the pilot must've been too low to recover ..... Having an engine quit on you is bad enough luck ..... but having it happened when you just happen to be at a low altitude is even worse luck ! (Actually, having an engine quit would *not* cause a plane to fall. As you say, it would just glide instead. What does cause a plane to fall--whether the engine is running or not--is pulling back too far on the control wheel, which causes the plane to slow down too much (at least, that's the simplified explanation). When that happens, witnesses who are not familiar with aerodynamic principles often perceive the incident as an engine failure, which is then how the press reports it initially. You're right too that when a plane stops flying (the technical term is "stalling", but that's confusing because it has nothing to do with the *engine* stalling), you can recover if you have enough altitude, but being lower makes recovery harder. Stall recovery shouldn't take much more than 100 feet, but there's a particularly bad type of stall--called a spin--that can take more than 1000 feet to recover from. --Gary |
Subsequent updates are emphasizing witness reports that the engine sounded
like it was sputtering, so perhaps an engine failure did contribute to the crash. --Gary |
Ben Hallert wrote:
The class B floor is 500? Sounds like a recipe for some sort of airspace version of scud running, which in turns sounds like a great way to have unrecoverable stalls/engine outs, controlled flight into terrain/water. The airspace below is over open water. It's perfectly reasonable. |
| Thread Tools | |
| Display Modes | |
| C172 Plane crash Orlando, FL | CFLav8r | Piloting | 25 | January 15th 05 09:54 PM |
| Long Island Crash - Kite String? | Neb Okla | Rotorcraft | 5 | September 3rd 04 06:43 PM |
| Navy releases names of 4 killed in island crash | Otis Willie | Military Aviation | 0 | August 15th 04 12:21 AM |
| Madeline Island and Richard I. Bong Museum PIREP | Jay Honeck | Piloting | 3 | July 20th 04 04:21 AM |
| Soviet Submarines Losses - WWII | Mike Yared | Military Aviation | 4 | October 30th 03 04:09 AM |
