Looking at sailplanes. Is a 15m LS6 really any better
than a 15m LS3? Both are flapped and have 40:1 glide slopes. In fact why does the LS6 have a better handicap than say a Discus, when the Discus is 2 points better in the glide? Is the 15m LS6 any better than an LS3 or Discus?? Thanks Kay |
If you never plan on flying faster than 80 knots or so, then there is
indeed no advantage to the LS6. |
Earlier, Kay Scott wrote:
Looking at sailplanes. Is a 15m LS6 really any better than a 15m LS3? Yes, no doubt about it in my mind. The biggest difference is that the LS6 actually achieves 40:1, while the LS3 just claims it. Of note, the LS3 uses the old FX67 profiles, which are quite sensitive to bugs, rain, dust, and other real-world elements. The LS6, on the other hand, uses FX81-series profiles, which are more conservative but also more robust. The FX81s tend to maintain more laminar flow under real-world conditions, and they also have lower pitching moment and consequently less trim drag. Earlier models LS6 have manual-connect controls and a somewhat hokey aileron damper system retrofitted to combat flutter. Later models have a neat mechanical mass-balance system and auto-connect controls. However, at least one operator complains that later LS6s have more aileron friction than earlier ones. This could be due to the switch from stainless steel to mylar for the lower flaperon seal. Both are flapped and have 40:1 glide slopes. In fact why does the LS6 have a better handicap than say a Discus, when the Discus is 2 points better in the glide? My take on that is that it's because the LS6 flaps allow better profile-to-speed optimization, and that the LS6 has a somewhat thinner wing in T/C. Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
Bob Kuykendall wrote:
Earlier, Kay Scott wrote: Looking at sailplanes. Is a 15m LS6 really any better than a 15m LS3? Yes, no doubt about it in my mind. The biggest difference is that the LS6 actually achieves 40:1, while the LS3 just claims it. I have to disagree with this statement. The LS3 certainly achieves 40:1, my LS3 does and so did the one that Dick Johnson tested: http://ssa.org/Johnson/25-1978-11.pdf The interesting thing is that the LS3a and the LS3/17 didn't seem to be able to achieve the same results. Obviously the LS6 is better than the LS3 up in the very high speed range and the LS6 can be flown over a wider range of wing loadings. Of note, the LS3 uses the old FX67 profiles, which are quite sensitive to bugs, rain, dust, and other real-world elements. The LS6, on the other hand, uses FX81-series profiles, which are more conservative but also more robust. The FX81s tend to maintain more laminar flow under real-world conditions, and they also have lower pitching moment and consequently less trim drag. In practice the LS3 doesn't seem to be as sensitive as other gliders of this era. Is this trim drag as much of an issue for flapped gliders? Earlier models LS6 have manual-connect controls and a somewhat hokey aileron damper system retrofitted to combat flutter. Later models have a neat mechanical mass-balance system and auto-connect controls. However, at least one operator complains that later LS6s have more aileron friction than earlier ones. This could be due to the switch from stainless steel to mylar for the lower flaperon seal. The LS3 autoconnects unlike the later LS3a and LS3/17, which have separate flaps and ailerons. This feature comes at the expense of a ton of mass balance lead on the flaperons. Both are flapped and have 40:1 glide slopes. In fact why does the LS6 have a better handicap than say a Discus, when the Discus is 2 points better in the glide? My take on that is that it's because the LS6 flaps allow better profile-to-speed optimization, and that the LS6 has a somewhat thinner wing in T/C. Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 Greg O'Sullivan |
At 02:06 02 September 2005, Greg O'Sullivan wrote:
Bob Kuykendall wrote: Earlier, Kay Scott wrote: Looking at sailplanes. Is a 15m LS6 really any better than a 15m LS3? Yes, no doubt about it in my mind. The biggest difference is that the LS6 actually achieves 40:1, while the LS3 just claims it. well if the LS6 did only 40:1 I'd be worried!!! More like 44:1 |
As a former LS3 owner, my experience was that a well-prepared '3 was
equivalent to an ASW 20, Ventus 1, or LS6 in both climb and cruise. The operative words are "well prepared." The LS3 uses an older airfoil that is, indeed, more sensitive to bugs, rain, and waviness. Worse, the LS3 wing has a tendency to get flat spots over the spar caps cause by shrinkage. Initially I was able to smooth these out by sanding. Later it was necessary to build up the profile over the spar caps. This eventually stabilizes but I suspect few LS3s have had this shrinkage corrected even if they have been refinished. A few other U.S. owners did the same thing and one or two also profiled the leading edge (the outer wing, especially, was apparently too blunt from the factory), with spectacular results. This is only a problem at high speed, by the way. Climb is unaffected and is excellent. The early LS3s were highly respected for their performance when new. As one poster observed, however, many of the later LS3a types didn't seem to go as well. There was a debate in SOARING magazine, sparked by Dick Johnson's testing, about whether the wing molds had warped as time went on, but I don't know the true story. In any case, the LS3 handles like a dream (as do the LS6 and Discus, by consensus) though it is more pitch sensitive than some if the CG is at the aft limit, which it should be for maximum performance. And it's very strong. Alas, the wings are heavy: about 175 lbs. each for mine (125 at the root, 50 at the tip). So a strong crewperson or a one-person rigging system is helpful, in particular because the wing is trailing edge heavy due to the lead mass balance for the one-piece "flaperon". Chip Bearden |
| Thread Tools | |
| Display Modes | |
| Discus 2b cockpit comfort? | Jeremy Zawodny | Soaring | 11 | January 12th 04 09:03 PM |
| All Czech built Discus grounded | Paul | Soaring | 0 | September 14th 03 03:22 AM |
| 18m Discus | Burt Compton | Soaring | 2 | September 8th 03 11:52 AM |
| Discus Wing question | John Galloway | Soaring | 6 | August 23rd 03 08:52 AM |
