downloading a gps20 without a serial port
Old February 2nd 06, 03:11 AM posted to rec.aviation.soaring
Default downloading a gps20 without a serial port
I recently lost my laptop and the replacement has no serial port. I
purchased a USB - serial converter cable but Cambridge Aero Explorer
can't seem to connect to the GPS 20. Anybody have a work around for
this problem? Just want to download waypoints and upload flights.
Ted
Old February 2nd 06, 10:16 AM posted to rec.aviation.soaring
Some of the USB adapters work, some don't.
Otherwise there are network servers like the Moxa serial ports.
Check out the Moxa site:
USB to Serial
http://www.moxa.com/Zones/Serial_Com...rial/index.htm
Ethernet to Serial
http://www.moxa.com/Zones/Serial_To_Ethernet/index.htm
Ted
Old February 2nd 06, 12:47 PM posted to rec.aviation.soaring
Take a look at pfranc.com - I'm using one of their adapters on a laptop
with a busted serial port. So far it's done everything I've needed,
including iPAQ hotsync via a serial cradle.
I'm not connected with them - just a happy customer.
martin@ | Martin Gregorie
gregorie. |
org | Zappa fan & glider pilot
Old February 2nd 06, 11:04 AM posted to rec.aviation.soaring
what operating system are you running did you load the software that came
with the cable ?
"Ted" wrote in message
Ted
Old February 3rd 06, 12:48 AM posted to rec.aviation.soaring
Am running windows XP. Did load the software which came with it.
Old February 2nd 06, 02:51 PM posted to rec.aviation.soaring
This probably only applies to a small niche (and won't answer your question,
Ted), but I recently had to figure how to use a USB-to-Serial adapter in
order to connect a PowerBook (yes, that's a Macintosh) to an SN10B, and a
Volkslogger. I also use it to ActiveSync my PDA.
The hard part was getting the USB-to-Serial adapter to work with Virtual PC,
but I've broken the code on that.
If anybody is interested, let me know via the newsgroup.
For the record, I'm not interested in any Mac vs PC discussions, since I've
already made up my mind on that.
On 2/1/06 7:11 PM, in article
, "Ted"
Ted
Old February 2nd 06, 03:25 PM posted to rec.aviation.soaring
Disregard this if you find a ready solution...another
option might be by a cheap PDA and load it with some
freeware flight software, add the cable to connect
it to the GPS20...and you can us the PDA to transport
flights and databases back and forth and leave the
GPS20 in the cockpit hooked up.
Old February 3rd 06, 12:50 AM posted to rec.aviation.soaring
Actually I can do that for the GPS 20I have a 1550 with flash. However
my real problem is loading my Zander SR 940 which has only the serial
port for communication.
Old February 2nd 06, 05:49 PM posted to rec.aviation.soaring
Ted, if you provide some more information it would help in finding a
solution your problem.
First, what is the make and model of both the computer and the
USB-serial converter? Second, what operating system are you using (XP,
NT, 98, DOS)? Third, if Windows, have you tried the standard Windows
tricks of looking for hardware conflicts, changing the serial port the
USB-serial adapter is on, setting baud rates, etc.? Fourth, if Windows,
what are the values that have been set by the installer for com number,
bps, data bits, parity, stop and flow control? Fifth, have you tried
booting into a pure DOS environment and using Data-cam with a fully
qualified command line to specify file name and com port?
I'm using an IBM T42 notebook with an IO Gear USB-serial adapter, and
I've had zero problems talking to a Cambridge Model 10 under XP and 98
using SeeYou, Data-cam and Vali-cam. This setup also works well under
DOS using Data-cam and Vali-cam.
So, as you no doubt suspected, it can be done! Taking a wild guess, I
suspect that your problem lies in getting the com port of the
USB-serial adapter to be com 1 or com 2. Most of the time the installer
puts them way up high, and this can lead to trouble (depends upon the
BIOS and the OS).
-John
Old February 2nd 06, 08:34 PM posted to rec.aviation.soaring
Windows 98 is not USB compliant windows 98 Second Edition is !
Landing strip off of Port O Connor, TX? Ricky Summersett Piloting 2 January 24th 06 05:35 PM
missing serial port Fred Blair Soaring 9 November 3rd 04 05:24 PM
WinPilot ADV comm port setting Ted Wagner Soaring 1 December 29th 03 06:44 PM
D'Amato's Role Investigated in La Guardia Airport Deal Roy Smith General Aviation 0 December 25th 03 06:47 AM
Is a static port a precision thing? Larry Smith Home Built 8 August 12th 03 11:26 PM
