Hello Pilots,
Seeing the question about CAI 302 tones prompts an issue I have with my 302. I have a relatively new V2C. It has a 302 and an LX 16 electronic vario for back up. I am running both off the TE probe in the fin. I had the 302 response times for both audio and pointer set relatively fast as I had done with my previous system and running 0% electronic compensation. The 302 is bonkers in any turbulence or transitions. I have tried adding some electronic compensation w/o improvement. In order to tame it I had to slow both audio and pointer response times down further than I would like. So the questions: 1) TE off the fin probe or go with static and electronic compensation 2) Operate with TE off the probe and some added electronic compensation 3) If running off static should I run with more than 100% electronic compensation 4) Optimum response time settings 5) Is there a solution that provide a well compensated 302 that is fast AND reasonably stable Thanks for the insights. Bob Caldwell |
Bob:
That's puzzling. You should be running your 302 on the TE probe (no electronic compensation) and it should work great with lower response time (this is how I have mine set up), as long as you don't have it set below ~1.5 seconds. Remember, *some* degree of dampening is necessary, you don't want the "air truth" in real time ... in AZ that would break the needle off. ~ted V2C "2NO" |
Mine was erratic when compared to the Borgelt, even at the 2.3 second
setting. Marty Eiler at Caracole added a restrictor to the line leading from the "T" to the 302 and it's worked well ever since, smooth response and a good match to the B40.. I now leave the response on the 302 set to 1.5 sec.. Ray Warshaw |
At Marty's suggestion I did the same thing as Ray describes. It works
great. Try a Sheuemann restrictor on the TE line. Jim |
Where does on get a Sheuemann restrictor?
Thanks, Jerz |
Thanks, Jerz |
I tried to get some from Sage, no reply. Called Noelle at Williams Soaring, had them in a couple of days. Tim Mara may have them too. This post is not associated with any commercial venture. Jim |
| Thread Tools | |
| Display Modes | |
| Electronic versus Pneumatic compensation (conclusions) | [email protected] | Soaring | 0 | September 26th 05 06:02 PM |
| Electronic versus Pneumatic compensation (follow-up) | [email protected] | Soaring | 4 | September 20th 05 07:21 PM |
| Electronic versus Pneumatic compensation (follow-up) | [email protected] | Soaring | 2 | September 20th 05 07:04 AM |
| Vario flask insulation | Bill Daniels | Soaring | 37 | January 18th 04 01:49 PM |
