Does an IPC count as a BFR?
Old March 18th 04, 10:21 PM
Brad Z
Fo me, the airplane was much of the issue. My clubs complex single (Piper
Lance) was pretty solidly scheduled, and when it wasn't scheduled, it was
down for various maintenance issues. Add to that an engine that passed TBO
and my determination was that the risk of the airplane being unavailable
when the checkride was due became too great. The club has two 172's and a
182, so I knew I wouldn't have a problem showing up for the checkride with
an airplane. I'm considering adding my multi-engine airplane rating to my
instructor certificate next, and will finish up with single-engine,
preventing the need to bother with a complex single all together. In the
meantime, I'm instructing instrument students while I work on the rest of my
ratings.
As to the point of taking the CFI-I at the FSDO because it is the easiest,
keep in mind that you are still tested on all of the FOI material and must
plan and conduct a lesson, so its substantially more than a CFI-I add-on.
Maybe a better way to frame this is that it's a matter of dividing the
instructor checkrides into more manageable pieces.
Others have also suggested that starting as an instructor of pilots who
already know how to fly is somehow "easier", or a way to ease into flight
instruction. My experience has been that while this may or may not be true,
an instrument instructor spends a fair amount of time correcting bad habits
formed over the time since the student passed their private checkride (and
in some cases before). Nevertheless, even if I never instruct a primary
student, I will still get my airplane instructor ratings.
Brad Z.
"Michael" wrote in message
om...
Mark Kolber wrote
As to why, it's pretty hokey, but there's some theory going around
that the CFI-I is easier, so, if you have to have an inspector for the
first ride, it might as well be the easier one.
The real reason is a little different. For all practical purposes,
you can't rent a complex airplane that isn't decades old. Any
determined fed can ground an airplane that old, and that's normal
practice in many FSDO's. If you go for an initial CFI ride in many
cases you get three inspectors - one ops and two maintenance. The ops
inspector starts your oral, and the maintenance inspectors start going
over the airplane. Oral ends when they ground it, and you get a pink
slip and, if you have the temerity to question their determination
(airplane not airworthy because the placard is curled up/TSO tag on
seatbelt unreadable/repair or alteration logged in logbook is major,
not minor, and requires Form 337) or the inspector just doesn't like
you, you get written up for flying an unairworthy airplane as well. I
know people who have had this happen, and there's at least one CFI on
this newsgroup who has his own story of something very similar.
The CFII ride need not be in a complex airplane - and new full-IFR
C-172's are available for rent all over. It's very difficult to
ground a new airplane. Thus I recommend that anyone doing an initial
CFI go over to a place that rents new C-172's and do the CFII first.
I did my initial CFI in a glider for the same reason - a new glider
was locally available for rent, and there was no way to flunk it
because it was new and completely unmodified - everything was just the
way it came from the factory.
Michael
  #32
Old March 18th 04, 11:09 PM
Michael
"Richard Kaplan" wrote
Related to this question of earning a CFII but not a CFI, I have not done
what follows and I am not sure the regs make sense in this area, but from a
strictly legal perspective I believe I can give an instrument proficiency
check in a multi-engine airplane even though I am not a multi-engine pilot.
My certificates are Commercial Pilot (ASEL + Instrument Airplane) and CFI
(Airplane Single Engine + Instrument Airplane).
I do not believe this is correct.
61.195 Flight instructor limitations and qualifications.
A person who holds a flight instructor certificate is subject to the
following
limitations:
(b) Aircraft ratings. A flight instructor may not conduct flight
training in any aircraft for which the flight instructor does not
hold:
(1) A pilot certificate and flight instructor certificate with the
applicable
category and class rating; and
For purposes of an instructor certificate, there are two classes
within the airplane category - ASE and AME. For purposes of a pilot
certificate, there are four classes within the airplane category -
ASEL, ASES, AMEL, and AMES. Thus, since you do not have a pilot
certificate with airplane category and multiengine land class (AMEL)
rating, I do not believe you could legally provide flight training in
a multiengine airplane.
Perhaps somewhat more practically speaking, I see no reason why I could not
sign off an IPC done with my simulator (Level 3 FTD) in twin-engine mode
since I do not need to be PIC to "create" IMC in the simulator and my CFI
instrument privileges refer to instrument airplane and not specifically to
single- or multi-engine airplanes.
You may be right, but this would be meaningless.
61.57(d)(1) The instrument proficiency check must be --
(i) In an aircraft that is appropriate to the aircraft category;
(ii) For other than a glider, in a flight simulator or flight training
device
that is representative of the aircraft category;
Note that there is no requirement for the simulator to be
representative of the class of aircraft, only the category. There is
no requirement for a multiengine pilot to take his IPC in a
multiengine airplane - any airplane will do. I see no reason why you
couldn't do this, but I also see no reason why anyone would ever want
to. It would have no regulatory purpose, and if you lack multinegine
experience it would have no practical purpose either.
Indeed, extending this further, my understanding is that a non-pilot could
pass the written exam to become an Instrument Ground Instructor and then
without ever setting foot in an airplane he could do an IPC in the simulator
(again a Level 3 FTD) and this non-pilot would have the authority to sign
off the pilot of a cabin-class twin as safe to fly in IMC.
Maybe, but I don't see that as obvious.
61.215 Ground instructor privileges.
(c) A person who holds an instrument ground instructor rating is
authorized to
provide:
(2) Ground training required for an instrument proficiency check;
61.57(d)(2) The instrument proficiency check must be given by --
(iv) An authorized instructor;
So the question would be - is the sim training ground or flight
training? If it's ground training, then an IGI would be an authorized
instructor and this would be legal. If it's flight training, then he
would not be authorized and it wouldn't be legal.
Michael
  #33
Old March 19th 04, 03:33 AM
Richard Kaplan
Richard Kaplan, CFII
www.flyimc.com
om...
done
from a
proficiency
pilot.
CFI
following
limitations:
hold:
applicable
not
CFI
to
device
could
simulator
sign
authorized to
provide:
Michael
  #34
Old March 19th 04, 03:46 AM
Doug Vetter
Doug wrote:
Using common sense, the CFI rating certainly should count. It is
pretty intense, requires a written test, ground school and a flight
test. Mine was exhaustive with 75 hours of ground school, 15 hours of
flight training and flying with 5 different instructors. Not all are
that exhaustive, but if someone tried to tell me it didn't qualify as
a BFR, I'd think that was pretty ridiculous. When you compare all that
to a two hour BFR, you see what I mean.
Just contacted AOPA and my FSDO about this. In short, any practical
exam that tests an applicant's piloting skills qualifies under the 61.56
BFR exemption. I was particularly concerned since my last qualifying
exam was almost two years ago, and if I'd been flying illegally all this
time.....well, I don't want to think about it.
An excerpt from AOPA's response:
'If the examiner also evaluates the applicant's piloting skills then
YES, ". . . a flight instructor practical test (for initial issuance or
a CFI rating addition or for a reinstatement) . . ." would meet the
requirements of a § 61.56 Flight Review.'
My FSDO's examiner did some research and called me back, only to confirm
this. His interpretation is slightly contradictory to what others have
pointed out here, in that he called the CFI certificate a "pilot
certificate" because (and I quote) "we don't give those to truck
drivers". However, he nevertheless agreed with your common-sense
approach. A BFR is a joke compared to the preparation and
demonstrations required for any CFI certificate / rating.
That said, if you choose to renew your CFI certificate without a
practical test, then you would need to accomplish a flight review before
the end of the 24th calendar month since your last practical exam.
Safe flying,
-Doug
Doug Vetter, CFIMEIA
http://www.dvcfi.com
  #35
Old March 19th 04, 03:49 AM
Richard Kaplan
om...:
hold1) A pilot certificate and flight instructor certificate with the
applicabl category and class rating; and
I agree that on first glance this would prohibit me from providing flight
instruction in a twin because both my pilot certificate and my instructor
certificate would need to contain both the Category Airplane and the Class
Single-Engine Land. Yet if this is true, then how can there exist flight
instructor certificates which only state "Instrument Airplane" because a
strict interpretation of the above would render such an instructor
certificate useless.
It would seem to me that by using the term "Instrument Airplane" on pilot
and instructor certificates the FAA has created a Class of airplane simply
called "Instrument."
What happens in the case of a CFII without a CFI. In that case doesn't the
instructor certificate read solely "Instrument Airplane"? In that case,
what is the category and class?
Meaningless but legal -- yes, I agree. Again, I am not proposing I or any
other single-engine CFI do this. It just seems to be a loophole in the
FARS, probably a dangerous loophole at that.
It is ground training but the ground training can serve as a legal IPC so it
does seem to be a loophole again as I understand it.
www.flyimc.com
  #36
Old March 19th 04, 03:18 PM
Michael
I concur that strict interpretation would render a CFI-IA with no
other ratings useless. In reality, we know the rule is not
interpreted that way. So once again the rules are not clear.
No, my point is that this loophole - a non-multiengine CFII giving
dual in a sim configured as a twin for purposes of an IPC - is not
dangerous at all. For purposes of legality, an IPC given in a single
also covers you in a twin. The only difference between the single and
twin IPC is the engine-out stuff; otherwise the twin flies just like a
complex single. So my point is that the loophole would allow you to
teach and evaluate the multiengine portion of the ICC, and you
probably could not do that competently, but it's not required anyway.
Now this is a dangerous loophole - all you need to do to be an IGI is
take two written multiple-guess tests. I would imagine this would be
well within the capability of most professionals with no flight
experience at all...
Michael
  #37
Old March 19th 04, 04:22 PM
Richard Kaplan
om...
OK, I agree there. Maybe this is actually helpful because if a twin-engine
pilot came to me to use my sim specifically so I could teach him how to use
a specific GPS or because he wanted to practice 0/0 landings then I could
put the sim in twin-engine mode to make him comfortable and still legally
log the instruction.
Yes, it is dangerous. I think in practice the way this is mostly used is to
allow rated pilots who are seeking the CFI rating to gain some experience
instructing in a flight training device. But the loophole does exist as you
note for someone who has never been inside an airplane in his life to sign
off an IPC.
www.flyimc.com
  #38
Old March 19th 04, 07:37 PM
Bill Zaleski
There is no loophole as far as an IGI is concerned with reference to
his signing off an IPC. As per the part 61 regs, he may give the
ground training required for an IPC, but there is no provision that
allows him to give an endorsement for the IPC itself. This has been
answered through the FAQ's before and has been gone over during every
examiner recurrent seminar I have attended. A CFII is given that
privilege, however if you look at the wording of privileges given to
ground instructors, only endorsements for knowledge tests and ground
training are allowed. They are not allowed to endorse for any recency
of experience issue. An IPC consists of both ground and flight
examination, as per the rating task table of the instrument PTS. A
person who has never been in an aircraft, even though he holds a
ground instructor certificate, can not give an IPC any more than he
can give a flight review. Just compare the privileges of a CFII vs. a
ground instructor, as per the Part 61 regs.
On Fri, 19 Mar 2004 16:22:25 GMT, "Richard Kaplan"
. com...
off an IPC.
www.flyimc.com
  #39
Old March 19th 04, 09:35 PM
Richard Kaplan
"Bill Zaleski" wrote in message
I agree for the most part with what you are saying. However, a flight
training device may be used as a substitute for the flight portion of the
IPC. The definition of flight time in 1.1 requires an aircraft for flight.
Therefore, it would seem that the training done in a flight training device
is legally ground training rather than flight training.
Let us take the other side of what you are saying and conclude that an IGI
can only perform the ground training elements of the PTS and not the flight
elements. Well there is no mechanism in Part 91 for an IPC to be done by 2
separate instructors; the only way 2 separate instructors can work on an IPC
is through a certified school such as a Part 142 school. So if an IGI
cannot sign off an IPC in a flight training device, then the IGI would have
no role at all for a Part 91 IPC.
www.flyimc.com
  #40
Old March 19th 04, 10:02 PM
Doug
One scenario you have not considered. A CFII with no Seaplane RATING
giving instrument instruction in a Seaplane (the student has a
Seaplane rating).
Legal? I think so. Advisable? I don't see a problem with it.
(Michael) wrote in message . com...
Michael
Where is approach good about multiple approaches and clearances in the air? Andrew Gideon Instrument Flight Rules 29 February 14th 04 02:51 AM
Zzzz Campbell's Second Lawsuit Against Sun-N-Fun Zzzz Ron Wanttaja Home Built 23 October 6th 03 02:09 PM
Aerial duel to the death - count to ten then Fire! pac plyer Home Built 18 August 12th 03 12:35 AM
