Help me figure out how much speed my RV can gain by fairing the Pitot Tube.
The pitot is made of 3/8" OD aluminium tube, with a 6" length perpendicular to the airstream. That gives a surface area of 3/8" x 6" = 2 1/4 sq inches. My understanding is that the Cd of a cylinder is .5 and the Cd of a faired shape can be as low as 0.005, but let's assume 0.05 for the faired shape. The effective area is .5 x 2 1/4 square inches = 1.125 square inches for the cylinder. and 0.05 x 2 1/4 = 0.1125 square inches for the streamlined shape. The difference is 1.125-.1125 = 1.06875 square inches. Let's call it 1 square inch... Assuming I'm in the ballpark so far, how much power can I "save" at 175 mph by streamlining the pitot, which eliminates essentially 1 square inch from the aircraft's effective frontal area? KB |
Kyle Boatright wrote:
Help me figure out how much speed my RV can gain by fairing the Pitot Tube. The pitot is made of 3/8" OD aluminium tube, with a 6" length perpendicular to the airstream. That gives a surface area of 3/8" x 6" = 2 1/4 sq inches. My understanding is that the Cd of a cylinder is .5 and the Cd of a faired shape can be as low as 0.005, but let's assume 0.05 for the faired shape. The effective area is .5 x 2 1/4 square inches = 1.125 square inches for the cylinder. and 0.05 x 2 1/4 = 0.1125 square inches for the streamlined shape. The difference is 1.125-.1125 = 1.06875 square inches. Let's call it 1 square inch... Assuming I'm in the ballpark so far, how much power can I "save" at 175 mph by streamlining the pitot, which eliminates essentially 1 square inch from the aircraft's effective frontal area? KB Kyle, any answer you get will be further complicated by the modifications in intersection drag. But ignoring that... From http://142.26.194.131/aerodynamics1/Drag/Page4.html , the equation for parasitic drag is: Dp = CDp x S x ½ r V^2 Essentially, once you remove the drag of the unfair pitot tube, and then accellerate, Dp will come out the same. You're using the all the horses the engine has to make the plane go faster, vs dragging a pitot tube around. So: CDp x S1 x ½ r V1^2 = Dp = CDp x S2 x ½ r V2^2 I only marked S and V with ones and two's, because everything else will drop out of the equation (making a BIG and unlikely assumption that the drag coefficient doesn't change), leaving: S1xV1^2 = S2xV2^2 But the useful form of this for your purposes is: V2^2 = S1 x V1^2 / S2 Now, your fairing the pitot is only one part of the entire airplane, and the entire airplance has to be considered to determine the increase in speed. I have no clue what the surface area of an RV of any sort is (but a Delta is 183ft^2 8*) Assuming your RV has the surface area of a C-172, 174ft^2, you've just dropped 0.007ft^2. Plugging the numbers: V2^2 = 174 x 175^2 / 173.993 V2^2 = 30,626 V2 = 175.00352 Are we ready for Reno yet 8*) You'd probably double this increase by cleaning up the intersection drag. If the tube is located in a position that will cause it to produce rough air for everything behind it, there would also be some (insignificant) benefit to be gained there. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
"Ernest Christley" wrote in message om... Kyle Boatright wrote: Help me figure out how much speed my RV can gain by fairing the Pitot Tube. The pitot is made of 3/8" OD aluminium tube, with a 6" length perpendicular to the airstream. That gives a surface area of 3/8" x 6" = 2 1/4 sq inches. My understanding is that the Cd of a cylinder is .5 and the Cd of a faired shape can be as low as 0.005, but let's assume 0.05 for the faired shape. The effective area is .5 x 2 1/4 square inches = 1.125 square inches for the cylinder. and 0.05 x 2 1/4 = 0.1125 square inches for the streamlined shape. The difference is 1.125-.1125 = 1.06875 square inches. Let's call it 1 square inch... Assuming I'm in the ballpark so far, how much power can I "save" at 175 mph by streamlining the pitot, which eliminates essentially 1 square inch from the aircraft's effective frontal area? KB Kyle, any answer you get will be further complicated by the modifications in intersection drag. But ignoring that... From http://142.26.194.131/aerodynamics1/Drag/Page4.html , the equation for parasitic drag is: Dp = CDp x S x ½ r V^2 Essentially, once you remove the drag of the unfair pitot tube, and then accellerate, Dp will come out the same. You're using the all the horses the engine has to make the plane go faster, vs dragging a pitot tube around. So: CDp x S1 x ½ r V1^2 = Dp = CDp x S2 x ½ r V2^2 I only marked S and V with ones and two's, because everything else will drop out of the equation (making a BIG and unlikely assumption that the drag coefficient doesn't change), leaving: S1xV1^2 = S2xV2^2 But the useful form of this for your purposes is: V2^2 = S1 x V1^2 / S2 Now, your fairing the pitot is only one part of the entire airplane, and the entire airplance has to be considered to determine the increase in speed. I have no clue what the surface area of an RV of any sort is (but a Delta is 183ft^2 8*) Assuming your RV has the surface area of a C-172, 174ft^2, you've just dropped 0.007ft^2. Plugging the numbers: V2^2 = 174 x 175^2 / 173.993 V2^2 = 30,626 V2 = 175.00352 Are we ready for Reno yet 8*) You'd probably double this increase by cleaning up the intersection drag. If the tube is located in a position that will cause it to produce rough air for everything behind it, there would also be some (insignificant) benefit to be gained there. Fortunately (unfortunately?) the pitot tube is probably the easiest "big" thing on the airframe I can streamline without hacking up the cowl to reduce cooling drag or taking some other *extreme* measure. I had considered fairing the pitot, the two fuel vents, the two fuel strainers, and the 4 aileron brackets that protrude into the airstream. My guess is that all of these items together only amount to maybe 3 to 5 times the drag of the pitot tube. Bottom line, if the combination of our math skills is correct, I'm lookin' at less than a 1/2 mph improvement? If that's the case, I've got MUCH better ways to spend my time. ;-) As to your assumptions, I'd guess the RV has half the surface area of a C-172. A couple of sources indicate the RV's flat plate area is ~2.3ft^2. KB |
Eanest:
How about a related question? On my Helio Courier the fusilage/wing intersection is slightly less than 90deg. The intersection looks like an aerodynamic disaster. How much drag would be eliminated with a fairing than can only come down the fusilage three inches? How about a two part fairing (one part would be on the door) that could come down 6 inches? Mike "Ernest Christley" wrote in message om... Kyle Boatright wrote: Help me figure out how much speed my RV can gain by fairing the Pitot Tube. The pitot is made of 3/8" OD aluminium tube, with a 6" length perpendicular to the airstream. That gives a surface area of 3/8" x 6" = 2 1/4 sq inches. My understanding is that the Cd of a cylinder is .5 and the Cd of a faired shape can be as low as 0.005, but let's assume 0.05 for the faired shape. The effective area is .5 x 2 1/4 square inches = 1.125 square inches for the cylinder. and 0.05 x 2 1/4 = 0.1125 square inches for the streamlined shape. The difference is 1.125-.1125 = 1.06875 square inches. Let's call it 1 square inch... Assuming I'm in the ballpark so far, how much power can I "save" at 175 mph by streamlining the pitot, which eliminates essentially 1 square inch from the aircraft's effective frontal area? KB Kyle, any answer you get will be further complicated by the modifications in intersection drag. But ignoring that... From http://142.26.194.131/aerodynamics1/Drag/Page4.html , the equation for parasitic drag is: Dp = CDp x S x ½ r V^2 Essentially, once you remove the drag of the unfair pitot tube, and then accellerate, Dp will come out the same. You're using the all the horses the engine has to make the plane go faster, vs dragging a pitot tube around. So: CDp x S1 x ½ r V1^2 = Dp = CDp x S2 x ½ r V2^2 I only marked S and V with ones and two's, because everything else will drop out of the equation (making a BIG and unlikely assumption that the drag coefficient doesn't change), leaving: S1xV1^2 = S2xV2^2 But the useful form of this for your purposes is: V2^2 = S1 x V1^2 / S2 Now, your fairing the pitot is only one part of the entire airplane, and the entire airplance has to be considered to determine the increase in speed. I have no clue what the surface area of an RV of any sort is (but a Delta is 183ft^2 8*) Assuming your RV has the surface area of a C-172, 174ft^2, you've just dropped 0.007ft^2. Plugging the numbers: V2^2 = 174 x 175^2 / 173.993 V2^2 = 30,626 V2 = 175.00352 Are we ready for Reno yet 8*) You'd probably double this increase by cleaning up the intersection drag. If the tube is located in a position that will cause it to produce rough air for everything behind it, there would also be some (insignificant) benefit to be gained there. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Mike Rapoport wrote:
Eanest: How about a related question? On my Helio Courier the fusilage/wing intersection is slightly less than 90deg. The intersection looks like an aerodynamic disaster. How much drag would be eliminated with a fairing than can only come down the fusilage three inches? How about a two part fairing (one part would be on the door) that could come down 6 inches? Mike, I think you are mistaking me for someone who knows what they are talking about. Seriously, though, I read a NACA report from the LARC site a while back describing an experiment with fairings on a high wing aircraft. I can't remember all the particulars, and a quick search just now proved fruitless, but I remember that they realized significant speed gains with increased fairing sizes. In my *opinion*, the more fairing you can get the better. Consider the right wing. The problem with intersection drag is that you have the air being compressed both from the left off of the fuselage and up from the wing. Down there in the corner, the poor air doesn't know which way to go. So like FEMA or a southern city mayor, it chooses to spin around in circles. We call these vortices, and they eat up a lot of energy without producing anything. A fairing, even a small one, will help direct the air, and stop the spinning, at least partly. Tell you what, Mike, why don't you try and experiment? Roll up a few sheets of newspaper for filler, and temporarily duct tape in a 3" fairing. Fly the plane and measure the before and after speeds. It would make a nice Sport Aviation article. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Thanks. I will try the experiment this winter (or at least I intend to try
it ). In addition to the Helio, I have a MU-2 which has large radius fairings between the wing and fusilage. On the right side of the Helio there is plenty of room for the fairing to come down the side of the fusilage before it reaches the window but on the left side the door restricts the fairing size. It is surprising to me that Helio left the area unfaired. Mike "Ernest Christley" wrote in message om... Mike Rapoport wrote: Eanest: How about a related question? On my Helio Courier the fusilage/wing intersection is slightly less than 90deg. The intersection looks like an aerodynamic disaster. How much drag would be eliminated with a fairing than can only come down the fusilage three inches? How about a two part fairing (one part would be on the door) that could come down 6 inches? Mike, I think you are mistaking me for someone who knows what they are talking about. Seriously, though, I read a NACA report from the LARC site a while back describing an experiment with fairings on a high wing aircraft. I can't remember all the particulars, and a quick search just now proved fruitless, but I remember that they realized significant speed gains with increased fairing sizes. In my *opinion*, the more fairing you can get the better. Consider the right wing. The problem with intersection drag is that you have the air being compressed both from the left off of the fuselage and up from the wing. Down there in the corner, the poor air doesn't know which way to go. So like FEMA or a southern city mayor, it chooses to spin around in circles. We call these vortices, and they eat up a lot of energy without producing anything. A fairing, even a small one, will help direct the air, and stop the spinning, at least partly. Tell you what, Mike, why don't you try and experiment? Roll up a few sheets of newspaper for filler, and temporarily duct tape in a 3" fairing. Fly the plane and measure the before and after speeds. It would make a nice Sport Aviation article. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
| Thread Tools | |
| Display Modes | |
| max altitude and Mach 1 | Boomer | Military Aviation | 22 | June 1st 04 09:04 PM |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| Source of Induced Drag | Ken Kochanski | Soaring | 2 | January 10th 04 01:18 AM |
| Forward CG Experience | Jay Honeck | Piloting | 41 | November 19th 03 03:54 PM |
| Did we decide if ballasted pullups are higher???????? | Lars Peder Hansen | Soaring | 22 | October 8th 03 01:45 AM |
