Riddle me this, pilots
Old August 19th 03, 03:21 AM
Ben Jackson
Chip Jones wrote:
In the most professionally bored voice I can muster, I key up and say "Baron
123, traffic alert, traffic two o'clock, two miles converging from the right
indicating 7000, suggest you turn right heading 180 immediately."
Why did it get that far? If I'm the Baron I'm thinking, "I can't see
the traffic, I won't see the traffic in IMC, why is this guy waiting
for me to spot this plane?" If you *believed* that he was really in
the soup, why not just pretend the VFR target was a lost-comms IFR
guy and gotten the Baron out of the way?
Plus if two aircraft are 2 miles apart and you turn one 90 degrees,
by the time the turn is completed they will have both covered a mile.
My mental image of this is that you're turning a situation where the
two course lines would converge to a sharp point into a situation
where they would converge in a nice rounded corner.
Ben Jackson
http://www.ben.com/
Old August 19th 03, 03:23 AM
Robert Henry
"Chip Jones" wrote in message
Given this traffic scenario, would any of you guys have followed my
suggestion to turn to a 180 heading, or was I wasting my breath?
Chip, ZTL
It reminds me of the scene in the Hunt for Red October where Jack Ryan has
to choose between steering the sub into the torpedo or away from the
torpedo. As such, I think the pilot feared a head on; a 70 degree turn is
about a mile in a cruising Baron. The Baron also guessed that he could
descend away from the climbing aircraft as reported - guessing (correctly
fortunately) that the interloper would not descend back out of the weather.
(a 400 ft altitude change following a 6 second turn should be considered
deliberate, imho.)
Based solely upon the vectors you listed, I also think the course he chose
(~20 left) put the aircraft closer to the destination instead of further
away, which may have also been a factor in his decision-making process.
Maybe a left 360 would have done the trick more comfortably for everyone? I
was recently "spun" in VMC about 3 miles from a VOR at 7000 in an SR22 with
no traffic reported -although I presumed that was the problem- which is what
made me think of it. It's puts the plane right back where it started, just
two minutes later.
While we hope never to be faced with an unverified target in IMC, please
make the suggestion that best resolves the conflict from your viewpoint.
Bob
PP-ASEL-IA, A/IGI
Old August 19th 03, 03:34 AM
Steven P. McNicoll
The other day, I had an air traffic situation I wanted to bounce off of
group. Those of you who don't know me, I'm a Center controller down here
in
Atlanta. Here's the deal.
I was working a Center departure sector mixing Atlanta terminal departures
of every ilk and kin with enroute overflight traffic north of metro
Atlanta.
The sector weather was typical summer MVFR down here- lots of convection,
hazy, hot, humid etc with building thunderstorms here and there impacting
the sector. I had received my briefing from the previous controller and
had
just assumed responsibility for the airspace. Part of my technique is to
do
one more quick traffic scan *after* I take over (while the previous
controller is still at hand) to ensure we didn't fumble a situation while
we
changed the guard.
I am working a Baron IFR at 7000 flying from Chattanooga TN to Charleston
SC, on course heading of about 110 or so. Doing my scan, I see he has an
IFR off the nose about 15 miles at 6000 and another IFR guy crossing from
the NE at 8000 and 20 miles, so he is separated. I notice additional
traffic for this guy, a VFR indicating 6600 about six miles south, heading
about 055 or so, converging with him. I ask the previous controller if
she had issued traffic, she said she hadn't.
I made the traffic call.. "Baron 123, VFR traffic one to two o'clock, six
miles, northeast bound converging, altitude indicates six thousand six
hundred." The response I get is "Baron 123 is IMC, no contact."
I make a few unrelated routine calls to other traffic, keeping an eye on
this VFR target. His Mode C indicates that he is in a climb, and the
conflict alert activates (both data blocks begin to flash). I make
another
call at four miles. "Baron 123, your traffic now two o'clock, four miles,
northeast bound, altitude indicating six thousand niner hundred VFR,
converging right to left." The Baron responds "123 is IMC, no contact."
The situation now has my undivided attention.
At three miles converging (next update), the traffic is indicating 7000.
The next update, the traffic is still at 7000. This guy is flying VFR
where
one of my IFR's is IMC. I swing into alert mode. The target slashes are
a
mile long each and the radar display is delayed a bit from actual position
so these guys are getting close and closing fast. The Baron needs to yank
it right most ricky tic and get behind this guy.
"Baron
right
indicating 7000, suggest you turn right heading 180 immediately." The
Baron
pilot says "We're turning left to 090, no contact." I then watch as the
Baron swings into a left turn, prolonging the collision vector another
minute. His left turn away from the traffic puts him wing high with
closing
traffic off the right side. The Baron also descends four hundred feet
during the maneuver as the targets merge. To me, this looks remarkably
like
a TCAS maneuver because of the altitude change. I key up and say "N123,
are
you TCAD equipped, do you have traffic avoidance avionics?" He gives me a
curt "Negative, we do not have the traffic." The targets have merged
thanks
to the left turn, and I cannot distinguish the one from the other.
Anything
I say now about the traffic would be a dangerous guess because I have lost
the flick between these two aircraft. Instead of responding to the Baron,
I
issue a vector to the IFR traffic at 6000 to get him away from Baron 123
(who is now well below assigned IFR altitude). At the next position
update,
I have tail to tail between the baron and the VFR. I tell the Baron,
"Traffic no factor, maintain 7000." He responds "We never saw him..."
[The
unknown SOB in the VFR remains at 7000 for the next fifty miles- his
profile
never changed and I have every reason to believe that he never saw the
IFR,
IMC Baron].
My question for the group is about the Baron pilot's decision to disregard
my suggestion to yank it towards the traffic and instead to turn away from
him. From a controller's perspective, the quickest way to achieve "Oh
Sh*t"
lateral separation with crossing traffic is to aim one airplane right at
other. The idea is that as both aircraft are moving through space, the
maneuvering aircraft is steering for a point where the traffic *used* to
be
but no longer is. Once the nose of the turning aircraft swings through
his
traffic's vector, every additional second buys additional separation.
When
we do this with IFR traffic, we call this a "Wimpy Crossover" or a "Bubba
Turn". If an aircraft turns away from conflicting crossing traffic, every
additional second of turn sees the targets get closer until either they
merge or else they *finally* get to the point of course divergence. The
closer the targets are when an away turn is initiated, the less effective
an
"away" turn is.
I'd have probably requested a vector for traffic avoidance before the
traffic alert became necessary.
It's possible that the VFR target was indicating bad Mode C, he may have
been at a proper VFR cruising altitude and no factor for the IFR traffic at
7,000.
Old August 19th 03, 03:40 AM
Chip Jones
"Henry Bibb" wrote in message
I'd have *asked* for the vector by about the second call, if I couldn't
see
him.
I do that even in VFR with flight following.
Good point. It would have been easier to get the ball rolling in the right
direction if we had started earlier instead of waiting until an actual alert
phase.
Chip, ZTL
Old August 19th 03, 03:44 AM
Capt. Doug
Chip Jones wrote in message The response I get is "Baron 123 is IMC, no
contact."
Howdy!
While your scenario may be right on the money, let me point out that some
pilots will claim to be IMC even when there isn't a cloud in the sky. Their
reasoning is that by doing this, it keep the onus of seperation on the
controller. We both know this isn't quite how it works, but then again, a
chimpanzee flew Mercury 7.
D.
Old August 19th 03, 03:48 AM
Teacherjh
.... and the N number of that rogue traffic - it wasn't N2504R perchance, was
it?
Jose
Chip Jones
"Bob Gardner" wrote in message
news:MCe0b.184104$o%2.89767@sccrnsc02...
This was drilled into us for shiphandling at sea...turn into the
conflicting
traffic.
We drill this concept into ATC developmentals too. Same principle.
Sad thing is that if you had yelled at the Baron "Negative, turn
right immediately," the situation would have gotten worse, not better.
I thought so too
I hope you tracked the intruder to his destination.
No I didn't. My supervisor and I has a very short discussion about doing so
and then decided we could prove nothing. Could have been bad mode C, no way
to prove he was not VMC, the baron never saw him etc etc.
Chip, ZTL
Old August 19th 03, 04:11 AM
Chip Jones
"Stan Gosnell" wrote in message
long story snipped...
I think I would have turned in the direction you gave, since I couldn't
see
the traffic & presumably you could, at least on radar. You have a much
bigger picture than I do. Either he misunderstood you or he's a lot more
arrogant than I like to think I am. If he knows he's faster than the
converging traffic, a turn away could work, but how could he know that?
OTOH, if you really, really want him to turn to a heading, give it as an
instruction, not a suggestion.
The only problem about issuing the 180 heading as an instruction instead of
a suggestion is that I do not have separation responsibility between an IFR
and a VFR in this class of airspace. Because of that, I have to follow the
7110.65's provisions regarding safety alerts and traffic alerts, and the
7110.65 requires me to make a suggestion instead of taking control with an
instruction in this case. In fact, the 7110.65 even instructs me to use the
phraseolgy "immediately" if I offer a suggested course of action. Hence, if
your best course of action was to hold your present heading, and I suggested
this to you, I would actually have to key up and say something as ridiculous
as "N123, traffic alert [insert appropriate information here], suggest you
fly your present heading immediately for traffic!" Silly, ain't it?
The logic is that during an alert, the FAA doesn't want ATC issuing
*instructions* to a controlled aircraft that might cause it to collide with
an uncontrolled aircraft. Say I instructed a 180 turn just as the unknown
VFR made a radical turn to the west to avoid ( know it's very very
unlikely). In such a collision, the ATC instruction would likely be
identified as the *cause* of the collision and as the controller I'd be hung
for not following the book. This was drilled into me a long long time ago
when as a young pup I assigned ATC vectors to a VFR aircraft in distress
(IFR pilot in VFR-only airplane stuck on top in winter clag looking for a
friendly airport). Eventually I vectored the pilot down into an airport
safely and then got reamed by facility management for not *suggesting* the
vectors instead of assigning them. My chewing for that event went something
like this- "Good job Chip. The pilot called to say thanks- he wants to buy
you a beer. HOWEVER, assign ATC headings contrary to the 7110 again, you
moron, and you will be decertified...you could have killed that guy."
Chip, ZTL
Old August 19th 03, 04:39 AM
Chip Jones
"Ben Jackson" wrote in message
news:EQf0b.149627$Oz4.41062@rwcrnsc54...
"Baron
right
First of all, I had about fifteen airplanes on frequency. Mentally I was
gearing up for the wad of Atlanta departures that were getting ready to
launch (indeed were beginning to check on freq) and how the weather was
going to impact the departure push. I also had other IFR irons in the fire.
For example, I had two IFR's inbound to JZP and I was blocking for an
approach at 47A (which conflicts with JZP). I was mentally trying to get a
plan working for sequence into JZP while I was making that final
position-relief traffic scan. To me, the VFR target represented a very low
priority traffic call at six miles and 400 feet, especially since I don't
have separation responsibility between IFR and VFR traffic in thsi airspace.
I *do* have an air safety obligation that trumps all of my separation
responsibilities, but at six miles, and even at four miles, I did not
recognize that this situation was going to deteriorate from a routine
traffic situation into an alert situation with co-altitude traffic.
I suppose he could have requested a vector at the first or second call. I
was waitng for him to spot the traffic because that's what happens between
VFR and IFR traffic in this airspace. See and avoid.
I didn't believe that the VFR was in the soup until he got co-altitude with
the IFR guy who had reported twice that he was IMC at 7000. I see an
unknown VFR target, I assume the pilot is complying with FAR's. In this
case, I can't prove that he wasn't.
I disagree with you here. I do not use the phraseology "immediately" unless
I am worried about an imminent collision. In 13 years of ATC, I have used
"immediately" probably less than twenty times. In order for the baron to
slip behind the VFR, he did not need to turn 90 degrees, he only needed to
turn 45 to 50 degrees right. I assumed that combining "immediately" with a
suggested 80 degree right turn, there was the highest probability of a
successful outcome for the Baron. In the event, the left turn of 20 or 30
degrees that the Baron pilot executed in the event was insufficient to keep
his target from merging with the intruder.
Chip, ZTL
Old August 19th 03, 04:59 AM
BTIZ
I've read all the other comments posted so far.. pretty much a 50/50 split
in options..
As an IFR pilot, my first reaction would be to take the ATC suggested turn
I'm IFR so the bozo must be too, but "Monday morning" says to initially turn
away from the traffic.. not towards, at the 2 O'clock and 2 mile call, based
on the turning radius of the Baron at 180knts TAS plus, the turn away would
give him a little more free distance before possible collision and more time
to loose a little altitude. And based on the Baron's speed being a tad
faster than the Cessna Spam Can variety aircraft, the extra speed may pull
you out in front.
Turning into the traffic (point your nose at his tail, you'll miss 'em
theory), based on the turning radius, may put the two together sooner,
allowing less time to apply an altitude change to the solution.
If you delay the turn to late, the turning radius will kill the plan.
BT (former ZBOS)
in
Atlanta.
had
do
we
changed the guard.
another
where
a
"Baron
right
Baron
closing
like
are
thanks
Anything
I
update,
[The
profile
IFR,
IMC Baron].
Sh*t"
be
his
When
an
"away" turn is.
Chip, ZTL
News==----
Newsgroups
Bush Pilots Fly-In. South Africa. Bush Air Home Built 0 May 25th 04 06:18 AM
Any Pitts S-1 pilots in this group? Kai Glaesner Aerobatics 4 April 12th 04 12:10 AM
Photographer seeking 2 pilots / warbirds for photo shoot Wings Of Fury Aerobatics 0 February 26th 04 05:59 PM
Pilot's Brains Develop Differently Badwater Bill Home Built 3 August 22nd 03 04:48 AM
