Biplane wing dihedral
Old June 16th 05, 03:09 AM
Gord Beaman
Ed Sullivan wrote:
On Sat, 11 Jun 2005 00:04:10 -0400, vincent p. norris
Friend of mine said at lunch today that the upper wings of biplanes
have no dihedral. Hementioned specificlaly the Stearman PT-17.
I believe he was mistaken. I know the Sopwith Camel upper wing was
flat but I think the PT-17 and most other biplanes have dihedral in
both wings.
Any expert comments?
Thanks. vince norris
Some biplanes have sweptback wings which provide the same effect as
dihedral. My parasol Jungster II has sweepback and no dihedral.
Ed Sullivan
Why is that Ed?...dihedral provides lateral stability by making
the 'downgoing wing' increase it's lift while the 'upgoing'
wing's lift decreases, so how does the 'sweep-back' provide
lateral stability?
-Gord.
"I'm trying to get as old as I can,
and it must be working 'cause I'm
the oldest now that I've ever been"
Old June 17th 05, 01:54 AM
Ed Sullivan
On Thu, 16 Jun 2005 02:09:30 GMT, Gord Beaman
both wings.
Ed Sullivan
lateral stability?
The reference escapes me, but I have read that so many degrees of
sweep back is the equivalent of an estabilished amount of dihedral.
All I know for sure is that this little sucker only has a 21' span and
it is as steady as a rock. It will go for miles without touching the
stick.
Old June 17th 05, 02:06 AM
Gord Beaman
both wings.
Ed Sullivan
lateral stability?
stick.
Ok, thanks...I know that sweepback will increase fore and aft
stability by making the critical fore and aft CG limits 'farther
apart' but I sure can't see how it affects lateral
stability...anyhoo...if you find out could you tip me off?
Thanks Ed.
-Gord.
Old June 17th 05, 08:20 AM
Ed Sullivan
On Fri, 17 Jun 2005 01:06:53 GMT, Gord Beaman
stick.
Thanks Ed.
This is not a complete explanation, but it might help.
http://avstop.com/AC/FlightTraingHan...Stability.html
Old June 17th 05, 12:50 PM
Brian Whatcott
On Fri, 17 Jun 2005 00:20:28 -0700, Ed Sullivan
stick.
Thanks Ed.
It does help - but in a disconfirming sense - let me quote:
"The contribution of sweepback to dihedral effect is important
because of the nature of the contribution. In a sideslip the wing into
the wind is operating with an effective decrease in sweepback while
the wing out of the wind is operating with an effective increase in
sweepback. The reader will recall that the swept wing is responsive
only to the wind component that is perpendicular to the wing's leading
edge. Consequently, if the wing is operating at a positive lift
coefficient, the wing into the wind has an increase in lift, and the
wing out of the wind has a decrease in lift. In this manner the swept
back wing would contribute a positive dihedral effect and the swept
forward wing would contribute a negative dihedral effect. "
This suggests that sweepback is directionally destabilizing..... (?)
Brian Whatcott Altus, OK
Old June 17th 05, 09:07 PM
Gord Beaman
stick.
Thanks Ed.
Yes, I see your point Brian and on a slightly different tack, I
always saw dihedral like this.
A wing has max lift when it's 90 degrees to gravity, (or 'down')
it has zero lift when pointed straight 'up'...now, when a gust
knocks a wing (with dihedral) 'down' (towards level) then it's
lift increases while the other wing's lift will decrease (as it
goes upwards 'toward' the 'zero lift angle'. Hell, if you had
'enough' dihedral then you couldn't roll the a/c because of this
powerful effect, the ailerons wouldn't have enough authority to
overcome it. Taking things to a ridiculous extreme you could have
say, 45 degrees of dihedral where it'd be possible to have a gust
of wind take one wing 'down' to 90 degrees so that it has the max
lift that it's capable of while the other wing is pointed
straight up and has 'no' lift at all.
I imagine that the correction then would be somewhat sudden.
-Gord.
"You are completely focused on RPM as the
single factor producing rotational velocity"
-Dude Henrickles
Old June 17th 05, 11:22 PM
Brian Whatcott
On Fri, 17 Jun 2005 20:07:30 GMT, Gord Beaman
goes upwards 'toward' the 'zero lift angle'.///
-Gord.
I think that I must have read this thread once too many times...in
that when I read what I posted, I see that the "Traing" text implies
just the opposite of what I thought it did. Oh my: he says sweep
back is like dihedral, but the argument seems to point the other way.
Think I will shut up, now!
Brian W
Old June 17th 05, 11:45 PM
Ed Sullivan
Brian W
I'm really sorry I started this. Perhaps my parasol also benefits from
the pendulum effect. It does have a slight dutch roll tendency, but
the controls are so light that this is overcome easily. According to
what I have read my aircraft has far more sweepback ( 15 degrees )
than is healthy subsonic, but it doesn't seem to care. It does very
reliable moderate aerobatics and yet is not a monster on cross country
trips.
Ed Sullivan, me too
Old June 18th 05, 12:08 AM
Ed Sullivan
On Fri, 17 Jun 2005 15:45:41 -0700, Ed Sullivan
Brian W
trips.
Ed Sullivan, me too
I take it back here is some more confusing
info:http://www.av8n.com/how/htm/roll.html
Old June 18th 05, 02:45 AM
vincent p. norris
Aren't a/c with sweptback wings subject to dutch roll?
vince norris
Waco Biplane Down at KSBA Larry Dighera Piloting 3 June 6th 05 02:33 PM
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 08:40 PM
Wing tip stalls mat Redsell Soaring 5 March 13th 04 05:07 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 03:52 AM
