When being vectored, and ATC says your 4 miles from X, I noticed
occasionally that they state the wrong X. They confuse the FAF with the IF. For this reason, I tell students to never rely on ATC's distance statements to make a descent. How often do others see this? |
On Wed, 28 Apr 2004 15:06:39 GMT, Greg Esres wrote:
When being vectored, and ATC says your 4 miles from X, I noticed occasionally that they state the wrong X. They confuse the FAF with the IF. For this reason, I tell students to never rely on ATC's distance statements to make a descent. How often do others see this? I guess I'm not understanding the circumstance clearly, that might lead someone to use that kind of information as an "OK to descend" point. If ATC is giving an approach clearance, and you are being radar vectored or on a random route, you should have received an "altitude to maintain until ...." If you are approaching an IAF that has a procedure turn, and you are NOT receiving radar vectors to final, I was taught that being on a published portion of the approach meant that I had to cross the IAF first. ????? Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
lead someone to use that kind of information as an "OK to descend" point. When being vectored outside the FAF, ATC will say, "You're 4 miles from x, turn left heading 210, maintain 2,500 until established, cleared for the approach". If you are between the IF and the FAF (as they said you were), then the published altitude is 2,000. If you are outside the IF, the published altitude remains 2,500. If ATC says you're 4 miles outside the FAF, but you're really 4 miles outside the IF, then if you descend based on that info, you've screwed up. |
On Wed, 28 Apr 2004 16:28:40 GMT, Greg Esres wrote:
I guess I'm not understanding the circumstance clearly, that might lead someone to use that kind of information as an "OK to descend" point. When being vectored outside the FAF, ATC will say, "You're 4 miles from x, turn left heading 210, maintain 2,500 until established, cleared for the approach". If you are between the IF and the FAF (as they said you were), then the published altitude is 2,000. If you are outside the IF, the published altitude remains 2,500. If ATC says you're 4 miles outside the FAF, but you're really 4 miles outside the IF, then if you descend based on that info, you've screwed up. OK, I understand now. I'm not an instructor, so I can only repeat back what I learned years ago. I think my approach would be to emphasize to the student the importance of situational awareness in all instances, and the attitude that he is the one flying and responsible. An intermediate segment is usually at least five miles long. So if all of a sudden ATC places the pilot 5+ miles from where the pilot thinks he is, that should trigger an immediate reaction to verify position. I think students (and advanced pilots) sometimes fall into the trap of allowing/expecting too much hand-holding from ATC. That may be more true in certain areas of the country than others. So I think it's extremely important to emphasize SA, responsibility, and the importance of being on a published segment of the approach (and knowing exactly where you are) before beginning a descent. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
importance of situational awareness in all instances, and the attitude that he is the one flying and responsible...I think students (and advanced pilots) sometimes fall into the trap of allowing/expecting too much hand-holding from ATC. I agree with all you said. I've been aware of this problem with ATC for a while and use it to illustrate to students how important it is for THEM to be in charge. I was just curious as to 1) how often others had noticed this, and 2) who was using this information in order to descend to intermediate altitudes. |
On Wed, 28 Apr 2004 19:49:50 GMT, Greg Esres wrote:
I think my approach would be to emphasize to the student the importance of situational awareness in all instances, and the attitude that he is the one flying and responsible...I think students (and advanced pilots) sometimes fall into the trap of allowing/expecting too much hand-holding from ATC. I agree with all you said. I've been aware of this problem with ATC for a while and use it to illustrate to students how important it is for THEM to be in charge. I was just curious as to 1) how often others had noticed this, and 2) who was using this information in order to descend to intermediate altitudes. I cannot recall ever hearing ATC give me a "distance from" an incorrect fix during an approach clearance. 90% of my flying is in the NE receiving radar services. Also, my recollection (and I could be wrong here), is that during the times I get a "maintain ....ft until established" clearance, it's for a precision approach. For non-precision approaches, I've received a "maintain ...ft until crossing xyz" Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Greg Esres wrote: When being vectored, and ATC says your 4 miles from X, I noticed occasionally that they state the wrong X. They confuse the FAF with the IF. For this reason, I tell students to never rely on ATC's distance statements to make a descent. How often do others see this? That's one of the many valuable purposes that a moving map of the MVA chart would serve. Of course, with GPS, the pilot can, and should be, the final authority on the distance to the final approach fix or point. |
authority on the distance to the final approach fix or point. Agreed. However, this "service" provided by ATC occured (I suppose) long before we had means to always verify the information. Seems a bit unsafe. |
Greg Esres wrote: Of course, with GPS, the pilot can, and should be, the final authority on the distance to the final approach fix or point. Agreed. However, this "service" provided by ATC occured (I suppose) long before we had means to always verify the information. Seems a bit unsafe. Go back to TWA 514 in 1974 and they didn't provide much information at all with vectors to approach courses. There have been more unsafe situations resulting from vectors over the years than anyone really knows. The NASA database is full of them, but the FAA ignores the issue. Some are controller errors, some are pilot errors, and some are a combination of the two. |
wrote in message ... Greg Esres wrote: Of course, with GPS, the pilot can, and should be, the final authority on the distance to the final approach fix or point. Agreed. However, this "service" provided by ATC occured (I suppose) long before we had means to always verify the information. Seems a bit unsafe. Go back to TWA 514 in 1974 and they didn't provide much information at all with vectors to approach courses. There have been more unsafe situations resulting from vectors over the years than anyone really knows. The NASA database is full of them, but the FAA ignores the issue. Some are controller errors, some are pilot errors, and some are a combination of the two. That is because FAA is afraid of opening ATC controllers up to civil liability. What FAA fails to comprehend is that "gross negligence", or "restraint of trade", is required to win a lawsuit in such a situation. Human error is not gross negligence and the issue could be safely addressed. |
| Thread Tools | |
| Display Modes | |
| Cessna 206 Pilot position....... | [email protected] | Home Built | 0 | January 28th 05 09:27 PM |
| Glad to hear the initial reports were wrong about accidents, as they usually are. | Tedstriker | Home Built | 0 | April 19th 04 03:52 AM |
| 3 blade prop position on 6cyl engine. | Paul Lee | Home Built | 3 | February 26th 04 01:47 AM |
| LED for position lights | Jerry Springer | Home Built | 2 | August 19th 03 02:43 AM |
| Wrong Brothers Air Force Party Invite | Jay Honeck | Home Built | 1 | July 20th 03 11:55 PM |
