STAR to nearby airport
Old May 13th 04, 05:39 AM
Steven P. McNicoll
"Teacherjh" wrote in message
If I'm picking up ice, the laws of physics will take over, and whether
or not they "have to have me" at 8000, I won't be there.
There's little other choice at that point. But there's sure to be
consequences.
  #32
Old May 13th 04, 02:20 PM
Teacherjh
what old clearance? You were told told to expect 8,000 on the ground.
Taking off is by definition acceptance of a clearance.
True. But I was expanding the point a bit. You're in the air, cleared at 5000
feet direct to Podunk. Freezing level is 6000 feet. Bigtown approach gives
you a new clearance - 8000 feet and ten miles over the ocean. You reject that
clearance, and still have your old clearance. Ultimately ATC needs to work
this out with you and with other aircraft. You are under no obligation to
accept the new clearance.
You're on the ground, and they offer you a clearance into the ice. You refuse,
you don't go anywhere. You're not in the air yet. You accept it hoping to
negotiate in the air. They won't play ball. You DON'T have an "old clearance"
you can fly - you already accepted the clearance into the ice. If ATC refuses
to play ball because they "need" you somewhere, the laws of physics eventually
take over.
Yes, there will be consequences, and they won't be pretty.
They were two different scenarios, but both involved choosing to refuse (or
not) a clearance.
Jose
  #33
Old May 13th 04, 03:05 PM
Newps
If ATC issues a clearance which will cause you to violate the FARs, are
you legally bound to accept it?
No.
If you are in the air, you still fly your old clearance while you reject
new one and you and ATC work it out. If you are on the ground however,
ATC has
no incentive to work it out with you. You end up staying on the ground.
You are the one with the incentive to wotk it out in the air. ATC will give
you what you want if they can. But they may not be able to.
  #34
Old May 13th 04, 10:48 PM
Teacherjh
ATC will give
That seems to be true in most places. It does not seem to be true in the
metropolitan NY area, and this is confirmed by my inquiries during a safety
seminar. They said flat out that you will get 7000 via Pennsylvania no matter
what.
Jose
SWRFI update... Moving again (argghh!!)... Dave S Home Built 14 October 15th 04 03:34 AM
Please help -- It's down to the wire Jay Honeck Home Built 12 July 14th 04 06:05 PM
The battle for Arlington Airport begins? Paul Adriance Home Built 45 March 30th 04 11:41 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 04:02 PM
Requirement to fly departure procedures [email protected] Instrument Flight Rules 77 October 15th 03 06:39 PM
