basic spar construction
Old December 8th 04, 07:47 PM
Dave Schneider
Default basic spar construction
Can anyone suggest some home built construction sites where they show the
process of building a spar for a foam composite wing. I'm confused on how a
spar is built for a foam wing. It doesn't seem like the foam itself would
provide enough structure to provide a web. It would seem like you'd have
to cut the wing foil, cut out the location of the spar, build the spar, and
then reinstert that section back into the foam wing.
Dave
Old December 8th 04, 10:15 PM
The SkyPup ultralight uses foam spar webs and ribs with
wood for the spar caps and rib caps. There are many pictures
on this website, some will show detials of the spars/wings during
construction.
http://www.skypup.net/index2.htm
For the SKyPup, fisrt the spar is made. The foam ribs are
made in two pieces one fore and one aft of the spar, then
butt glued in to the spar web. Then the rib caps are glued on.
The spar caps carry all the compressive and tensile stress due
to bending of the spar as the wing is loaded. The web only carries
shear due to bending and that is quite small.
Clearly not the only way to do it, nor necessarily the easiest
for every builder.
If you are not familiar with beams, it can be very helpful to
study up on beams, especially I-beams and box-beams as
wing spars are essentially beams.
FF
Old December 8th 04, 10:25 PM
Dave Schneider
thanks!
construction.
for every builder.
FF
Old December 8th 04, 10:38 PM
On the SkyPup site the photos are groups by owner in the 'Kennels'
section. It will take a lot os searchign to find one with construction
details.
Good pictures of the wings and spars are also he
http://www2.wcoil.com/~rford/
The show the spar and rib construction quite well.
The Sky Pup is made of foam, wood and fabric so it is a composite
aircraft. Most of the time when refering to composite aricraft the
speaker
means fiberglass, kevlar or carbon fiber.
Conceptually, those other materials can be substituted for the wood
in a SKyPup-like design, though ther result might not necessarily have
a better strenght to weight ratio. The wood in the SKy Pup is used
very
efficiently.
FF
Old December 8th 04, 11:05 PM
Dave Schneider
Thanks. I finally found the same site after some searching. Pretty neat
little ultralight!
Is there any way to calculate wing loads on something like the following
(this is where I'm going). Do you think the skypup construction could
handle these loads:
http://groups.msn.com/LandsailerandI...ndconstruction
Thanks again for your help
details.
speaker
very
efficiently.
FF
Old December 9th 04, 06:05 PM
following
Of course.
The first step is to model or at least establish an upper bound to the
forces acting on it. That may be more complicated for an iceboat
than for an airplane.
handle these loads:
Possibly. The iceboat wing may see more substantial torsional
loads than the SkyPup Wing. In general box beams are, in regard
to strength to weight ratio, very efficient for handling torsional
loads.
The SkyPup spars are more like an I-beam than a box beam.
The SkyPup, being an ultralight was designed to minimize torsional
loading on the wings to permit the use of a single spar and keep
them light as well as keeping the construction simple.
Some aircraft use two spars per wing with x-bracing between them
to handle torsional loads. Some use box beam spars. Monocoque
construction which relies on distributing the stress on the skin rather
than carrying it all on internal structure essentially turns an entire
wing into a box beam.
FF
Old December 9th 04, 02:13 PM
James R. Freeman
Dave:
Take a look at the ruttan wings on a q-1 or q2 it will fit the bill for
what you want. There is one site on the web for free downloads of the q2
info but I do not have the URL at hand. Q1 plan can be had on C.D. for less
than $10 via EBay.
"Dave Schneider" wrote in message
a
would
and
Dave
Old December 9th 04, 03:46 PM
Dave Schneider
after a bit of surfing i found this. Is something like this what you are
talking about?
http://www.hinkleymall.com/airplane_cd.html
There is also this on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...0814 564&rd=1
Basic question for the Quickie, do the wings disassemble? I'm also looking
for techniques for attaching wings.
Thanks!
Dave
"James R. Freeman" wrote in message
Dave:
for
less
than $10 via EBay.
how
a
would
have
and
Dave
Old December 10th 04, 03:34 PM
James R. Freeman
Dave:
I found the URL. It is:
http://www.finleyweb.net/default.asp?id=141
talking about?
http://cgi.ebay.com/ebaymotors/ws/eB...ory=26441&item
=4510814564&rd=1
looking
Thanks!
Dave
Dave:
for
less
than $10 via EBay.
how
a
would
have
spar,
and
Dave
Old December 10th 04, 03:54 PM
James R. Freeman
Dave for Your info. The Quickie and Q2 use a fiberglass build up spar as You
will see from the plans. The Q-200 uses a carbon fiber spar.
Yes the Quickie canard (front wing) can be removed.
Dave:
are
talking about?
=4510814564&rd=1
looking
Thanks!
Dave
Dave:
bill
for
q2
less
than $10 via EBay.
show
on
how
a
itself
would
you'd
have
spar,
and
Dave
cvjetkovic ca-65 skyfly- plywood spar? patrick mitchel Home Built 3 October 16th 04 06:26 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 3rd 04 12:41 AM
Marske spar workshop Marske Flying Wings Home Built 0 October 14th 03 05:53 PM
Carbon Spar design and construction workshop Marske Flying Wings Home Built 0 September 18th 03 06:47 PM
Worthy EAA Construction Books Brock Home Built 5 September 16th 03 08:48 PM
