Rotax 912 Preheaters
Old November 4th 05, 06:19 PM
Willard
Default Rotax 912 Preheaters
I have a SLSA on order which uses a Rotax 912 engine. The owner's
manual for this aircraft specifies that the engine should be preheated
when the temp falls below 41 degrees F. I see that both Tanis and
Reiff have engine-intalled preheaters available for the 912. Anyone
have any experience with any preheater installed on a 912?
Old November 5th 05, 03:15 PM
Ron Lee
I have a Reiff oil sump heater on my RV-6A O-360. I would assume that
an engine is an engine so as long as the Reiff system fits it would
perform as well on your Rotax 912 as it does on my engine. I use a
timer rated for this application that turns on about five hours before
I fly. I am in an insulated and heated (to 40 deg F) hangar and the
oil temp is around 90 deg F when I start up.
Ron Lee
Old November 13th 05, 01:02 AM
Willard
Ron Lee
Thanks Ron,
After a couple of e-mail exchanges with Bob Reiff I decided the Reiff
heater should be adequate. What I like about this unit is that it
includes a heater for the oil tank (which, of course, "wet sump"
engines don't have). I couldn't get the guy from Tanis to say exactly
what their preheater includes, and it's a lot more expensive. They do,
however, heat the cylinder heads thru bolt heaters. The preponderance
of the opinions I have read is that this is not important. The Rotax
engine manual says only that you have to heat the oil if the engine is
hard to start.
Willard
Light weight low cost four stroke engines, good Rotax replacements. Bushleague Piloting 1 October 13th 05 05:49 AM
Engine sound of Rotax 912 JK Home Built 12 May 22nd 05 03:47 PM
Rotax 582 Firewall Forward Package For Sale Bushmaster Guy Home Built 0 November 22nd 04 07:33 AM
Questions Rotax Engines Mark Smith Home Built 2 August 14th 04 12:01 AM
RV-9A's wing with Rotax 914? Shin Gou Home Built 26 March 7th 04 09:56 PM
