I have a Becker 3201 radio in my glider that has a problem. With a
fully charged 14 V system I find that when I push the PTT switch the display starts to blink and the radio then transmits a garbled buzzing noise. A friend thinks that the flashing is a low power signal and that the 24 year old wiring may be offering enough resistance to cause a voltage drop. The radio receives just fine. Anyone know or heard of this problem (and the fix) in the past? TIA Mike KV |
Hi Mike
Check the battery voltage under load (when you key the transmiter). If ok check the voltage as close to the radio as you can while keying the transmiter. There could be a poor connection between the battery and the radio. If that is ok try your radio in a ship that has the same radio. Don't forget to attach the antenna! Ken (KP) |
Mike,
A blinking display is the signal for low voltage (10.5-11) and it would show up first during transmit. I am not so sure about the buzzing sound though. Test the disconnect the radio and test the voltage on the DB-15 connector. Pins 4 and 5 are +, pins 2 and 3 are ground. Test those with a multimeter for voltage at the radio. The fix if that's bad is to rewire the radio power leads. You might just need to clean the connectors on the radio. If you can't fix it that way, pull it and send it to Erie Aviation. Todd Smith 3S Who has rewired his becker 3 time this year, before I got it right. wrote: I have a Becker 3201 radio in my glider that has a problem. With a fully charged 14 V system I find that when I push the PTT switch the display starts to blink and the radio then transmits a garbled buzzing noise. A friend thinks that the flashing is a low power signal and that the 24 year old wiring may be offering enough resistance to cause a voltage drop. The radio receives just fine. Anyone know or heard of this problem (and the fix) in the past? TIA Mike KV |
Careful probing those pins on the DB-15. It is extraordinarily
difficult to probe the pins without shorting them. A good alternative is to get the matching connector (male or female), plug it in, and probe the connections on the back of the connector. Much easier to probe that way. Larry Test the disconnect the radio and test the voltage on the DB-15 connector. Pins 4 and 5 are +, pins 2 and 3 are ground. Test those with a multimeter for voltage at the radio. The fix if that's bad is to rewire the radio power leads. You might just need to clean the connectors on the radio. If you can't fix it that way, pull it and send it to Erie Aviation. Todd Smith 3S Who has rewired his becker 3 time this year, before I got it right. wrote: I have a Becker 3201 radio in my glider that has a problem. With a fully charged 14 V system I find that when I push the PTT switch the display starts to blink and the radio then transmits a garbled buzzing noise. A friend thinks that the flashing is a low power signal and that the 24 year old wiring may be offering enough resistance to cause a voltage drop. The radio receives just fine. Anyone know or heard of this problem (and the fix) in the past? TIA Mike KV |
Hi
Just to check voltage at the connector is not good enough if there is a week battery or a poor connection somewhere. It will show the 12v so you need to put a load on the system get a true reading. Ken (KP) |
toad wrote:
Mike, A blinking display is the signal for low voltage (10.5-11) and it would show up first during transmit. I am not so sure about the buzzing sound though. Squealing or buzzing is a very common problem with low battery voltage on transmit. Test the disconnect the radio and test the voltage on the DB-15 connector. Pins 4 and 5 are +, pins 2 and 3 are ground. Test those with a multimeter for voltage at the radio. The fix if that's bad is to rewire the radio power leads. You might just need to clean the connectors on the radio. Could be bad wiring or dirty connectors, but a more likely problem is just a trashed battery that won't hold a charge. Before trying to measure the voltage at the radio, I'd test the voltage at the battery to see if it's good. And yes, it does need to be measured while trying to transmit in order to give real results. -Dave If you can't fix it that way, pull it and send it to Erie Aviation. Todd Smith 3S Who has rewired his becker 3 time this year, before I got it right. wrote: I have a Becker 3201 radio in my glider that has a problem. With a fully charged 14 V system I find that when I push the PTT switch the display starts to blink and the radio then transmits a garbled buzzing noise. A friend thinks that the flashing is a low power signal and that the 24 year old wiring may be offering enough resistance to cause a voltage drop. The radio receives just fine. Anyone know or heard of this problem (and the fix) in the past? TIA Mike KV |
Some years ago I had a similar problem...It's not related to the glider
battery. Inside the box, on a electronic circuit there is a small "pill" battery dedicated for the memory. After several years of use, this small battery was leaking and corroded the close area on the Printed circuit board inside the radio unit. Of course, false contacts did occur and after a while the LCD display was no more working, and the radio was no more emitting. I strongly recommend to bring your radio to a certified shop for renewing the battery and cleaning the circuit if found necessary. Best regards, |
| Thread Tools | |
| Display Modes | |
| Becker radio repair | [email protected] | Soaring | 7 | March 10th 10 04:14 PM |
| Mooney Engine Problems in Flight | Paul Smedshammer | Piloting | 45 | December 18th 04 10:40 AM |
| Becker Radio battery | John Giddy | Soaring | 3 | October 20th 04 08:52 PM |
| Becker 4201 multiple failures | Jean | Soaring | 0 | August 9th 04 09:43 AM |
| Microair vs Becker | Ian McPhee | Soaring | 0 | August 30th 03 10:45 PM |
