ASW-24
Old May 27th 05, 01:46 PM
Papa3
Udo Rumpf wrote:
Of course it would be true, at 80km/k you would be flying to slow
if you tried to thermal.
This is minimum sink speed in level flight at 6.5 lb/sqft.
at 7.5 lb/sqft you would be approaching stall speed.
To recap the ASW24 does not have to be flown any faster then
other glider of its type. Two gliders you have mentioned have a much
lighter wingloading and the Discus and the ASW24 with 7.5 lb/sqft
will fly at about the same speed.
Now I know how misinformation gets started.
Regards
Udo
Udo,
A related question in terms of data points. How significant is the
in-flight CG on climb performance? It's purely subjective, but my LS8
seems to climb markedly better now that I've moved the CG back to about
80% of aft limit (from a previous 45%). Locically, aft CG would
reduce the amount of lift (nose up pitch) required of the
elevator/stabilizer, reducing induced drag from these surfaces. As a
percentage of total induced drag I'm sure this relatively small, but is
it significant?
Erik Mann (P3)
Old May 27th 05, 02:34 PM
Udo Rumpf
Eric
From my initial set-up I flew with a C of G in the 50% to 55% range.
This worked out nicely. The up elevator in climb was identical
to the down in cruise. I was happy with this compromise.
Then I loaded water 55 litres in each tank about 240 lb total.
To thermal, I needed much more control input and up elevator,
due to the water being ahead of the C of G. Also I had the sense,
aside from being heavier, it was not climbing as well. This could
have been subjective. I added 5 lb to the tail and the handling
improved and felt just as before when dry.
I was surprised when I dumped the water how much more nimble
and responsive but still very comfortable it felt. I am flying dry now
at 85% C of G. The elevator with the new C of G, once the bank and turn
is established, has a minimal up deflection but in cruise the elevator
is even more in a down deflection. This causes more drag. This can
be corrected by placing a washer under the bolt attachment of the
stab to reduce the angle of incidence to reduce the down deflection
in cruise. Ideally the ASW 24 should have a tail tank.
Anyone know of someone that made this mod on the 24?
Regards
Udo
"Papa3" wrote in message
Regards
Udo
Udo,
it significant?
Erik Mann (P3)
Old May 27th 05, 05:42 PM
Papa3
Udo Rumpf wrote:
Eric
Regards
Udo
What you really need is a lead weight on a track mounted in the
fuselage driven by a small motor. Move the weight back for climb.
Move it forward for cruise :-)) Actually, the flight research
department at my University had this installed in Navions. I guess
I'm only half-joking...
P3
Old May 27th 05, 08:09 PM
Bob Johnson
Papa3 wrote:
Udo Rumpf wrote:
Eric
Regards
Udo
P3
Reminds me of the "mercury pump" gadget Moffat supposedly revealed to
his fellow contestants on the start grid one long-ago day.
Didn't matter whether it worked or not, the other guys were so psyced
out they were beaten before they hooked up.
Bob Johnson
Old May 28th 05, 09:58 PM
Nyal Williams
At 19:30 27 May 2005, Bob Johnson wrote:
Papa3 wrote:
Udo Rumpf wrote:
Eric
turn
cruise the elevator
drag. This can
of the
down deflection
Regards
Udo
in the
back for climb.
research
Navions. I guess
P3
Reminds me of the 'mercury pump' gadget Moffat supposedly
revealed to
day.
were so psyced
Bob Johnson
Moffat comes from a racing sailboat tradition, where
trickery is admired if not the norm and where clever
rule beating devices are constantly developed. I heard
of one sailor who, not allowed ballast at his weighing,
put several boxes of tomato soup (highest specific
gravity) in the bilges as crew provisions.
I never met George and I'm not accusing him of cheating,
but the out-psych'em strategy is certainly a NE tradition.
Old March 9th 18, 12:12 PM posted to rec.aviation.soaring
Default ASW-24
Hy its probably a bit late for this thread but i thought, this would be a good adress for what i'm searching for.
I'm looking for some nixon winglets for my 24, are there any tips where i could order a pair or if they are still available they could also be used already or even damaged. Sadly i found nothing on the internet and there are also no other 24 owners with nixon winglets here in switzerland.
Would be cool if someone still reads this haha.
greetings and thank you from switzerland
Yves Müller ASW 24 HB-3008 "CRN"
Old March 9th 18, 01:41 PM posted to rec.aviation.soaring
Default ASW-24
Hank Nixon will likely read this thread this morning and get back to you. He still does winglets, wouldn't be surprised if he could do a set of -24 for you.
But, let him tell you.
Old March 9th 18, 11:51 PM posted to rec.aviation.soaring
Default ASW-24
Hank Nixon (UH) is completing a set of ASW 24 winglets for another pilot as I write this. He still builds them, especially now that they are approved by Schleicher. Just respond directly to any posting by UH on this forum.
Chip Bearden
Old March 10th 18, 12:30 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default ASW-24
As I understand it, there are three different sets of winglets for the ASW-24. I had the Nixon ones and liked them. I think there is a Mark Maughmer designed winglet and also a factory winglet.
One of Rex's rentals has the Maughmer set and the other has one of the others.
On Wednesday, May 25, 2005 at 4:54:34 PM UTC-7, Lee Rusconi wrote:
I have an opportunity to buy a 1988 ASW-24 which is
in beautiful condition, good electronics and great
trailer. The glider is equipped with M&H winglets.
The asking price is $45,000 US. I would appreciate
any feedback regarding the winglets and/or the price.
Thanks
Old March 10th 18, 03:36 PM posted to rec.aviation.soaring
Dan Marotta
Default ASW-24
My aerodynamic interest is piqued.Â* As small as winglets are with
respect to the wings, can you notice or measure a performance difference
between the three different types of winglets mentioned in this thread?
Thanks
Dan, 5J
