IFR with a VFR GPS
Old November 9th 05, 09:26 PM
Peter R.
Default IFR with a VFR GPS
"Steven P. McNicoll" wrote:
"Peter R." wrote in message
Primary navigation (the VFR GPS) is no longer reliable, the aircraft is
IMC, and the pilot is unaware that the unit is no longer reliable. Those
are not properties of a problem?
I don't think so. If the aircraft drifts off course the controller will
nudge it back and the pilot will then be aware that the unit is no longer
reliable. No problem.
Assuming the aircraft is in controlled airspace. What if it isn't?
Peter
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
Old November 9th 05, 09:27 PM
Peter R.
Sorry, I mean assuming the aircraft is in radar contact.
Peter
Old November 9th 05, 11:15 PM
Steven P. McNicoll
We're not assuming the aircraft is in controlled airspace, we know it is.
That was established in the original message.
Old November 9th 05, 11:24 PM
Steven P. McNicoll
Radar monitoring is required for off-airways routes beyond navaid
altitude/distance limits. So if not in radar contact your route will be via
airways or between navaids within the established limits. You'll know the
VFR GPS is unreliable when it no longer agrees with your more traditional
navigation radios.
Old November 10th 05, 12:22 AM
Peter R.
You'll know the
traditional navigation radios.
Assuming the pilot is continually tuning his traditional navigation radios,
then including those in his instrument scan. And what if he does not?
You asked what the risks of flying IFR with a VFR GPS are. There's one.
Peter
Old November 10th 05, 01:03 AM
Steven P. McNicoll
radios,
Why would he do that?
But I didn't ask what are the risks of flying IFR using a VFR GPS
exclusively.
Old November 10th 05, 01:32 AM
Peter R.
exclusively.
You didn't ask what are the risks of flying IFR using a VFR GPS in concert
with other navigation instruments, either.
Peter
Old November 10th 05, 01:44 AM
Steven P. McNicoll
No, I didn't. I didn't have to, as the the other navigation instruments are
required to be there. The bottom line is you haven't identified any risk
from flying IFR with a VFR GPS.
  #29
Old November 10th 05, 01:49 AM
Peter R.
Are they required to be used?
Yes I did. Just because your newsgroup pride won't let you recognize it
doesn't mean it didn't happen.
Peter
  #30
Old November 10th 05, 01:52 AM
Ron Lee
What happens when these VFR GPS's drop reception of all but one or two
satellites? Do they instantly provide a RAIM message?
I don't know? Is it a problem if they don't?
If the pilot were using the unit for primary navigation in IMC and the unit
did not warn the pilot of too few satellites to be able to calculate
position, would that be a problem?
You should note that if you lose lock (too few satellites) then your
display will start flashing (or portions of it). That is not RAIM
which determines if you have a signal error.
Ron Lee
