Say my aircraft is in a current orientation of
phi (roll, x-axis) = 0 degrees theta (pitch, y-axis) = 30 degrees psi (yaw, z-axis) = 20 degrees which corresponds to a quaternion Q = 0.952 + 0.045i + 0.255j + 0.168k But my desired orientation is phi = 0 degrees theta = 0 degrees psi = 0 degrees -OR- Q = 1 + 0i + 0j + 0k If I am thinking in terms of Euler notation, then I know there is a pitch error of 30 degrees and need to deflect the elevator to correct this. Likewise, the 20 degree yaw error must be countered by rudder deflection. However, if I'm thinking in terms of quaternions, then how can I go about this? Thanks in advance, weg |
I think you better post this one to sci.aeronautics
it has more engineers that this one. wrote in message oups.com... Say my aircraft is in a current orientation of phi (roll, x-axis) = 0 degrees theta (pitch, y-axis) = 30 degrees psi (yaw, z-axis) = 20 degrees which corresponds to a quaternion Q = 0.952 + 0.045i + 0.255j + 0.168k But my desired orientation is phi = 0 degrees theta = 0 degrees psi = 0 degrees -OR- Q = 1 + 0i + 0j + 0k If I am thinking in terms of Euler notation, then I know there is a pitch error of 30 degrees and need to deflect the elevator to correct this. Likewise, the 20 degree yaw error must be countered by rudder deflection. However, if I'm thinking in terms of quaternions, then how can I go about this? Thanks in advance, weg |
| Thread Tools | |
| Display Modes | |
| Simple Green Pirep | JJS | Owning | 13 | May 19th 05 04:35 AM |
| millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 6th 04 12:14 AM |
| Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 04:07 PM |
| A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 06:07 AM |
| Phoenix AIM-54A (QUESTION) | Krztalizer | Naval Aviation | 10 | February 23rd 04 08:22 AM |
