Hi all,
I just installed a GEM-610 in my airplane and it works great. Is there a way to download/configure the unit without the suggested HP 200LX handheld computer? I've tried a Toshiba laptop with no luck. Any suggestions? Thanks Dave |
Javier Henderson wrote: wrote: Hi all, I just installed a GEM-610 in my airplane and it works great. Is there a way to download/configure the unit without the suggested HP 200LX handheld computer? I've tried a Toshiba laptop with no luck. You need to make sure that the irDA port on your laptop is set to be COM1, then the program you can download from Insight's website will work. -jav jav, I have Win 95 loaded. Just open a dos window and run the exe? Thanks |
Tauno Voipio wrote: wrote: Javier Henderson wrote: wrote: Hi all, I just installed a GEM-610 in my airplane and it works great. Is there a way to download/configure the unit without the suggested HP 200LX handheld computer? I've tried a Toshiba laptop with no luck. You need to make sure that the irDA port on your laptop is set to be COM1, then the program you can download from Insight's website will work. -jav jav, I have Win 95 loaded. Just open a dos window and run the exe? Yout Windows is too old for IrDA. Are you sure that there is a suitable port in the computer (too old)? I located a driver for the laptop (WIN 95) and it has a IRDA port. Maybe i'll try Kermit as Kyler suggested. i'll try to set it up as com1. Wonder if it will do basic "at" commands? Thanks Dave |
Javier Henderson wrote: wrote: Hi all, I just installed a GEM-610 in my airplane and it works great. Is there a way to download/configure the unit without the suggested HP 200LX handheld computer? I've tried a Toshiba laptop with no luck. You need to make sure that the irDA port on your laptop is set to be COM1, then the program you can download from Insight's website will work. -jav jav, I have Win 95 loaded. Just open a dos window and run the exe? Yep, and again, make sure the irDA port on your laptop is set to be COM1. -jav |
Javier Henderson wrote: wrote: Javier Henderson wrote: wrote: Hi all, I just installed a GEM-610 in my airplane and it works great. Is there a way to download/configure the unit without the suggested HP 200LX handheld computer? I've tried a Toshiba laptop with no luck. You need to make sure that the irDA port on your laptop is set to be COM1, then the program you can download from Insight's website will work. -jav jav, I have Win 95 loaded. Just open a dos window and run the exe? Yep, and again, make sure the irDA port on your laptop is set to be COM1. -jav Haven't figured out how to reallocate comports in win95. Com 1 is pointing to the serial port and com 3 is the irDA. If anybody can tell me how to change the comport assignments that would be great, if not i'll go down to Fry's and pickup a serial to IR adapter. That should make it work. Thanks again dave |
| Thread Tools | |
| Display Modes | |
| A-7 Corsair Info needed | [email protected] | Naval Aviation | 0 | January 25th 05 09:48 AM |
| HA-6 Carburetor Info needed | Stu & Kathy Fields | Home Built | 0 | May 13th 04 07:05 PM |
| Web site info needed | dave | Home Built | 1 | December 3rd 03 05:12 AM |
| Groom Lake/area 51 Migs from 70s info needed | Aerophotos | Military Aviation | 23 | September 13th 03 06:16 PM |
| RB-47H info needed for model | Matt Wiser | Military Aviation | 0 | August 3rd 03 04:54 AM |
