Corvair conversion engines
Old January 24th 06, 10:10 PM posted to rec.aviation.homebuilt
Default Corvair conversion engines - cracked crank link
Rich S. wrote:
"Peter Dohm" wrote in message
Yes. I know that they do, and new design engines are notorious; as are
design improvements, changes of supplier, etc. And they include plenty of
reasons for loss of power not caused by the crankshaft!
However, my concerns include, reliability, maintainability, and eventual
replacement; and I think you understand my point.
At this point, the Jabiru 3300 is the only engine that really looks to me
like a promising replacement; and I really don't know its service record.
However, albeit at a higher dollar price, its features seem to preserve:
1)
similar or lighter weight, 2) similar or higher power, 3) six cylinder
smoothness, 4) reasonably slow idle, and 5) similar dimmensions.
Additional
benefits are designed in dual ignition and an updraft intake system,
similar
to Lycoming and Continental, which should be more resistant to ice.
Peter..........
Since you answered seriously, I will too. I can agree on the higher price
and on #1-3 and #5. I don't understand #4 - do Corvairs idle unreasonably
high? The dual ignition is good if the Jabiru 3300 truly has two stand-alone
systems. The intake direction is irrelevant if the Corvair is fuel-injected
or has a heated intake manifold. Updraft carbs are a lot better at
preventing fire as well. The small Continentals will ice up if you look at
them cross-eyed even with updraft intake.
Rich S.
The Lycoming approach, with the intake manifolds passing through the oil
sump are less inclined to ice up. I'm sure they can be provoked, though.
As for the Corvair's idle? I plain dunno.
I have never seen a Corvair on an airplane - in person.
ANd that kinda is the point here.
The mounted pics I have seen are on a Pietenpol Air Camper, which needs
the weight on the nose. On most other planes that's considered a
Bad Thing (tm). On small short coupled airplanes, it might qualify as
a Very Bad Thing (tm), which is obviously much worse.
Now, I've only *seen* the Jabaru on a plane.
Haven't flown one myself.
But it does look like an engine of fine merit.
Light and simple are high on my short list.
Cost is there too, of course, but it has to take a place in line with
the rest of the conflicting requirements.
The Rotax 912 (which I have flown) is a really sweet set-up.
There is the extra complication (and weight) of the liquid cooled heads.
But it's probably not that big a deal on any two-seater.
From what I've heard, the Jabaru/912 power ratings remind me of the old
Continental A-65/Lycoming 145 days. Both were rated at 65 hp, but the
Continental horses seem a little longer legged.
I'd rank most VW power estimates as Shetland ponies...
I suspect that most people expect a VW to put out like a Rotax, but it
just doesn't work that way.
In the end the final choice will depend on the airframe and the mission.
On the Corvair question...
As I said earlier the Great Plains crank on my 2180 i.e. a way massive
hunk of pure confidence. Just the way an A-65 crank compares to other
small 4 banger non-flying counterparts.
So, why can't someone turn out a new Corvair crank - built to aircraft
service requirements?
The Corvair engine is a 4 bearing block, isn't it?
There is no reason that you _have_ to have a Corvair crank is there?
Richard
Rich,
Whatchit with that BWHAAAAAAaaaaa stuff.
Scared the stuffings outta me.
O thought Badwater was back and I was going to have to spell check my
posts...
  #52
Old January 24th 06, 10:35 PM posted to rec.aviation.homebuilt
"who cares?" wrote in message
news:54xBf.560$AV.519@trnddc07...
Why would an updraft intake system be more resistant to ice?
Heat rises, so I would expect a downdraft system, mounted above the engine
block, to be more resistant to icing.
"Typically" cooling air comes in above the engine, flows down between the
cylinders, then out the bottom. This makes it colder up top, and warmer
below. There are, of course, exceptions.
Geoffrey Thorpe
The Sea Hawk At WowWay D0t Com
  #53
Old January 25th 06, 02:08 AM posted to rec.aviation.homebuilt
Peter Dohm wrote:
The Corvairs have a very good idle. But the Rotax, which is one of the
possible replacements I would include on my list, seems to have a minimum
operating speed restriction. On a KR-2, which has no flaps, I suspect it
would result in very flat final approaches.
You are right about the small Contintals, time has gone by and I just
plain forgot.
The KR-2 built to plans do have flaps. The drawings are hanging on the wall
behind me;-)
John
wish I could unload it so I could get/build a SP elegible aircraft!
  #54
Old January 25th 06, 02:12 AM posted to rec.aviation.homebuilt
engine block, to be more resistant to icing.
This has been one of the most friendly informative threads yet on this
newsgroup, How refreshing!
John
  #55
Old January 25th 06, 03:02 AM posted to rec.aviation.homebuilt
On Wed, 18 Jan 2006 21:26:23 GMT, "Don Lewis n FTW"
See: http://www.flycorvair.com/crankissues.html
"Ron Webb" wrote in message ...
Do you have a link for the broken cranks? I cannot find anything about broken cranks on the "Corvair authority" site.
I did find the following statement:
"I have never seen a cracked head, cylinder, case, crank or rod in the hundreds of Corvair engines I have inspected. It is a very
strong engine."
The Corvair engine has been flying since the early 1960's. Seems odd that ANY flaw would only now be being discovered.
They are only recently flying at 115HP in 200MPH planes - which is a
totally new world. Previous engines were flying at 60HP and 90MPH
without any issues.
Everything seemed OK until yesterday when I read the most recent updates on their website. Seems that the "untreated" automotive
cranks have been cracking in a very short time. Nitriding seems like the only solution. But with standard cranks cracking at
under 100 hours, what would be the expected life of a nitrided crank. Twice as long, four times as long, eight times as long?
This would still fall short of the 1500 hour TBO stated by the Corvair Authority.
Does anyone have any first hand experience with Corvair conversion engines? Any info on their realistic life and reliability?
TIA,
CV
  #56
Old January 25th 06, 03:03 AM posted to rec.aviation.homebuilt
On Thu, 19 Jan 2006 15:35:13 -0500, "Morgans"
"Bret Ludwig" wrote in message
roups.com...
I just think hanging a prop on a crank directly is a non-starter in
the first place...especially on a crank and case not specifically
designed for this in the first palce. Maybe a good redrive and flywheel
would be a better way to go?
That is my opinion, also.
What isn't there can't break. That's my reson for a direct drive 'vair
insted of a geared Soob - same weight - same HP.
  #58
Old January 25th 06, 03:07 AM posted to rec.aviation.homebuilt
On Tue, 24 Jan 2006 16:22:45 -0500, "Peter Dohm"
"Rich S." wrote in message
news
---------much snipped-----------
These were also 40 year old cranks of unknown provenence, pulled out
of old car engines that may have been thrashed to within an inch of
their lives in previous "inCARnations"
This has been my area of concern as well. I would really find these
engines more attractive if I was confident that a complete new engine
could
be built.
New engines don't have crankshaft problems?
BWAHAHAHAHAHAHA!!!
Rich S.
However, albeit at a higher dollar price, its features seem to preserve: 1)
smoothness, 4) reasonably slow idle, and 5) similar dimmensions. Additional
benefits are designed in dual ignition and an updraft intake system, similar
Peter
By what reasoning? Virtually all carbureted aero engines are
sucseptible to carb ice - doesn't matter where the carb is.
  #59
Old January 25th 06, 03:10 AM posted to rec.aviation.homebuilt
On Tue, 24 Jan 2006 13:32:22 -0800, "Rich S."
1)
Additional
similar
Peter..........
Rich S.
And updraft carbs are NO LESS dangerous firewise. They can't leak on
the top of the hot engine (but a properly designed top carb can't
either) but they have over a yard of "wet" intake manifold - if or
when the (flooded) engine backfires when starting and the battery is
low, a bottom carb engine WILL BURN.
  #60
Old January 25th 06, 03:15 AM posted to rec.aviation.homebuilt
On Tue, 24 Jan 2006 22:10:02 GMT, Richard Lamb
1)
Additional
similar
Peter..........
Rich S.
Richard
Rich,
posts...
Got ten grand? You can have a "proper" crank made - or for 300 grand
you can have a hundred of them.
As for the idle, mine ticked over very nicely at 700 RPM with a 72
inch IVO Magnum - but the Magnum was too much prop and was only able
to spin about 2450 or so. It idles fine at 750 with a 3 bladr 68" Ivo
ultralight - which is not enough prop and can be spun over 3000 at
full pitch.
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Corvair Engine Conversion Breakin Success Dick Home Built 1 January 11th 04 02:06 PM
Corvair Conversion Gig Giacona Home Built 17 October 27th 03 09:43 PM
