Vectored past the localizer
Old December 24th 03, 09:19 PM
Steven P. McNicoll
"Ron Rosenfeld" wrote in message
Never mind, I just found 5-4-3b1b.
AIM 5-4-3.b.1.(b) states; "If approach course crossing is imminent and the
pilot has not been informed that the aircraft will be vectored across the
final approach course, the pilot should query the controller." It does not
say "the pilot is required to query the controller" or "the pilot must query
the controller". Even if it did, the AIM itself says it's nonregulatory.
Old December 24th 03, 10:59 PM
Mike Beede
In article , David Rind wrote:
I can recall someone on this group once suggesting that if
you're past the localizer and concerned that you may be getting
close to terrain, and the frequency is too busy to get a word
in, that hitting IDENT is likely to cause ATC to notice.
Well, if I'm past the localizer and concerned I may be getting close
to terrain, then I *will* be turning back to intercept, and the guy
sitting in the dark can straighten out any kinks in the traffic flow.
I'm assuming your definition of "concerned" means "I know there's
a mountain in front of me that's higher than I am."
Luckily, we have no actual terrain in Minnesota, though we do
have some radio towers that are pretty impressive near the ILS
14 into St. Paul. Even so, they're well below where you ought
to be. Out here I've tooled along for what seems like a long time
till the controller remembered us, but I've never gotten testy
enough to remind them of my existance. If I did it for a living
(or we were in bumpier country) I might feel differently....
Hope everyone--pilots, controllers, and others on the group--all
have a nice Christmas.
Mike Beede
Old December 25th 03, 09:32 PM
Newps
This seems like a bit of an aggressive solution, but I'd guess the
controllers would prefer it to someone breaking off from their
assigned heading or altitude because of worries about terrain
avoidance. Could any of the controllers comment on this?
Not aggressive at all and a good idea.
Old December 26th 03, 12:50 PM
NO, it is not a good idea. Read the AIM.
He says he was vectored to intercept the localizer. That means new
heading or not, he is to intercept the localizer. I don't see what
the problem is. If he doesn't intercept, he is not in compliance with
his clearance. Period. That's why he was told the purpose of the
vector.
If he weere given a vector and not told to intercept, then a question
might be in order as the aircraft aproaches the course as to whether
the controller wants him to intercept or pass thru (not unusual)
Old December 26th 03, 05:08 PM
Steven P. McNicoll
What's not a good idea? Identing when you can't get ATC's attention on a
busy frequency or breaking off from an assigned heading or altitude because
of worries about terrain avoidance?
He said; "Several times, while under IFR flight plan and radar services, I
have
been vectored to intercept the localizer and the controller was late in
turning
me into the localizer." He was being vectored to the localizer but not yet
assigned a heading to join it and instructed to intercept.
That means new
the problem is.
That was good advice you gave earlier; "Read the AIM". Here's what the AIM
says about this very situation:
AIM 5-4-3.b.1.(b):
After release to approach control, aircraft are vectored to the final
approach course (ILS, MLS, VOR, ADF, etc.). Radar vectors and altitude or
flight levels will be issued as required for spacing and separating
aircraft. THEREFORE, PILOTS MUST NOT DEVIATE FROM THE HEADINGS ISSUED BY
APPROACH CONTROL. Aircraft will normally be informed when it is necessary to
vector across the final approach course for spacing or other reasons. If
approach course crossing is imminent and the pilot has not been informed
that the aircraft will be vectored across the final approach course, the
Actually, in this case, he's not in compliance with an ATC instruction if he
does intercept.
That's why he was told the purpose of the vector.
Do you have a reference for that? I thought the primary reason for stating
the purpose of the vector, beyond the simple courtesy of keeping the pilot
informed, was for potential loss of radio communications.
Why would approaching the final approach course without being told to
intercept prompt a question if you'd already been told the vector would take
you through it?
Old December 26th 03, 09:39 PM
Snowbird
wrote in message . ..
You too. Start with 5-4-3b.1.(b)
I think you're missing a distinction between the stated reason
for vectors (ie "vectors for the ILS 15 Richmond") and an
ATC instruction to intercept the localizer (ie "fly heading 180,
intercept the localizer")
The situation being discussed here is the former: the pilot
is receiving radar vectors to the FAC, but has not yet been
cleared for the approach nor instructed to intercept the localizer.
So when he observes the needle come alive, what should he do?
The textbook answer is "maintain the heading of his last ATC
instruction and query ATC 'Cessna 12345 through the localizer' "
The common sense/real life answer is "maintain situational
awareness and turn as necessary if the heading will take you
into terrain or obstructions or through the FAC for a parallel
approach. OTHERWISE, maintain the last ATC assigned heading
and query ATC".
The controller is supposed to inform the pilot if will be
vectored through the FAC, but often this doesn't happen --
perhaps the controller believes it will not be necessary
but the necessity develops. However, that doesn't mean
it is "safer" for the pilot to second-guess the controller
and turn to intercept the localizer anyway -- unless he
has been specifically instructed to do so or cleared for
the approach.
I don't see what the problem is.
I hope the problem is clearer now.
vector.
Um, no. The pilot is told the purpose of the vector ("vectors
for the localizer") because it's a requirement of 7110.65 for
the controller to inform the pilot of the reason for radar
vectors.
Being informed of the purpose of the vector ("vectors for the
localizer") does NOT constitute an ATC clearance to intercept
the localizer ("fly heading 180 intercept the localizer"),
nor should the former be interpreted as the latter.
A pilot who turns to intercept the localizer instead of
flying his assigned ATC heading, simply because he was informed
of the purpose of his vectors, is NOT in compliance with
his clearance. He is violating FAR 91.123, unless a emergency
condition exists. I would consider being vectored into terrain
or towers or towards a parallel FAC in use to constitute an
emergency, JMO.
Hope this helps,
Sydney
Old December 29th 03, 09:21 PM
S Narayan
The KSNS (Salinas) ILS 31 approach could be a dicey place to get vectored
past the LOC depending on your airspeed and where you are getting vectored
to etc. I am sure there are approaches others out there. I have flown this
approach in VFR conditions much above the fog layer where I could see the
mountains well. It would be prudent to at least slow down in such instances
and try to raise ATC asap.
"David Rind" wrote in message
David Rind
  #29
Old December 30th 03, 07:05 PM
Mick Ruthven
That's one of the places that I just wouldn't fly through the localizer
toward the nearby mountains, period. I've done that approach in clear skies
also, and if I'm the safety pilot I have the PIC remove the foggles as we
near the localizer on a vector so the point is made.
"S Narayan" wrote in message
instances
Aeronautical Engineering Help needed Marc A. Lefebvre US-775 Home Built 94 January 11th 04 12:33 PM
ILS Critical Area signage: Localizer or Glideslope? Adam K. Instrument Flight Rules 4 October 30th 03 10:09 PM
Established on the approach - Checkride question endre Instrument Flight Rules 59 October 6th 03 04:36 PM
Localizer Back Course vs. ILS ilsub Instrument Flight Rules 8 August 25th 03 04:04 PM
