I have an need to disable one side of a dual magneto for my project.
Essentially I am installing a Electroair system to fire one set of plugs and retaining the magneto to fire the second. My initial plan was to find a single mag to replace the dual but apparently the nature of the gearing that drives this Dual Magneto makes it impossible to replace it with a single mag. Therefore I will only be using one side of the Dual Magneto. I'm wondering the BEST way to neutralize the non-used side of the magneto. I could: #1 simply ground the P-Lead Is there any reason this is a Bad idea? #2 Remove one coil and/or set of points and/or distributer gear - will removing the coil leave the mag "Unbalanced" in any manner, Magnetically Physically or otherwise? I know that having a magnet and coil means that I am creating electrons, I am just wondering the best way to neutralize them? Thanks in advance doug |
Doug,
If you have an 0-360 A1F6D (dual mag lycoming) you can run one mag in the dual mag hole.It can be done very easily.....although it will be a bit pricey. You will need to buy one single mag and the appropriate gears. Contact Aero-Sport power and they have all the info for what you need. They will also take your dual mag housing as a core and give you a pretty good price for it. It makes a very clean installation. Dave Mader Sheridan, Wyo. Doug Palmer wrote: I have an need to disable one side of a dual magneto for my project. Essentially I am installing a Electroair system to fire one set of plugs and retaining the magneto to fire the second. My initial plan was to find a single mag to replace the dual but apparently the nature of the gearing that drives this Dual Magneto makes it impossible to replace it with a single mag. Therefore I will only be using one side of the Dual Magneto. I'm wondering the BEST way to neutralize the non-used side of the magneto. I could: #1 simply ground the P-Lead Is there any reason this is a Bad idea? #2 Remove one coil and/or set of points and/or distributer gear - will removing the coil leave the mag "Unbalanced" in any manner, Magnetically Physically or otherwise? I know that having a magnet and coil means that I am creating electrons, I am just wondering the best way to neutralize them? Thanks in advance doug |
The Dual is for a Continental Tiara Six Cylinder. The drive turns at 3/4X
Crankshaft speed where as most six cylinder engines turn at 1.5X Crankshaft speed, They compensated for this by having four magnets on the Magneto armature instead of two. I've researched it pretty thoroughly, there is no single that will fit so I need to negate one side of the dual. Thanks, Doug wrote in message oups.com... Doug, If you have an 0-360 A1F6D (dual mag lycoming) you can run one mag in the dual mag hole.It can be done very easily.....although it will be a bit pricey. You will need to buy one single mag and the appropriate gears. Contact Aero-Sport power and they have all the info for what you need. They will also take your dual mag housing as a core and give you a pretty good price for it. It makes a very clean installation. Dave Mader Sheridan, Wyo. Doug Palmer wrote: I have an need to disable one side of a dual magneto for my project. Essentially I am installing a Electroair system to fire one set of plugs and retaining the magneto to fire the second. My initial plan was to find a single mag to replace the dual but apparently the nature of the gearing that drives this Dual Magneto makes it impossible to replace it with a single mag. Therefore I will only be using one side of the Dual Magneto. I'm wondering the BEST way to neutralize the non-used side of the magneto. I could: #1 simply ground the P-Lead Is there any reason this is a Bad idea? #2 Remove one coil and/or set of points and/or distributer gear - will removing the coil leave the mag "Unbalanced" in any manner, Magnetically Physically or otherwise? I know that having a magnet and coil means that I am creating electrons, I am just wondering the best way to neutralize them? Thanks in advance doug |
"Doug Palmer" wrote I know that having a magnet and coil means that I am creating electrons, I am just wondering the best way to neutralize them? If you don't have a complete circuit, you can't make electrons. So, in short, just take out any part of the system so that the electrons can't flow. My choice would be the points. If you don't have points to make and break, you will not have a collapsing magnetic field trying to make a big spark. -- Jim in NC |
| Thread Tools | |
| Display Modes | |
| Bendix Magneto Question | Dick Kurtz | Owning | 0 | September 22nd 05 04:36 AM |
| Prop Pitch Question | Eugene Wendland | Home Built | 2 | April 25th 04 04:22 AM |
| Question | Charles S | Home Built | 4 | April 5th 04 10:10 PM |
| Partnership Question | Harry Gordon | Owning | 4 | August 17th 03 12:23 AM |
| Ellery Queen and the Case of the Missing Magneto Gear Teeth | MikeremlaP | Owning | 3 | July 26th 03 04:01 AM |
