How long to get down question
Old November 22nd 05, 02:06 PM posted to rec.aviation.owning
Default How long to get down question
I was a passenger on a flight from Atlanta to Orlando in a 757.
About half way, at probably FL 310, passengers and crew detected
smoke in the cabin. Spoilers came out full, gear stayed in. We
pitched down and headed for Jacksonville. JAX was probably 40 - 50
miles to the east of our course, but we landed in less than 10 minutes
and were met by the equipment.
The smoke turned out to be coming from a short in the 'crew computer';
the system that kept track of crew duty time.
I'm not sure if we hit 10000 fpm descent, since we also had to cover
about 40- 50 miles laterally, but we were getting down fast!
Mike Pvt/IFR N44979 PA28-181 at KRYY
David Lesher wrote:
An OT query for folks here. While discussing things that can happen
between the jetways, I posited that it's a really bad to be aloft
in Big Iron in a medical emergency, etc. -- based on how long it
takes to get on the ground.
That brings up the question of how long that time really is....
So:
If you are at cruise in Boeing's finest at FL430 & declare an
emergency; how fast CAN you be down and stopped? (Or Airbus, for
that matter....)
Assuming ATC can clear a lane, I assume it's a function of how
steep a decent you can use without exceeding the max IAS. What are
the limits on speed brakes, dropping gear, etc. to dirty things ups?
Do you slow to gear-down speed, drop them, then nose over? Or is
the higher speed possible w/ gearup better?
Old November 22nd 05, 02:14 PM posted to rec.aviation.owning
k.net...
Getting down is not a problem.
MU-2
You're right, hence aviation's perfect record of never leaving one up there.
Old November 23rd 05, 03:13 AM posted to rec.aviation.owning
If I need to get on the ground that fast.. screw the "pattern" and taxi
time.. The descent will be planned to have me on final and "configured" for
landing.. I'll stop on the runway or turn off and shut down.. the trucks can
meet me there... screw "taxi"...
BTDT
BT
"Doug" wrote in message
If you are directly over the airport you can land at, then follow the
emergency decent procedures for that plane (and they differ from plane
to plane) and come down about 2000 fpm (I really don't know, and it
would depend on the plane), but lets use that figure. Then it would
take 21 1/2 minutes to get down and maybe 1 1/2 minutes in the pattern
and 1 minute of taxi, so that is 23 minutes, assuming the airport is at
sealevel. That would be fast.
182RG question Paul Anton Owning 11 May 16th 05 09:45 PM
Question for CFIs Casey Wilson Piloting 11 February 24th 05 10:29 PM
Showstoppers (long, but interesting questions raised) Anonymous Spamless Military Aviation 0 April 21st 04 05:09 AM
Defining Composites (long) B Lacovara Soaring 1 September 13th 03 08:04 PM
