I've been reading the messages about the DG-400 oxygen system with some
interest. In the DG-1000 that I often fly, we have a US oxygen bottle, the AL-647 listed on the Mountain High site: http://www.mhoxygen.com/index.phtml?...product_id=359 The DG-1000 has a factory made oxygen cut out that can accept a bottle up to 5.5 inches in diameter and 29 or 30 inches long. The AL-647 is the only bottle that fits but is only 19" long. There appear to be no other [longer] bottles with a similar diameter that we can get. The problem is that even with a decent fill and the EDS system, two pilots flying at high altitudes (16,000 feet or so) will run out in about 6-7 hours with that tank. Clearly it'd be good to have a bigger bottle. And since bottles, relatively speaking, aren't that expensive, we're wondering if it makes sense to order one from Europe and use it instead. It's be nice not to run out and have to refill every single day. Aside from the lack of a DOT sticker (the FBOs we use never look), are there any other real downsides to this? Has anyone done it? Where might I buy such a bottle or at least get pricing info? Thanks, Jeremy |
Jeremy Zawodny wrote:
I've been reading the messages about the DG-400 oxygen system with some interest. In the DG-1000 that I often fly, we have a US oxygen bottle, the AL-647 listed on the Mountain High site: http://www.mhoxygen.com/index.phtml?...product_id=359 The DG-1000 has a factory made oxygen cut out that can accept a bottle up to 5.5 inches in diameter and 29 or 30 inches long. The AL-647 is the only bottle that fits but is only 19" long. There appear to be no other [longer] bottles with a similar diameter that we can get. The problem is that even with a decent fill and the EDS system, two pilots flying at high altitudes (16,000 feet or so) will run out in about 6-7 hours with that tank. That seems a bit quick for an EDS system. It would be worth checking the output pressure of your regulator, which should be 15 psi. If it's higher than that, your consumption will be correspondingly higher. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Eric Greenwell wrote:
Jeremy Zawodny wrote: The problem is that even with a decent fill and the EDS system, two pilots flying at high altitudes (16,000 feet or so) will run out in about 6-7 hours with that tank. That seems a bit quick for an EDS system. It would be worth checking the output pressure of your regulator, which should be 15 psi. If it's higher than that, your consumption will be correspondingly higher. No, it actually matches the charts that EDS publishes. Jeremy |
| Thread Tools | |
| Display Modes | |
| DG-400 Oxygen Bottle Problems | [email protected] | Soaring | 23 | September 8th 05 11:43 PM |
| European 15m and Open championships: 1000 Km task! | Lars Peder Hansen | Soaring | 19 | July 12th 05 01:09 AM |
| What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 08:35 PM |
| Reprise - Oxygen concerns | Neptune | Soaring | 20 | May 27th 04 04:27 PM |
| Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 09:52 PM |
