#11
3 Turn Point Distance
On Wednesday, March 3, 2021 at 10:05:20 PM UTC-5, xcnick wrote:
On Wednesday, March 3, 2021 at 6:55:33 PM UTC-8, tango: CNv works a little differently, you must declare the task you want declared on the ground, then that declaration remains active until superseded. does this mean that if I change the go to on the CNv I loose the declaration? No, once the declaration is set in CNv, it's set for keeps. Use for navigation as you like. A 750 diplome needs to be done to 3TP distance rules. Use release or declared start, up to 3 turn points (in any order), finish isn't declared, it's best fix. Free 3TP distance is a separate category for records. T8 |
Similar Threads | ||||
Video Surfaces Of Russian Su-27 Making Aggressive Turn Into U.S. F-15 During Intercept - Su-27 aggressive turn.jpg | Miloch | Aviation Photos | 0 | February 1st 19 04:27 AM |
turn point | glen | Soaring | 14 | May 26th 13 02:15 AM |
Turn point Files | Zaphod Beeblebrox | Soaring | 1 | March 25th 12 02:26 PM |
Turn point website and flight logs | Udo | Soaring | 2 | December 5th 06 11:03 PM |
Calculating vertical time and distance in a stall turn (US Hammerhead) | Dave | Aerobatics | 3 | November 20th 03 11:48 AM |
