Good AI backup, wish me luck
Old February 21st 04, 04:08 PM
Robert M. Gary
(Doug) wrote in message . com...
There are some non-TSO's EFIS systems around for under $2000! I saw
one at Oshkosh and was impressed! No moving parts, fully electronic.
Check out
http://www.dynonavionics.com
You can also buy a solid stage gyro that feeds your IPAQ. If you use
AnywhereMap as your GPS already you can just switch modes. However,
having a dedicted instrument sounds like the best solution to me. I'm
probably going to postpone my traffic watch system in favor of the
electric AI.
Old February 22nd 04, 05:00 AM
Teacherjh
How is this fundamentally different than if one AI disagrees with the DG
and turn coordinator?
You don't know which to trust, and you are out of bullets. You have to figure
out which one is lying. Besides, you can bank while remaning straight, and
you can be level while turning.
With two AIs, you can go PP and use the TC and DG (and ball).
Jose
Old February 23rd 04, 02:26 PM
Dave Butler
Robert M. Gary wrote:
Dave Butler wrote in message ...
I now have the Aero-Advantage STCed dual-rotor vacuum pump and think it is
overall the best solution. It offers more redundancy and more reliable backup
for a reasonable price. http://www.aeroadvantage.com
Including installation it will be less than your electric AI, and a better
solution, IMO.
I'm not so worried about losing the vac. What I'm worried about is
lossing the AI.
BTW: What is the purpose of the dual rotor pump. When my pumps have
gone out its always been because a vain got stuck and sheared off the
pump shaft. My mechanic said that's how they usually fail. Wouldn't
that kill both rotors?
-Robert
I understand your skepticism, but AeroAdvantage claims that they have a
mechanical arrangement that allows each rotor to fail independently. Check the
web site for more details, but if my memory serves it amounts to providing weak
points (necking) in the shaft in such a way that the shaft for each rotor can
fail independently. I have had trouble visualizing what the mechanical
arrangement is and would like to take one apart or see an exploded drawing to
see how they do that. I can't explain exactly how it's done, but they convinced
me to my satisfaction that they had solved the problem.
Dave
Remove SHIRT to reply directly.
Old February 23rd 04, 02:31 PM
Dave Butler
After having both a vac pump failure and an AI failure (not on the
same flight ) I decided its really time for a backup.
I had a similar revelation recently, after a challenging IPC at night
and a quiet reflection on a AI that did fail one me, albeit on a nice
day. Did lot of soul searching and decided to postpone a GPS upgrade
in favor of some attitude information backup first.
Dave Butler wrote:
FWIW, I have an electric AI in my Mooney and I wouldn't do it again. It's
expensive, failure prone, and too far out of my scan to be useful as a backup.
Did you have a lot of problems with the electric AI ? I am also
considering one (the dual pumps sound promising, but still don't back
up the gyro...), so I am curious how they hold up (the RCA-26 series
or the non-TSO'd Falcon, the AIM / Midcontinet stuff is just too
expensive). I heard mixed reviews on the RC Allen, some people have
had them for years without any problems and some claim they they don't
hold up as well as quality vacuum gyros.
The electric gyro in my Mooney was installed before I bought into the
partnership, so I don't know all the details, but I think it's been in there
about 10 years or so, and has been overhauled twice. Each overhaul cost about
the same as the original purchase price.
Sorry, I don't know which brand it is. If I can find out, I'll post it.
The installation in my airplane is over on the copilot's side, so it's way out
of my scan and therefore pretty much worthless. I'd go partial panel with the
turn coordinator and mag compass before I'd try to use a gauge so far out of my
scan. If you install an electric, be sure to put it where you can see it.
Dave
Re Falcon, I strongly considered the possibility (337 or not), but
with a custom tilt they are over $1100 (Chief), not *that* cheap
considering a brand new RCA goes for $1650 at the discounters (like
Spruce), factory tilt included and less paperwork hassle. Still, $500
is money, so if they are OK, might be worth considering. There seems
to be very little info on them besides the manufacturer,
unfortunately....
Martin
Dave Butler, software engineer 919-392-4367
Old February 23rd 04, 02:36 PM
Dave Butler
Mark Astley wrote:
Robert,
There was a recent article in Aviation Consumer about this (not sure if you
subscribe):
http://www.aviationconsumer.com/arch...ty/5307-1.html
Among other things, they discuss: dual chamber vac with a backup gyro and
PDA-style all electronic backups. If memory serves, a dual chamber vac with
a backup gyro is not terribly expensive and probably wouldn't require fancy
paperwork. I think they quote a price in the ballpark of $2000 for that
solution. The PDA-style all electronic solution is a bit more pricey and
wouldn't be panel mount.
Aviation Consumer's original article on the subject, written by Coy Jacobs, was
pretty negative on the dual vacuum pump. In a later article, maybe the one
referenced above, they were more positive about it. I think I paid $745 for the
dual rotor pump on an "Oshkosh Special" price. AeroAdvantage says 4-8 hours to
install, mine took 6 hours on an M20J.
Dave
mark
om...
same flight ) I decided its really time for a backup. I always
consider my Mooney to be an "IFR anytime" type of plane, in that I
consider it a solid IFR platform. When the vac pump goes out alarms
starting sounding, my voice annunicator starting saying "check vac
pressure" and the needle goes to 0. It's pretty obvious. I do a
voluntary IPC every 6 months with a local DE and always do partial
panel approaches so I'm as comfortable as you can be with that. A
couple weeks ago I had my AI go out. WOW, that's another story!! The
thing slowly rolled 30 degrees off and REMAINED RESPONSIVE!! When I
banked, it banked, when I pitched, it piched. Figuring out that it was
dead could be hard and it would be easy to miss it. I decided I need a
back up and those vac backup systems are a waste of money(Precise
Flight, electric vac, etc). After getting it back from overhaul my
partner reported that it did it again! I called a couple gyro places
and they said the vac AIs don't last very long because they have a
stream of "dirty" air running through them. The electrics last much
longer. So I'm getting an electric AI installed as my backup. I
noticed that the non-TSO'd electric AIs are almost $1000 less than the
TSO'd ones. I asked my mechanics and the FSDO and they said I could
probably get a 337 approved by the FSDO for a non-TSO'd unit as long
as it wasn't in the "T" area of the panel. One FSDO guy said I might
need to label it "VFR only" and I'd have to promise not to do 135. In
either case I'll end up having an electric backup AI for under $1500.
That's less than the price of a backup electric vac pump installed
about about the same price to put a Precise Flight in a Mooney (with
California labor rates of $95/hr ) with twice the redundency.
-Robert
Old February 23rd 04, 03:07 PM
Dave Butler
it is overall the best solution. It offers more redundancy and more
reliable backup for a reasonable price. http://www.aeroadvantage.com
better solution, IMO.
lossing the AI.
-Robert
Check the web site for more details, but if my memory serves it amounts
to providing weak points (necking) in the shaft in such a way that the
shaft for each rotor can fail independently. I have had trouble
visualizing what the mechanical arrangement is and would like to take
one apart or see an exploded drawing to see how they do that. I can't
explain exactly how it's done, but they convinced me to my satisfaction
Following up my own posting: here's what it says in the FAQ at
http://www.aeroadvantage.com (to visualize, the pump is mounted so that the
drive shaft is pointing forward):
1.) How can the rear pumps chamber continue to operate after the forward pump
chamber has failed?
The Dual Rotor Vacuum Pump incorporates a shear coupling between the forward
rotor and the driveshaft. The forward rotor’s shear coupling can shear away from
the driveshaft without causing the driveshaft to fail. Similarly, the rear rotor
also incorporates a shear coupling. As an Additional safeguard, the shaft has a
necked down area between the two rotors. Either the rear rotor’s shear coupling
or the necked area in the driveshaft can shear away from the forward rotor
without effecting the forward rotors continued operation.
and also:
6.) When a vacuum pump fails it can contaminate the vacuum system how do you
prevent one vacuum pump chamber from contaminating the other in the event of a
failure?
The Dual Rotor Vacuum Pump incorporates an intake manifold with dual check
valves. When a rotor disconnects from the driveshaft the check valve for that
chamber closes, preventing contamination of the other pump that is still
operating. Also, since the pump's chambers share a common exhaust, the exhaust
from the operating pump helps contain the contamination to the failed chamber by
applying positive pressure to the failed chamber.
Dave
Old February 23rd 04, 08:03 PM
Dave Butler
It's expensive, failure prone, and too far out of my scan to be
useful as a backup.
there about 10 years or so, and has been overhauled twice. Each overhaul
cost about the same as the original purchase price.
Followup after talking to one of my partners: We're pretty sure it's an RC
Allen. It's been in a little longer than I thought, more like 12 years instead
of 10. It's been repaired twice in the 12 years. The first time was relatively
reasonable and cost a few hundred dollars. The second time was over a thousand
and was called an 'overhaul'. The overhaul was done by Kelly Instruments. My
partner's feeling is that the reliability and repair cost was no different from
any typical gyro. The net is that maybe it's not as bad as I thought.
way out of my scan and therefore pretty much worthless. I'd go partial
panel with the turn coordinator and mag compass before I'd try to use a
gauge so far out of my scan. If you install an electric, be sure to put
Dave
unfortunately....
Martin
Good plans-built Light Sport Aircraft Rob Schneider Home Built 15 August 19th 04 05:50 PM
Free Volksplane to good home, located in Chino Hills CA Bryan Zinn Home Built 3 July 18th 04 02:55 AM
Solid State Backup AI Dan Truesdell Instrument Flight Rules 20 January 15th 04 09:53 PM
Good Luck, Jim! Rich S. Home Built 203 November 4th 03 11:46 PM
bulding a kitplane maybe Van's RV9A --- a good idea ????? Flightdeck Home Built 10 September 9th 03 07:20 PM
