structural adhesive
Old May 29th 06, 10:27 AM posted to rec.aviation.homebuilt
Default structural adhesive
Hi everybody!
I am looking for a structural adhesive tape but I prefer a glue
(because I do not want thickness) to bond aluminium (with passivation
or anodization treatment) and steel. The bond have to resist to sea
salt fog, and temperature between -100°C +100°C.
I will appreciate any suggestions!
Thank you
Old May 29th 06, 02:37 PM posted to rec.aviation.homebuilt
good answer!
I will calculate shear force!
my target is like I wrote, I would like to bond alluminium and metal
with high mechanical resistance join; the dimension of pieces a
-aluminium about 15 mm large per 2 mm hickness
-steel or iron 8mm large per 0,5 thickness
glued surface is about 8 mm per 15 mm
Peeling force should be greater than several kilos;
I have no space for mechanical join I would like to avoid rivets or
something similar.
Thank you!
Old May 29th 06, 02:53 PM posted to rec.aviation.homebuilt
Years ago, I was involved with an application "glueing" stainless
steel to 6061 and 6063 aluminum for structural applications. We used
a film adhesive, 3M's AF42. After curing, glueline was in the 0.001
to 0.002 inch range. The shear stresses are a problem over that
temperature range, unless you are doing one side of a thin assembly
and it may bend with temperature change (think bimetallic strip).
This stuff is GOOD, but the prep is significant.
On Mon, 29 May 2006 19:43:47 +0800, Stealth Pilot
On 29 May 2006 01:27:22 -0700, "circio0" wrote:
Hi everybody!
Thank you
I think you're asking the impossible.
the difference in thermal expansion between aluminium and steel at
those extremes of temperature would put incredible sheer forces across
a glue joint.
what is the actual application envisaged?
Stealth Pilot
Old May 29th 06, 06:45 PM posted to rec.aviation.homebuilt
circio0 wrote:
Hi everybody!
I suggest you change your design.
Unless you are going to attach very small pieces of one to
the other, so that differential thermal expansion is negligible,
no bonding method is going to work.
You could bolt or rivet the parts together and they'd
buckle or break.
FF
Old May 30th 06, 04:13 AM posted to rec.aviation.homebuilt
Sizes are probably small enough to not see major loads from
differential expansion.
Our qualification with AF42 was 50 lbs / inch. That will be about 0.8
kilograms / mm, probably enough in the 8mm width, almost surely enough
in the 15mm width.
something similar.
Thank you!
Old May 30th 06, 10:34 AM posted to rec.aviation.homebuilt
3M's AF42 seems strong bonding but it needs 60 min curing!!!! do you
know a faster method?
we are moving in the right way!
Thank you in advance
Adhesive removal [email protected] Soaring 8 May 2nd 06 03:37 PM
Plexiglas/canopy adhesive Michael Pilla Home Built 3 May 3rd 04 06:09 PM
structural stainless steel tank screws needed for PA-32-300 Dave Owning 11 October 1st 03 11:14 PM
Looking for sand paper rolls and adhesive Roger Halstead Home Built 9 August 8th 03 09:58 AM
Structural adhesive question BD5ER Home Built 1 August 3rd 03 07:03 AM
