DG-300 instrument panel
Old January 28th 06, 04:24 PM posted to rec.aviation.soaring
Default DG-300 instrument panel
I'm thinking of starting anew with the instrument panel in the 300.
The Terra 720 radio is out, and the L-NAV works, but it came with an
old Garmin 95 GPS, which looks more like a typewriter, and no logger.
I'm looking to do a Cambridge 302, with a good radio, and remove the
compass from atop the cowling, and put it into the panel. The panel I
have now is drilled with 4 80mm holes and one 57mm hole, with the other
space taken up by 3 fuses, and voltage indicator. I was hoping some
300 type people might be kind enough to send a few pics of updated
panels? thanks
Old January 28th 06, 06:05 PM posted to rec.aviation.soaring
panels? thanks
I think your question was about panel layout and not the actual construction
of a panel, but the following may help even if it is a bit of a thread fork.
If you have a modest collection of shop tools, you can make a very good
looking panel. Start with some 3/4" thick high density particle board or
plywood and, using the old panel for a guide, cut a template with the
layout you think you like. Very accurate and clean 80mm and 57 mm holes can
be cut in the wood template with large Forstner bits in a drill press. Hole
saws work too but the holes are not as neat as Forstner bits make.
Using this new template and a router with a carbide ball bearing guide bit,
cut a .1/8" thick plexiglass test panel. The clear plexi prototype lets you
mount all the new goodies in the glider and see any conflicts behind the
panel while validating the new layout.
Loop this process until you run out of patience or have the exact layout you
like. Then, use the final template and the router to cut the actual panel
out of your material of choice.
If this strikes you as way too much work, use a PC CAD program to lay out
the panel and e-mail a .DXF file to a laser cutting shop who will cut the
new panel for you. Some will even cut plexi test panels for you to play
with. Hint: to get the panel outline right, trace the old panel on a large
sheet of graph paper and then transfer the grid points to the CAD program.
If you choose aluminum for the actual panel, you can have that black
anodized for another $75.
Bill Daniels
Old January 28th 06, 07:27 PM posted to rec.aviation.soaring
The 300 (along with all single seat DGs) uses a molded fiberglass panel
which is also the primary structural element of the instrument pod. It
might be possible to fold up an aluminum sheet replacement, but that
probably can't be done right with home shop tools. It is likely cheaper
and easier to buy a new blank panel from AMS.
Back to the original topic: there are two standard layouts that people
have used, both have three 80mm instruments across the top. The early
choice (from the days when most instruments were 80mm) was two 57mm
holes in the second row (one of which is missing on the OPs glider) with
an 80mm hole centered below. Later on, most people put four 57mm holes
in two rows in the lower part of the panel. You can put an additional
57mm+ instrument in the pedestal that supports the instrument pod, this
is where the radio usually goes, along with fuses, power switches, etc.
It is pretty difficult to come up with workable alternative arrangements
(although you can obviously omit holes), as there are various clearance
issues with the pod cover. You may also run into troubles with long
57mm instruments in the lower part of the panel, I couldn't get a B50 to
fit properly down there, and (while I haven't tried it) to get a 302 to
fit you may need to take the cover off the serial cable connector. I've
seen some ugly looking mods to the cover to allow for alternative
arrangements and deeper instruments, don't go there if you don't have
to. If I can find a picture of my 303 panel (latter arrangement above,
with compass in panel), I'll post a link...
Marc
Old January 28th 06, 08:00 PM posted to rec.aviation.soaring
I've sent the original poster photos of my panel before and after
changes I had done.
Within reason it is possible to fiberglass patch existing holes and
redrill them. I'd go this route instead of trying to fabricate a new
panel. I had this done to my DG-303. As Marc says the tapered sides of
the instument panel shroud are a problem. In my case this prevented the
normal Becker transponders or radios being mounted in the lower panel
cutouts. (the radio normally goes in it's own curout below the main
panel). In my case both 57mm bottom holes in the panel were filled and
a new hole cut in the center of this filled area to accoodate a Becker
radio, a Becker transponder was installed where the radio normlly goes.
Of course you lose an instument position.
It is also possible to cut the instument shroud and make fabricate on a
"bubble" to accomodate the longer instuments but I didn't want to do
this. Becker also makes remote mount radios and transponders but they
are more expensive and you have to find somewere to install the remote
unit.
Darryl
Old January 28th 06, 08:01 PM posted to rec.aviation.soaring
Folks, please don't use aluminum panels. The edge of that
panel can act like a knife in an accident (and yes, this has
happened and lets skip the gory details). For this reason
I believe most manufacturers have gone to a glass panel
with a molded flange. Its easy to make one of these; you
can use the old one to make a mold if you don't want to
buy one from AMS.
Be safe out there,
Best Regards, Dave
Old January 28th 06, 09:38 PM posted to rec.aviation.soaring
You take a look at try http://emachineshop.com/, which provides an easy
to use CAD program that will provide immediate quotes from the drawing
you make. A large choice of materials and finishes is available,
including fiberglass sheet.
Eric Greenwell
Washington State
USA
Old January 28th 06, 09:53 PM posted to rec.aviation.soaring
Thanks Bill, I just happen to have some 1/8" plexiglass in my shop
from when I built my router table, so I have that tool too! I might
try and get hold of a carbon fiber blank and use that for a svelt
looking panel!
Old January 28th 06, 11:08 PM posted to rec.aviation.soaring
Gerard,
There are good resources within ASA that can offer some ideas and have
machine tools. For example, cut out the face of your existing panel,
leaving the perimeter flange and a small portion of the face intact.
Make a new face out out aluminum that is full size. Fasten the new face
to the old flange portion.
Tom
On Sat, 28 Jan 2006 12:53:36
looking panel!
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 03:41 AM
Instrument panel labelling options John Galban Home Built 12 November 18th 04 11:42 PM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 06:54 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
