canard flying boat
Old July 20th 05, 02:37 PM
Stealth Pilot
On Wed, 20 Jul 2005 20:05:23 +1000, "......... :-\)\)"
The biggest issue with a canard is that the CLmax of the configuration is
low compared to a conventional configuration. This is for several reasons:
1. The smaller canard must stall first and that means that the wing will
never stall and hence never develop it maximum lift. Of course the opposite
is true for a conventional airplane. The larger wing stalls and developes
its maximum lift whilst the smaller tailplane remains unstalled.
2. Unless you do some tricky stuff you cannot really put a flap on a canard
because it is difficult to trim out the nose down pitching moments.
Low CLmax means that the configuration will not develop as much lift at a
given speed and hence the airplane will not be as suitable for short fields
as will a conventiona configuration.
For those without an engineering background, CLmax is simply a measure of
how much lift a given wing will produce per unit area at a given speed.
CLmax is the maximum lift coefficient.
"Marc J. Zeitlin" wrote in message
fredfighter wrote:
Hmm. ISTM that a canard does not stall when the aircraft pitches
down, it stalls when the aircraft pitches up.
Correct.
picture an aircraft flying along which has a sudden brutal increase in
the resistance of the wheels (note that is hypothetical, thankfully
the snake oil plane wasnt built)
say for instance your canard clips the main wheels on the top wire of
a fence.
in that scenario, which is similar to what I predicted with the
hovercraft skirt, the sudden rotation forward and down would be
catastrophic in that the sudden downward movement of the canard would
probably increase its angle of attack beyond the stall (due to a
change in realtive wind direction).
that is what I was referring to.
other than that I have agreed with all that has been posted.
Stealth Pilot
Old July 20th 05, 06:27 PM
Correct.
a fence.
Or a less drastic scenario, the nosewhell plows thorugh a clump
of grass...
Well, I thought that increasing the pitch (nose up) increased
the angle of attack and decreasing the pitch decreased the angle
of attack. Aren't both angles conventionally measured so that
an upward rotation of the nose of the plane is a positive change
in the respective angle?
E.g. lift increases with increasing angles until teh wing stalls.
If the canard is not stalled and then the nose of the aircraft
pitches downward the lift of the canard decreases pitching the
nose even more downward. In the air the aircraft would accelerate,
trading altitude for speed, thus increasing lift to compensate
for the reduced angle of attack. However on the ground there
is no altitude to trade for speed so the nose bounces.
Have I got it right yet?
FF
Old July 21st 05, 02:45 PM
Stealth Pilot
Correct.
a fence.
of grass...
your mental picture is a practical one but you are looking at an
aircraft with a gently changing angle of attack and your assumptions
are correct I think.
but picture if you will a *very sudden* pitchdown. the canard would
see the direction of the incident airflow change from directly ahead
to somewhere down in front of it. ...like a gust.
dont lose too much sleep over this, the scenario was hypothetical.
besides I have some more of my Turbulent's fuselage beckoning to me
for attention :-) ...and that vw engine I picked up yesterday for
converting.
Stealth Pilot
Old October 19th 15, 07:37 AM posted to rec.aviation.homebuilt
Alejandro Irausquin
Default canard flying boat
Michele, hello from Venezuela. As your relative Frank Edward Boland was the first person to fly in Venezuela, I has been researching his life and work for several years now. Here are the results (in Spanish, not the latest version). I will like to have access to any files or records your family keep on that venture, in order to prepare an english version:
https://www.scribd.com/doc/201685272...autico-Ene2014
Thanks in advance
Alejandro Irausquin
Aeronautical Engineer/Latino-american aviation historian
LAAHS
El martes, 19 de julio de 2005, 17:54:19 (UTC-4), escribió:
My distant relatives built several canard biplane pusher seaplanes
between 1911 and 1917. The used engines that they built themselves.
The planes were turned with their patented "Jib Sheet Rudder" which was
a surface the was mounted on the outside interplane struts between each
wing and pivoted to the outside to turn the plane. It was supposed to
have worked very well.
If you can find a copy of Jane's Planes from back then look for the
Boland Aeroplane and Motor Company. There is also a book called "Wings
of the Weird and Wonderful" that has a picture of the landplane
version.
Michele
Passing of Richard Miller [email protected] Soaring 5 April 5th 05 01:54 AM
Swift Boat Guys Caught in Some Great Big Lies WalterM140 Military Aviation 44 August 23rd 04 08:30 PM
William Rood, Swift Boat skipper : Anti-Kerry vets not there that day Riddick Military Aviation 0 August 21st 04 05:09 PM
[sci.military.naval, rec.aviation.military] Lost Sunderland Flying Boat Found! Sunderland Military Aviation 0 April 4th 04 06:27 PM
'They want to ban recreational flying...' Thomas J. Paladino Jr. Piloting 28 July 22nd 03 07:20 PM
