Shine it, with a protective polished coating inherent in the product. Simpler than paint. To make paint adhere to aluminum requires a lot of preparation; polishing does not take so much work. You can hire unskilled labor to do the polishing, Senor. For a shiny unpainted surface and to remove oxidation consider this - Nuvite , from Nuvitechemical.com The Nuvite metal polish line of products is very good. See http://www.nuvitechemical.com/Products.asp?ProductID=1 It is a progressively graded abrasive compound and polish system applied with electric orbital rotary buffer. Kind regards. Dancing on clouds, Keep it up! Jim Culp USA GatorCity FL |
| Thread Tools | |
| Display Modes | |
| Painting aluminum glider trailer | John Murphy | Soaring | 17 | April 25th 06 11:44 PM |
| Pannting aluminum glider trailer | Jim Culp | Soaring | 0 | April 20th 06 03:12 PM |
| Question about Alodine 1201 | Andrew Sarangan | Home Built | 20 | April 11th 06 02:31 PM |
| Glider and Trailer Transport | Paul | Soaring | 5 | March 12th 06 06:58 PM |
| Bad publicity | David Starer | Soaring | 18 | March 8th 04 04:57 PM |
