Transponder
Old October 17th 05, 02:29 AM
Tom Cummings
Default Transponder
My King KT-76A transponder has a stuck "Ident" button.
It stuck when activated for ATC on the last flight and the button appears to
have colapsed sideways underneath the cover panel. It is no longer visible
in the opening now. ATC says the unit indicates an "Indent" signal
presently.
Does this require an avionics shop to repair or could it be a simple matter
such as removing the unit, then remove the cover plate and look for a
colapsed return spring?
Tom
Old October 17th 05, 03:17 AM
Default Transponder
presently.
Tom
When I read a message like this it scares me to think you're sharing IFR
airspace. Hopefully, it's in not in conjested airspace.
Old October 17th 05, 05:58 AM
Jimmy
Default Transponder
to
presently.
matter
Tom
If you have any skills with a phillips head screw driver, yank it out and
try to fix it yourself.
Old October 17th 05, 06:29 AM
Ray
Default Transponder
I don't see why it should be a big deal. ATC has the capability to
receive multiple idents simultaneously. I would imagine most
controllers can deal with this kind of problem without skipping a beat -
even if you're VFR and not in contact with ATC.
- Ray
Old October 17th 05, 11:47 AM
Dale Scroggins
Default Transponder
to
presently.
matter
Tom
Opening the case (by removing the faceplate) generally can only be done
legally by an appropriately rated repair station. From the OP's
description, he may have some damaged parts. Taking the front end of
some transponders apart can be pretty involved.
But, what the heck. The OP may not get caught. And he may not break
anything. And he may find the part he needs from some scrap
transponder. Rules and regulations only need be followed if it's not
too much expense or trouble, right?
Old October 17th 05, 02:20 PM
Michelle P
Default Transponder
Anybody can legally disassemble anything aviation that they like. It is
the assembly that requires a license or certification.
Michelle (A&P, ATP)
appears
to
visible
presently.
matter
Tom
and
done legally by an appropriately rated repair station. From the OP's
Old October 17th 05, 03:26 PM
Default Transponder
That seems to sum it up. Scrimp/cheat on the maintenance so you can affor $4.00
fuel.
Old October 17th 05, 03:28 PM
Default Transponder
Michelle (A&P, ATP)
I presume that is tongue-in-cheek. If I were to tear down an engine without
you being around wouldn't your certification of the reassembly require a
whole lot more work to do it correctly?
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
Operation without a transponder flyer Piloting 11 September 14th 04 09:48 AM
Transponder test after static system opened? Jack I Owning 6 March 14th 04 04:09 PM
Transponder petition Ian Cant Soaring 11 February 28th 04 07:38 AM
More on transponder petition Ian Cant Soaring 1 February 27th 04 07:37 PM
