GPS mounting bracket
Old November 5th 05, 07:55 PM
Michael Ware
Default GPS mounting bracket
I have a Garmin 296 GPS. In the Skylane that I fly, the mic/phone jacks are
on the panel, directly below where the control yoke shaft goes through. The
the clamp part yoke mount protrudes about 3" below the shaft when clamped
on, so when my phones are plugged in...no good. So for now I am clamping it
on the top lip of the panel, but that partially blocks my view of the
temp/fuel/pressure guages over there.
Any suggestions? There is a blank below the radio stack that would hold one
of those $100 panel mounts, but since it is the club's plane, not mine, I
can't go that route.
Hello, my name is Mike, and I am an airplane addict...
Old November 5th 05, 10:22 PM
Dan Luke
http://tinyurl.com/7h3th
Old November 6th 05, 12:02 AM
john smith
Yep, I switched to the suction cup mount two years ago.
I mount it on the left side of the windscreen. Keeps it out of the way
of the instruments.
Old November 6th 05, 12:30 AM
You might consider replacing the plugs on your headset with the right
angle variety (assuming that you can find some - these used to be
available, but I don't know if they still are). OTOH, I never cared
for yoke mounts. Perhaps the swivel suction cup mount suggested by
others in this thread would work best in your case.
David Johnson
Cherokee alternator bracket replacement [email protected] Owning 7 September 2nd 05 09:53 PM
C150 Wheel Fairing mounting plates Robert Zrim Owning 17 June 16th 05 08:37 AM
Instrument mounting question Rob Turk Home Built 4 July 19th 04 11:33 PM
Skymap IIIC Mounting Options NW_PILOT Owning 15 July 8th 04 02:41 PM
Mounting my GPS Charles Talleyrand Piloting 8 November 19th 03 12:51 PM
