Ted,
If you want to try wiring in a different mic (and flipping a switch under the cover of the radio to change to the other mic style setting), the wiring diagram is available at: http://www.wingsandwheels.com/AR4201%20Manual.pdf Assuming here that it is a 4201 you have. Otherwise, Rex's comments are good. Try installing an identical radio and see if you have the same problem. I suspect you will. I bet Rex or Tim or one of the guys could get a replacement mic on its way to you tomorrow., as I suspect that is where your problem really is. V2C coming soon, huh? Nice! I suspect you will like it a LOT! Steve |
Steve,
[Second response ... groups dot google nuked my first hack ...] I'll have to check on the model number. Currently checking around for another Becker in the area to test with. But if new mics are cheap ... maybe I'll just try one of those first; if it's not the problem, hey, I'll have a spare. Tim, add one to my order!!! Yeah, the V2C was too good of an opportunity to pass up. I watched that glider pass me a number of times in the ASA contests, and I know how well NC has taken care of it. The 304CZ has been a perfect first ship for me but the 9.4lb max wing loading is really inadequate on strong SW days... -ted/2NO |
ON Becker AR3201 there is a jumper to switch between Dynamic (un-amplidfied)
microphones to Standard (Corbon, Amplified Dynamic and Electret) mjicrophones..however, on the AR4201 there are different Pin-outs for the different microphone types, it is NOT done by changing anything internal to the radio! The 3201 runs only one type mic at a time, the 4201 actually supports 4 microphones at one time, (2) standard and (2) Dynamic....Ted's radio will be a 4201 for sure. the AR3201 has not been produced now for about 6-8 years tim "Steve Leonard" wrote in message ... Ted, If you want to try wiring in a different mic (and flipping a switch under the cover of the radio to change to the other mic style setting), the wiring diagram is available at: http://www.wingsandwheels.com/AR4201%20Manual.pdf Assuming here that it is a 4201 you have. Otherwise, Rex's comments are good. Try installing an identical radio and see if you have the same problem. I suspect you will. I bet Rex or Tim or one of the guys could get a replacement mic on its way to you tomorrow., as I suspect that is where your problem really is. V2C coming soon, huh? Nice! I suspect you will like it a LOT! Steve |
| Thread Tools | |
| Display Modes | |
| Becker radio repair | [email protected] | Soaring | 7 | March 10th 10 04:14 PM |
| Becker radio repair | Steve Leonard | Soaring | 2 | August 23rd 05 03:25 AM |
| Dittel Radio Repair | [email protected] | Soaring | 4 | July 22nd 05 01:02 PM |
| I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 06:39 PM |
| Calibrate? Repair? Adjust? | RST Engineering | Owning | 3 | April 4th 05 02:41 PM |
