Prop Balancing Question
Old January 30th 06, 04:32 AM posted to rec.aviation.owning
Default Prop Balancing Question
Past couple of flights, found a screw that was loose on the spinner and
actually lost one in flight. A&P replaced them, and said during preflight,
check them. If they work their way loose again, need to get the prop
balanced.
Logs show no maintenance on the prop, so I am sure it's well overdue as it
has 2400 hours on it.
Today's flight, lost a screw in flight, and talked with my A&P. He is
going to arrange for a person to come out and balance the prop tomorrow.
Question is, after the balancing is done, what should I look for (if
anything) other then unusual vibrations and the like?
Is this one of those types of repairs, where I should stay in the pattern,
or is it OK to go to the practice area?
Plane is a 1976 Beech Sundowner.
Allen
Why does a prop ice up so apparently readily? Mike Rapoport General Aviation 3 November 8th 05 03:52 PM
Why does a prop ice up so apparently readily? Mike Rapoport Piloting 2 November 8th 05 03:52 PM
Sensenich Wood Prop Question [email protected] Owning 3 April 4th 05 03:32 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 04:04 AM
Prop balancing and assorted observations - long Dave Hyde Home Built 10 June 27th 04 02:08 AM
