Coming back from Mammoth this past Sunday and flying through a snow
cloud West of the Sierras, I had the Pitot freeze over. I realized it was frozen when I tried to correct for altitude gained in turbulence and the airspeed indication didn't increase even as I pushed the nose down and could hear the relative wind increase. Not a big problem -- I could see where I was going on the AI, and a minute or less after I turned Pitot heat on, ASI returned to normal. This did raise a question -- is there a good reason Pitot heat isn't on all the time? It doesn't seem to be a big power drain, and unlike carb heat does not to my knowledge affect performance. Is there a reason I shouldn't turn it on when I put transponder on ALT and turn it off when I shut down electrics before engine shutdown? Ari. -- Elections only count as free and trials as fair if you can lose money betting on the outcome. |
This did raise a question -- is there a good reason Pitot heat isn't on all the time? It doesn't seem to be a big power drain, and unlike I would think that leaving the pitot heat on all the time would be unecessary wear and tear. Turn it on before entering visible moisture.. or as soon as you can. Turn it off when not needed. |
"K. Ari Krupnikov" wrote in message
... This did raise a question -- is there a good reason Pitot heat isn't on all the time? It doesn't seem to be a big power drain, and unlike carb heat does not to my knowledge affect performance. Is there a reason I shouldn't turn it on when I put transponder on ALT and turn it off when I shut down electrics before engine shutdown? Only that having it on when you have no airspeed may overheat it and cause unnecessary wear and tear. I put it on as part of the line-up checks and switch it off as part of the after-landing checks. I think most airlines do the same -- just because the big boys do it doesn't mean we should automatically follow suit, but in this case, as you found, I figure that prevention is better than cure. Weren't some of the Piper Malibu accidents attributed to loss of control after the pilot forgot the pitot heat? Finally, the pitot heat can make a difference to the compass. At least in my part of the world, the compass is swung with the pitot heat on. Julian Scarfe |
Leave it on all the time. Every checklist for a turbine airplane that I
have seen says to turn it on. All airlines leave it on all the time. Since the heat is just a resistance element with no moving parts, I doubt that it will "wear out faster" as others have suggested. Mine have 4600hrs on them and presumably they have been on all that time. Mike MU-2 "K. Ari Krupnikov" wrote in message ... Coming back from Mammoth this past Sunday and flying through a snow cloud West of the Sierras, I had the Pitot freeze over. I realized it was frozen when I tried to correct for altitude gained in turbulence and the airspeed indication didn't increase even as I pushed the nose down and could hear the relative wind increase. Not a big problem -- I could see where I was going on the AI, and a minute or less after I turned Pitot heat on, ASI returned to normal. This did raise a question -- is there a good reason Pitot heat isn't on all the time? It doesn't seem to be a big power drain, and unlike carb heat does not to my knowledge affect performance. Is there a reason I shouldn't turn it on when I put transponder on ALT and turn it off when I shut down electrics before engine shutdown? Ari. -- Elections only count as free and trials as fair if you can lose money betting on the outcome. |
Pitot heat power in most airliners I know of is controlled by way of
the squat switch (landing gear) to prevent burnout on the ground. Javier "Mike Rapoport" wrote in message thlink.net... Leave it on all the time. Every checklist for a turbine airplane that I have seen says to turn it on. All airlines leave it on all the time. Since the heat is just a resistance element with no moving parts, I doubt that it will "wear out faster" as others have suggested. Mine have 4600hrs on them and presumably they have been on all that time. Mike MU-2 "K. Ari Krupnikov" wrote in message ... Coming back from Mammoth this past Sunday and flying through a snow cloud West of the Sierras, I had the Pitot freeze over. I realized it was frozen when I tried to correct for altitude gained in turbulence and the airspeed indication didn't increase even as I pushed the nose down and could hear the relative wind increase. Not a big problem -- I could see where I was going on the AI, and a minute or less after I turned Pitot heat on, ASI returned to normal. This did raise a question -- is there a good reason Pitot heat isn't on all the time? It doesn't seem to be a big power drain, and unlike carb heat does not to my knowledge affect performance. Is there a reason I shouldn't turn it on when I put transponder on ALT and turn it off when I shut down electrics before engine shutdown? Ari. -- Elections only count as free and trials as fair if you can lose money betting on the outcome. |
While it has no moving parts, they due "burn out" by overheating. Its a
cigarette lighter, the filiment can and does burn out, usually caused by overheating. Also, smaller GA singles will notice the current drain on the system (espicially if they have not beefed up the alternator and have a brand new radio stack with high powered radios, cd players, etc... ). I was actually working on a temperature switch setup, one that would allow you to turn the switch on all the time, yet would not actually power it if the temperature was above say 5C or so. This would significanly help with the burn out, but not the current draw issue. Scott "Mike Rapoport" wrote in message hlink.net... Leave it on all the time. Every checklist for a turbine airplane that I have seen says to turn it on. All airlines leave it on all the time. Since the heat is just a resistance element with no moving parts, I doubt that it will "wear out faster" as others have suggested. Mine have 4600hrs on them and presumably they have been on all that time. Mike MU-2 "K. Ari Krupnikov" wrote in message ... Coming back from Mammoth this past Sunday and flying through a snow cloud West of the Sierras, I had the Pitot freeze over. I realized it was frozen when I tried to correct for altitude gained in turbulence and the airspeed indication didn't increase even as I pushed the nose down and could hear the relative wind increase. Not a big problem -- I could see where I was going on the AI, and a minute or less after I turned Pitot heat on, ASI returned to normal. This did raise a question -- is there a good reason Pitot heat isn't on all the time? It doesn't seem to be a big power drain, and unlike carb heat does not to my knowledge affect performance. Is there a reason I shouldn't turn it on when I put transponder on ALT and turn it off when I shut down electrics before engine shutdown? Ari. -- Elections only count as free and trials as fair if you can lose money betting on the outcome. |
I was actually working on a temperature switch setup, one that would allow you to turn the switch on all the time, yet would not actually power it if the temperature was above say 5C or so. Something else to go wrong. Jose -- (for Email, make the obvious changes in my address) |
yes - you don't want to leave it turned on without adequate airflow to
dissipate the heat buildup. The things get hot enough to melt the 1/4" plastic tubing that connect most of them to the P/S system. I had a P/S failure just prior to rotation on an ITO in Seattle years ago because of a looong hold with the heat turned on. Luckily the student in the left seat had paid attention during training and aborted the takeoff when the airspeed went to zero. A perfect training lesson for the student and a lesson in reality for the instructor. Typically now we turn on the heat as we taxi into position and then turn it off during the taxi in to the ramp. Feel of the pitot tube some time after the heat has been on for a while -- but do so carefully because you can get burnt on some of them. -- Jim Carter Seen on a bumper sticker: If you can read this, thank a teacher If you can read this in English, thank a soldier. "K. Ari Krupnikov" wrote in message ... Coming back from Mammoth this past Sunday and flying through a snow cloud West of the Sierras, I had the Pitot freeze over. I realized it was frozen when I tried to correct for altitude gained in turbulence and the airspeed indication didn't increase even as I pushed the nose down and could hear the relative wind increase. Not a big problem -- I could see where I was going on the AI, and a minute or less after I turned Pitot heat on, ASI returned to normal. This did raise a question -- is there a good reason Pitot heat isn't on all the time? It doesn't seem to be a big power drain, and unlike carb heat does not to my knowledge affect performance. Is there a reason I shouldn't turn it on when I put transponder on ALT and turn it off when I shut down electrics before engine shutdown? Ari. -- Elections only count as free and trials as fair if you can lose money betting on the outcome. |
| Thread Tools | |
| Display Modes | |
| Pitot tube question | Doc Font | Home Built | 2 | January 24th 05 05:28 AM |
| Any metallurgist's on the group, I want to heat treat aluminum? | [email protected] | Home Built | 3 | December 11th 04 12:50 PM |
| Painting and air cooled motor? | CitizenX | Home Built | 5 | June 30th 04 01:47 PM |
| 28 volt pitot heat | B2431 | Home Built | 15 | April 17th 04 04:25 PM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
