Runway Numbering - Radio Procedure
Old October 20th 05, 05:59 PM
Daniel L. Lieberman
Default Runway Numbering - Radio Procedure
If one announces "Runway Two Zero" but the "Zero" is cutoff the listener
thinks "Runway Two". Announcing "Runway "Zero Two" prevents this
possibility.
Obviously this problem only occurs with a limited number of runway
alignments.
The "Runway Zero Two" for someone speaking at 120 words per minute occupies
1/2 second more than "Runway Two."
Old October 20th 05, 06:22 PM
Jim Burns
We've got Rwy 03/21 and 30/12 at STE. I always say Zero Three when using
that runway for exactly the reason you indicate.
"Daniel L. Lieberman" wrote in message
m...
possibility.
alignments.
occupies
Old October 20th 05, 06:31 PM
Steven P. McNicoll
"Jim Burns" wrote in message
No, you've got Rwy 3/21 and 30/12 at STE.
Old October 20th 05, 08:27 PM
BTIZ
what is the problem of thinking rwy two or rwy zero-two are they not the
same runway?
BT
m...
possibility.
alignments.
occupies 1/2 second more than "Runway Two."
Old October 20th 05, 08:34 PM
Lakeview Bill
No, because there are no runways named "zero-two" in the US...
"BTIZ" wrote in message
news:VjR5f.13018$MN6.12287@fed1read04...
same runway?
BT
m...
possibility.
alignments.
Old October 20th 05, 10:55 PM
John T
listener thinks "Runway Two". Announcing "Runway "Zero Two" prevents
this possibility.
....but it introduces the possibility of the listener hearing "runway zero".
How is that any better?
It's best to use the numbers painted on the runway.
John T
http://tknowlogy.com/TknoFlyer
http://www.pocketgear.com/products_s...veloperid=4415
Reduce spam. Use Sender Policy Framework: http://spf.pobox.com
____________________
Old October 21st 05, 12:37 AM
Mike W.
If you hear 'runway zero', then you know you have missed something in the
transmission.
"John T" wrote in message
m...
this possibility.
zero".
John T
Old October 21st 05, 03:51 AM
John T
"Mike W." wrote in message
the transmission.
Similarly, if you're in the pattern for runway 20 and you hear somebody
announce "[your airport] traffic, N123 base, runway 2[garbled]", you can
assume you've missed something. You still haven't made a case for using
anything but the numbers painted on the runway.
John T
Old October 21st 05, 04:03 AM
Icebound
m...
the transmission.
Well, yes, the case is easy to make.
If everybody used the leading zero all the time, then you KNOW FOR SURE
anytime you hear less than two digits, then you have missed something.
If the leading zero is NOT used and you hear only ONE digit, then you have
no way of knowing whether you missed something, or not.
Shortening a direction-based entity in this way is unnatural and causes
confusion. Even the FAA's own NACO chart-selection web site, uses the
leading zeros in the index, and then omits them on the charts..
Old October 23rd 05, 03:03 PM
Steven P. McNicoll
"Icebound" wrote in message
How do I know the digits haven't been transposed? If I hear, "Podunk
traffic, Waco niner eight zero one victor, entering downwind runway zero
two, stop-and-go, Podunk", how do I know the pilot didn't mean to say,
"Podunk traffic, Waco niner eight zero one victor, entering downwind runway
two zero, stop-and-go, Podunk." Podunk does have a runway two zero, but it
has no runway designated zero two.
What might I have missed if I hear,"Podunk traffic, Waco niner eight zero
one victor, entering downwind runway two, stop-and-go, Podunk."
That may be only a software requirement.
"Cleared Straight-In Runway X; Report Y Miles Final" Jim Cummiskey Piloting 86 August 16th 04 07:23 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 06:40 PM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 04:27 AM
F15E's trounced by Eurofighters John Cook Military Aviation 193 April 11th 04 04:33 AM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 04:30 AM
