360 HP Electric Extra Sets Climb Record
Old December 9th 16, 10:08 PM posted to rec.aviation.piloting
Larry Dighera
Default 360 HP Electric Extra Sets Climb Record
http://www.avweb.com/avwebflash/news...-228172-1.html
AVweb Staff | December 7, 2016
Famed aerobatic pilot and aircraft designer Walter Extra has set a new FAI
record for time to climb in an electric airplane. According to Extra and
Siemens, the manufacturer of the motor used in the Extra 330LE, the climb was
4:22 to an altitude of 3000 meters (9842 feet). That's an average climb rate of
about 2300 feet per minute. The record is a new C1b class for light landplanes
but it doesn't exceed time to climb performance for piston airplanes in other
classes. The record applies to powered electric aircraft with a takeoff weight
of 500 to 1000 kg.
The Extra 330LE first appeared last spring at the Aero show in Friedrichshafen,
Germany. As part of its regular show coverage of Aero, AVweb prepared this
video report
http://www.avweb.com/videos/Video-Siemens-Electric-Extra-330-Aircraft-226133-1.html.
The 330LE was developed by a consortium of companies including Extra, Siemens,
MT Propeller and Pipistrel. The motor is a 350-HP brushless DC design that
weights only 110 pounds. You can learn about the details in this AVweb video
http://www.avweb.com/videos/How-Aircraft-Electric-Motors-Work-226315-1.html.
The flight took place on Nov. 25 at Dinslaken, Germany. Siemen's Frank Anton,
head of eAircraft at the company, said, “This is the first time that an
electric aircraft in the quarter-megawatt performance class has flown.” He said
the new system means that hybrid-electric aircraft with four or more seats will
now be possible. However, battery development still lags and this is seen as an
essential requirement for practical aircraft, including hybrids.
Video: Siemens' Electric Extra 330 Aircraft Larry Dighera Piloting 2 April 28th 16 09:42 PM
Siemens' 110 lb world-record electric aircraft motor produce 348 hp at 2,500 RPM Larry Dighera Piloting 29 December 2nd 15 08:29 PM
electric speed record (141kts) with a cricri Philippe[_4_] Home Built 0 September 13th 10 07:31 AM
