Spreadsheet for takeoff/landing distance calculation?
Old May 20th 06, 02:11 PM posted to rec.aviation.owning
Default Spreadsheet for takeoff/landing distance calculation?
Hi!
I fly a Piper Arrow 180 hp from 1968
Anyone have a spreadsheet or programme to calculate takeoff and landing
distance letting you input weights, pressure alt, temperature?
Frode
Old May 27th 06, 02:17 PM posted to rec.aviation.owning
Look at chapter 5 in the Pilots Operating Handbook (Performance).
That's the official publication that you must use to meet the
requirments for pre-flight action. Try showing a Designated Pilot
Examiner or FAA check Airmen a spreadsheet programe on the day of your
checkride to compute your take-off and time fuel and distance to climb,
He'll give you the same answer as I.
The POH is valuable, the problem is knowbody wants to use it anymore.
Chad
Old May 27th 06, 05:54 PM posted to rec.aviation.owning
Of course the POH is probably printed on paper and continual use tends
to wear it out. Taking the information from that page however and
building a spreadsheet (correctly) will yield the same information. Of
course the spreadsheet algorithms will have to be validated across the
range of acceptable input values by comparing it to the POH, but it is
still a one-time task.
I know this doesn't answer the original question, but the correct answer
isn't always USE the POH; it is REFER to the POH. You can do that by
having a validated spreadsheet.
-----Original Message-----
Posted At: Saturday, May 27, 2006 7:18 AM
Posted To: rec.aviation.owning
Conversation: Spreadsheet for takeoff/landing distance calculation?
Subject: Spreadsheet for takeoff/landing distance calculation?
climb,
Chad
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 01:18 PM
Declaring a free distance fight Basil Fairston Soaring 0 September 1st 03 09:27 AM
15 M Time Management Nationals Kilo Charlie Soaring 12 August 15th 03 04:09 AM
Best Software and Hardware for Turn Area Task? Snead1 Soaring 29 August 13th 03 05:12 PM
