A thought came to me the other day...
Now, I have never seen a bi-wing glider, but was thinking, could a bi-wing glider of, say 15m wingspan, effectively have 30m performace? This is probably a stupid uneducated question, and I would imagine that it hasnt been done because it wouldnt work! But its certainly something I am interested in. Think of it...a bi-wing ETA giving a total of 60m performance! JR |
The main idea of long wings is to reduce the relative part of the wingtip
vortexes in the total amount of the drag. Having 4 vortexes instead of 2 certainly doesn't help. "Jono Richards" wrote in message ... A thought came to me the other day... Now, I have never seen a bi-wing glider, but was thinking, could a bi-wing glider of, say 15m wingspan, effectively have 30m performace? This is probably a stupid uneducated question, and I would imagine that it hasnt been done because it wouldnt work! But its certainly something I am interested in. Think of it...a bi-wing ETA giving a total of 60m performance! JR |
Ok, what if one of the wings is a canard? If the elevator pushes down to
support the nose, and a canard lifts, doesn't that make a canard more efficient? Al "Bert Willing" wrote in message ... The main idea of long wings is to reduce the relative part of the wingtip vortexes in the total amount of the drag. Having 4 vortexes instead of 2 certainly doesn't help. "Jono Richards" wrote in message ... A thought came to me the other day... Now, I have never seen a bi-wing glider, but was thinking, could a bi-wing glider of, say 15m wingspan, effectively have 30m performace? This is probably a stupid uneducated question, and I would imagine that it hasnt been done because it wouldnt work! But its certainly something I am interested in. Think of it...a bi-wing ETA giving a total of 60m performance! JR |
support the nose, and a canard lifts, doesn't that make a canard more efficient? No. Take a look at the success of Rutan's Solitaire. The disadvantages with a canard or a tandem wing plane is that it is hard to use flaps, and to keep the plane pitch stable you end up with a plane that won't develop the same maximum total lift coefficient as a "normal" plane because you can never use the aft wing to it's full potential. This means that you end up having a higher minimum speed for a given wing area or need more wing for a given minimum speed. What all this means is that the speed range for efficient operation will be less than that of a comparable "normal" plane. You can tune the plane to be efficient at one speed by matching the airfoils and relative areas and this is how some of the canard homebuilts manage to show such good cruise performance. But they all suffer from high landing speeds. About the only way I see to improve on the standard glider - might - be to develop a flying wing with some kind of weight shift to increase it's speed range. The canard/tandem wing planform does have some advantages for powered planes but even there I've decided that a negative stagger biplane with a conventional empenage (Durand Mk V is an example) is more efficient than a pure tandem wing or canard ..................... and why my Q-2 will fly with a V-tail and flaps if I ever decide to finish it. ======================= Just my opinion Leon McAtee |
Thanks, very informative. Al
wrote in message oups.com... Ok, what if one of the wings is a canard? If the elevator pushes down to support the nose, and a canard lifts, doesn't that make a canard more efficient? No. Take a look at the success of Rutan's Solitaire. The disadvantages with a canard or a tandem wing plane is that it is hard to use flaps, and to keep the plane pitch stable you end up with a plane that won't develop the same maximum total lift coefficient as a "normal" plane because you can never use the aft wing to it's full potential. This means that you end up having a higher minimum speed for a given wing area or need more wing for a given minimum speed. What all this means is that the speed range for efficient operation will be less than that of a comparable "normal" plane. You can tune the plane to be efficient at one speed by matching the airfoils and relative areas and this is how some of the canard homebuilts manage to show such good cruise performance. But they all suffer from high landing speeds. About the only way I see to improve on the standard glider - might - be to develop a flying wing with some kind of weight shift to increase it's speed range. The canard/tandem wing planform does have some advantages for powered planes but even there I've decided that a negative stagger biplane with a conventional empenage (Durand Mk V is an example) is more efficient than a pure tandem wing or canard ..................... and why my Q-2 will fly with a V-tail and flaps if I ever decide to finish it. ======================= Just my opinion Leon McAtee |
Jono Richards wrote:
A thought came to me the other day... Now, I have never seen a bi-wing glider, but was thinking, could a bi-wing glider of, say 15m wingspan, effectively have 30m performace? This is probably a stupid uneducated question, and I would imagine that it hasnt been done because it wouldnt work! But its certainly something I am interested in. Short answer: no. The F1H competition model glider class has a maximum total *projected* wing area limit, so some years back an ingenious chap built a bi-plane version with no stagger so the projected area was the same as for a monoplane but with halved wing loading. He omitted interplane struts to minimize drag, but the model flew better with one wing removed. The reason was that you get a lot of interference drag between the wings. His interplane spacing was about 1.5 wing chords. Theoretical calculations later showed that he should have used a spacing of at least 5 chords to avoid interference gap. A sailplane with a 0.7m average chord would need an interplane gap of 3.5m and you'd still have a lot of drag from interplane struts. You'd need step-ladders or a fork lift to rig it. However, it would win the Ugly Trophy hands down. -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
"I have never seen a bi-wing glider"
Orville and Wilbur used to fly them. Colin |
At 14:12 21 February 2006, Colin Lamb wrote:
'I have never seen a bi-wing glider' Orville and Wilbur used to fly them. Colin Colin, Good point hadnt thought of that! Were those not kites, rather than gliders? Or maybe I should read my history books again... Right so there is no benefit in havin two wings than one? even if staggered to reduce the interference from each? As regards to using a fork lift to rig, no i am sure it would be far from practical, but then again, what would some people do in the strive for performance...!? JR |
"Jono Richards" wrote in message ... At 14:12 21 February 2006, Colin Lamb wrote: 'I have never seen a bi-wing glider' Orville and Wilbur used to fly them. Colin Colin, Good point hadnt thought of that! Were those not kites, rather than gliders? Or maybe I should read my history books again... Right so there is no benefit in havin two wings than one? even if staggered to reduce the interference from each? As regards to using a fork lift to rig, no i am sure it would be far from practical, but then again, what would some people do in the strive for performance...!? JR You probably should go back and read your history again. The Wright's 1902 glider is probably the most important aircraft in the history of aviation. It's the aircraft all their patents were based on. Tim Ward |
Tim Ward wrote: You probably should go back and read your history again. The Wright's 1902 glider is probably the most important aircraft in the history of aviation. It's the aircraft all their patents were based on. Tim Ward Don't forget the Wright 1911 biplane glider. On 24 Oct 1911, Orville soared it for 9 minutes 45 seconds, a world record that stood for 10 years. http://worlddmc.ohiolink.edu/History...arch status=0 John |
| Thread Tools | |
| Display Modes | |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| 48.4 hours !? | [email protected] | Soaring | 49 | April 28th 05 01:12 AM |
| Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 06:07 PM |
| Unintentional fully-developed spins... | Marc Ramsey | Soaring | 62 | February 12th 04 06:52 PM |
| Latest Newsletter Pipistrel Motorgliders | Michael Coates | Soaring | 20 | September 19th 03 02:25 AM |
