FLARM releases firmware for ADS-R and TIS-B
Old January 23rd 21, 10:45 PM posted to rec.aviation.soaring
Bob Caldwell (BC)
Default FLARM releases firmware for ADS-R and TIS-B
On Thursday, January 21, 2021 at 3:22:40 PM UTC-7, Ramy wrote:
On Tuesday, January 19, 2021 at 10:44:42 PM UTC-8, Ramy wrote:
On Tuesday, January 19, 2021 at 10:06:19 AM UTC-8, Matt Herron Jr. wrote:
Ramy;
I am curious to know what your experience with fusion is also. What is your antenna set-up? Range get better or worse? coverage get better or worse? Did you have the same antenna set-up with the core prior to fusion (so we can compare the two boxes)?
Matt H
Matt, Charles, I wasn’t clear. I meant I was flying with the beta version of core with TIS-B and ADS-R before it was released last week. I don’t have the Fusion unit (yet). I am seriously considering it.
Ramy
I am considering upgrading to Fusion. If anyone is interested in my powerflarm core which includes all licenses including the new TIS-B/ADS-R for $1000 plus shipping please let me know.
Ramy
Has anyone tried the 7.03 Beta version which enables alerts associated with UAT targets?
  #42
Old January 24th 21, 03:13 PM posted to rec.aviation.soaring
Steve Koerner
So, with this upgrade to PowerFlarm and LX Nav computer, am I likely then to start seeing the Air Force fighter jets that permeate the sailplane MOAs in Arizona? (tongue in cheek ideology there)
  #43
Old April 27th 21, 11:24 PM posted to rec.aviation.soaring
Ramy[_2_]
Some folks who installed the new license in a glider with only mode C transponder are reporting seeing “ghosting” of their own glider. This is expected when you don’t have ADS-B out.
You may or may not notice this issue, it is a combination of multiple things, mainly which transponder you have, your flarm display configuration, and how much experience you have with flarm. For example you may want to disable zoom to nearest if you have the ghosting issue and use manual zoom instead (my recomendation is to set it manually to 1-2 miles)
However if you still find it distracting, you can completely disable TIS-B. You will still benefit from ADS-R which relays UAT aircrafts (about half of GA aircrafts?) but you will not benefit from TIS-B which relays transponder only aircrafts (e.g. gliders without powerflarm).
To disable TIS-B (only relevant to those who purchased and installed the new license or purchased the new Powerflarm Fusion):
If you use the online configuration tool: https://flarm.com/support/tools-soft...iguration-tool, in advanced mode under "Rebroadcast Services" select "ADS-R Only".
If you use text editor, just add/update the following line in your config file:
$PFLAC,S,REBROADCASTSERVICES
Ramy
Ramy;
Matt H
Ramy
Ramy
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 04:13 AM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
IGC Flight Recorders using Flarm firmware - New DLL file forvalidating IGC flight data files Ian Strachan Soaring 0 July 20th 14 07:28 PM
Flarm with Firmware 1.20 update Robert Fidler[_3_] Soaring 49 January 31st 12 03:40 PM
FLARM firmware release schedule Andy[_1_] Soaring 11 January 5th 11 06:09 PM
Copyright 2004-2024 AviationBanter.
