MoGas Tips, Tricks, Concerns, How To
Old May 13th 06, 05:18 PM posted to rec.aviation.owning
Default MoGas Tips, Tricks, Concerns, How To
If you'd just get the operation, you and Mary wouldn't have to USE
conundrums.
Golly, what a conundrum...
  #112
Old May 13th 06, 05:23 PM posted to rec.aviation.owning
Switching to courtroom mode
"So, Teledyne Director Of Engineering, would you please tell the court why
you recommended exceessive leaning and poor quality automobile fuel when we
have sworn testimony that it was this lethal combination that caused this
poor widow and her children to lose a husband and father?"
It sure as hell wasn't for engineering reasons that they made these
pronouncements.
mode off
Teledyne Continental and (I think) Lycoming have both gone on record
to say that mogas is damaging to their engines. They are certainly
multi-millon dollar aircraft engine companies and have have no
incentive to lie to you.
They are also multi-million dollar aircraft engine companies that
recommend against LOP operation. (Unless you are running a FADEC system).
Allen
  #114
Old May 13th 06, 10:55 PM posted to rec.aviation.owning
"RST Engineering" wrote in message .. .
Uhhh, no it didn't. It was allowed a MAXIMUM of 0.5 ml / gallon of TEL, but from the '50s on, the actual TEL count
was zero in 80.
Thanks Jim. That's the first I had heard that...but it was not declared as no-lead fuel, so the post asking for what was
the favorite unleaded fuel was a loaded question, eh?
  #115
Old May 14th 06, 05:33 PM posted to rec.aviation.owning
: Most of Florida is close to sea level.
I think the highest elevation in Florida is 120-ish feet? I think that's
what the sectional shows.
Aaron C.
  #116
Old May 14th 06, 05:41 PM posted to rec.aviation.owning
Jay Honeck wrote:
: A touch of Carb heat and the throttle cracked ever so slightly. It creates
: turbulence in the intake system that evens things out rather nicely.
: Care to expand on that?
Boy, I'm ever so worried to jump into a religious shouting match. But...
When I flew the Cherokee 180, carb'd O-360 or course, I could run LOP with
carb heat turned up. I could use the mix to slow the engine down until
it wasn't producing any useful power. It ran smoothly during this. Without
carb heat it would let you know if you went too far LOP.
I can't repeat these experiments; I'm sure the guy who owns my plane now
would be upset!
Aaron C.
  #117
Old May 14th 06, 11:09 PM posted to rec.aviation.owning
Here's another tip for carbureted engines only. When operating at full
throttle, it is often helpful to back off on the throttle until you see just
the tiniest drop in MP (if you have a MP gauge, otherwise look for the
slightest drop in RPM), and leave it there instead of fully open. That cocks
the throttle plate just enough to set up a slightly turbulent flow, and that
helps mix the fuel and air for better combustion. A touch of carburetor heat
may help, too.
Using our JPI EDM700 engine analyzer as our guide, we usually can get
all 6 cylinders within 70 degrees of one another using the "pull the
throttle back a hair" method at altitudes from 4500 to 8500 feet.
At full throttle, we're lucky to get them within 150 degrees of
matched.
Never tried the carb heat thing. We don't have a carb temperature
gauge.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #118
Old May 15th 06, 03:06 AM posted to rec.aviation.owning
"Aaron Coolidge" wrote in message
creates
Is it "religious", or religion [anecdote (my mechanc says...,the
manufacturers say without supporting evidence], blind faith [redundant]) vs
science (graphs, charts test stand data)?
  #119
Old May 15th 06, 08:56 PM posted to rec.aviation.owning
A couple of points:
1) My copy of ASTM spec D910 page 0539 states that the allowable TEL
content of 100LL avgas is 2 milliliters per gallon NOT 2 grams per
gallon. This means there will be over 1/3rd pound of lead in an 80
gallon tank of 100LL, plus about 1/5th pound of ethlylene dibromide
scavenging agent.
2) My muffler "failures" were from the internal flame tubes, which
must be present and in reasonable condition if they were originally
present when new, but are not required on later mufflers that did not
have the internal flame tubes. We did a proctoscope exam with a small
flashlight at annual to verify their condition. Our engine was run
about 50 deg rich of peak, or so we thought as we had only a single EGT
probe. There was little engine roughness though if the mixture was
leaned further. Manifold pressure was set to 21 inches for cruise,
less at higher altitudes.
I suspect many 172s were just run until the flame tubes were all gone
out the tailpipe.
  #120
Old May 15th 06, 10:49 PM posted to rec.aviation.owning
"nrp" wrote in message
A couple of points:
scavenging agent.
Aside from the curiousity of mixing gallons and metric measurments, 2
gr/gallon is 160 grams in an 80 gallon tank. 160/454=0.3524 lbs, so it's
virtually the same thing. SAW, 160 gr in a tank that holds 36,320 grams, 1/3
lb in a tank holding 480 lbs.
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Home Built 82 May 19th 05 02:49 PM
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Owning 87 May 19th 05 02:49 PM
Pocket PC Tips & Glide Navigator II Tips Paul Remde Soaring 0 December 14th 04 08:21 PM
Mogas and microbial growth Economic Girly Man Owning 6 November 13th 04 09:14 AM
"Dirty Tricks" and "Both Sides Do It" Leslie Swartz Military Aviation 19 March 29th 04 06:11 PM
