Quality helicopter sim?
Old April 8th 06, 12:43 PM posted to rec.aviation.simulators
Default Quality helicopter sim?
Can someone recommend a quality helicopter simulator?
(Yet affordable by an individual enthusiast/helicopter student)
Esp. I am looking for one with Schweitzer 300C/CB/CBi (Hughes 269C) model.
What do people think of the helicopter models in X-Plane and MS Flightsim?
Thanks.
Old April 9th 06, 07:54 AM posted to rec.aviation.simulators
I use both MSFS2004 and X-Plane 8 for helos, but MSFS is not adequate for
helo training. There used to be some helo combat sims but I've never tried
them.
MS Flightsim is eye-candy but melts quickly; it doesn't autorotate. X-Plane
autorotates quite accurately.
I have not made either sim demonstrate settling-with-power (ring-vortex
state).
Neither sim comes with an SGS-300 but users have made dozens of free
downloadable helos. X-Plane lets you make your own by modifying existing
models.
X-plane has external long-line loads you can practice with, but lacks an
inset view so you cannot fly and position your load at the same time.
MSFS has a more complex GPS, but X-plane's is adequate for VFR navigation.
Both sims can be used for IFR helo flight. X-plane's S-61 Sea King has an
autopilot which makes IFR approaches much easier.
Both sims come with a Bell 206 and a Robinson R-22. The MSFS R-22 is a
breeze to fly, NOT like the real thing. X-Plane's R-22 is realistically
dicy.
I like MSFS for recreation, but not when I am trying to improve skills.
Marc Williams
"AirDolphin" wrote in message
om...
Thanks.
Old April 13th 06, 02:25 AM posted to rec.aviation.simulators
Just posted this elsewhe
Autorotation can be simulated with a kludge. Don't kill the throttle.
Instead bring it to 0, then back up to between 10 and 20 and "pretend"
you've just switched the engine off.
http://www.hovercontrol.com/artman/p...ticle_18.shtml
Old September 10th 06, 01:23 AM posted to rec.aviation.simulators
CriticalMass
The OTHER Kevin in San Diego wrote:
the helicopters are way easier to fly than the real thing - especially the Robinsons. All
helicopters are turbine powered and the flight models are tweaked to "emulate" piston power.
Absolutely FALSE. If "real-world" helicopters "flew" anything like the
models in FS2004, there wouldn't BE any "real-world" helo pilots -
they'd all be dead by now.
MS FlightSimulator doesn't come close to simulating helicopters.
Old September 10th 06, 03:22 AM posted to rec.aviation.simulators
Heywood Jablowme
As a real-world multi-thousand hour helo pilot, I can confirm what
Critical mass says. M$2K4 flies nothing like a real helicopter. The
models are awful.
The closest thing to reality can be achieved with Janes Longbow2 on
full realism. It's a PITA to get it to run on a WinXP box, but with
tweaking it works great.
(o o)
oOOo-(_)-oOOo
___|___|___|___|___|
Kilroy was here, and he hates spammers...
Tinasj
The Anti-Spam Jihad LIVES !!!
Lumber Cartel Member #857 [TINLC]
Old September 10th 06, 09:57 AM posted to rec.aviation.simulators
Garrot[_1_]
models are awful.
Have you ever flown Search&Rescue: Coastal Heroes? Some people say it is
somewhat realistic so am interested in your opinion. There is a demo if
you want to check it out.
http://www.3dgamers.com/games/searchrescue4/
http://pc.iavgames.com/searchandrescue4/
Old September 12th 06, 02:04 PM posted to rec.aviation.simulators
CriticalMass
Isn't that what I had implied? While not a mutli-thousand hour helo
pilot like heywood, I am a commercially rated heli pilot myself...
Not the way I read your post. I, and numerous others, have repeatedly
maintained they don't model real helos due to the nasty roll tendency
built into the flight models that essentially make them unflyable at
very low airspeeds. They're unrealistically HARDER to fly than the real
thing, not easier, as you said.
Old September 12th 06, 05:58 PM posted to rec.aviation.simulators
Garrot[_1_]
Someone here try SAR4 that I posted about in my other post. I've flown
LB2 many times and SAR4 feels similar in flight model.
Old September 14th 06, 12:41 PM posted to rec.aviation.simulators
CriticalMass
Perhaps it's the flight controls I'm using.. I've got a full
collective/cyclic/pedal setup (Home built) using Epic hardware and
some Epic code/FSUIPC to "fake" some of the aerodynamics so I don't
see the roll tendencies. Is this roll tendency present in 2002 and
2004? (I only have 2002)
Interesting. You may be on to something. I honestly can't remember far
enough back to recall how FS02 was. I was referring to FS04, and it's
definitely there. It's widely known and is a recognized and reported
defect in the helo flight models. I've always been amazed that MS never
bothered to patch it. This is a major contrast to the light single
flight models in FS04, which are passably good, IMO. I'm FAA-rated for
those, but not helos.
I've never tried it with the kind of controls you have. I've always
just used the best consumer joysticks I could find, force feedback ones
from CH or MS.
Attempting to lift off and hover IGE with the Bell, or any of the other
ones, is pretty nearly impossible; the aircraft is immediately totally
unstable, no matter how carefully you handle the stick, and there's a
point in these uncommanded rolling tendencies where recovery is pretty
much impossible, no matter how much control input is given. Same thing
happens at any airspeed below about 40 kts, IIRC, and slowing to hover
and land is the same deal. Pretty dicey.
You should pick up a copy of FS04 and try it with your setup - I think
the price is only $20-$30 now, can't remember what it was when I was at
CompUSA last.
Old September 14th 06, 02:00 PM posted to rec.aviation.simulators
CriticalMass
I d/l the demo and tried it. Didn't get far with it because it
apparently won't recognize any more than mouse, keyboard and joystick x
and y (roll and pitch). It doesn't see my rudder pedals, and I can't be
bothered to fly with a mouse or keyboard. That's certainly not
"realism", IMO. Not actually sure about the quality of the flight
model. I didn't get that far.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Idiot NBC "Terrorists" arrested at Helicopter Operation Vaughn Rotorcraft 2 August 16th 04 09:31 PM
Musings of a Commercial Helicopter Pilot Badwater Bill Home Built 6 February 27th 04 09:11 AM
Musings of a Commercial Helicopter Pilot Badwater Bill Rotorcraft 0 February 25th 04 06:39 PM
