Wing Extensions
Old July 22nd 03, 10:19 PM
Roger Halstead
On Sun, 20 Jul 2003 14:43:58 GMT, Dave Hyde wrote:
Roger Halstead wrote:
I guess you'd need some sort of plastic overlay for the airspeed
indicator to remind you of the new critial speeds.
They don't change all that much. You leave them set for the shorter
wing. ...
I think someone else said this too, and I find it confusing. If they
don't change that much, why have the extensions? Just for more fuel?
They can be used for additional fuel and they create a higher aspect
ratio for greater speed at altitude than the short wing.. They also
offer a bit more climb, and a bit slower landing.
OTOH although the landing is slower, fowler flaps and the extended
wing only lower the landing speed a few MPH
The airpseed indicator could certainly be marked that way
and inspectors may approve it, but it seems like the long-wing version
would be more critical for safety numbers. Vne would likely be lower
It's not. That depends more on other factors
for the long wing(*), and maneuvering speed will be lower as well,
It is by a little
assuming the extensions add any lift at all.
They do.
Stall speed for *both* wings is important.
Stall with the longer wing is only a couple MPH slower.
(*) Assuming it's flutter that sets Vne, which is a
big assumption.
Kinda, sorta...flutter is one. Various portions of the structure are
another. As
Roger Halstead (K8RI EN73 & ARRL Life Member)
www.rogerhalstead.com
N833R World's oldest Debonair? (S# CD-2)
Dave 'corner speed' Hyde
Old July 25th 03, 05:14 AM
Grieg Pedersen, Information Systems Engineer
Funny you should bring this up. I've been considering a series of very
narrow (high aspect) winglets which would pivot at their roots and be
attached to the end of the wing. These could be arranged to work
together as a very high lift arrangement and be foldable on-the-fly. A
lot like the wingtip feathers of large raptors. Aft winglets might be
shorter than fwd ones, and each "feather" might be only 2-3" in chord.
Jay wrote:
Seems like it might be useful to have removable wing extensions for an
experimental. There are times when you want a fast airplane for cross
country and you can stand a long runway for the high TO/landing speeds
and then there are other times you want the low speed handling for
short field, etc. Flaps do this to some degree depending on how
exotic you want to get and have the advantage of being adjustable in
flight but the wing extensions would appear to extend the flight
envelope (on separate flights) beyond what can be done with typical
flap configurations.
A solid composite structure, perhaps 2 feet on each side that plugs
into the main spar(s) would do nicely to allow you to have both a high
speed clipped wing plane (when removed) and a long wing high lift
plane, of course not at the same time. The further out you go on the
wing the less the loads are so these wouldn't have to be built up as
strong as other parts.
They could be made with no control surfaces or other moving parts.
You could even select a different airfoil for that section if you
wanted. No problem plugging composite extensions into an aluminum
main wing. Of course the main short wing would have to be built to
allow access to the main spar(s). A hollow rectangular cross section
spar could accept an insert to mate with removable extensions.
Anyone seen anything like this?
Old July 25th 03, 05:18 AM
assuming the extensions add any lift at all. Stall speed for *both*
wings is important.
Forget "stall speeds." A given airfoil stalls at a given AOA. Period.
Loading, airspeed, aspect ratio have nothing to do with it.
Get an AOA indicator and fly that.
Old July 25th 03, 07:46 AM
Bart D. Hull
Bob, Bob, Bob,
You can make a AOA indicator for $50 and a little bit of time to machine
a dual purpose pitot - AOA pylon for the end of your wing.
I do agree that many gauges on the dashes of many kitbuilts are
worth a great deal less than the asking price, but a stall warning
system is worth its weight in gold!!! Just ask the gentleman that
"made it" to Oshkosh in a Glasair got stuck behind a cub on final,
did "s" turns until he fell out of the sky 400 ft short of the runway.
DEAD.
Another Information System Engineer, but without a gold lined wallet.
Bart D. Hull
Tempe, Arizona
Check
http://www.inficad.com/~bdhull/engine.html for my Subaru Engine
Conversion
Check http://www.inficad.com/~bdhull/fuselage.html for Tango II I'm
building.
Barnyard BOb -- wrote:
"Grieg Pedersen, Information Systems Engineer"
wings is important.
A rather amusing, although assinine approach....
Killing a bug with an extravagant $ledge hammer.
Is this what pompous information system injun-eers
are good at?
Barnyard BOb -- limited resources
Old July 25th 03, 01:29 PM
Barnyard BOb --
Bob, Bob, Bob,
DEAD.
Bart D. Hull
Jezus...
Just admit you know not how to fly small GA aircraft.
You sound like one of the typical dumb**** cable infomercials.
Gimmee a break and quit insulting my meager intelligence.
Glasairs and Cubs will never mix and starring at a homebrew
AOA on a wingtip instead of where one is going while attempting
to navigate the world's busiest airport at rush hour is...
extremely poor form in my 50 year old book of competent piloting.
You can X, Y, Z or S 'til hell freezes over, but ....
Not even a $5000 AOA indicator can substitute for good judgment
and save your dumb ass when you should be on final at 100 mph
instead of attempting to match wits with a 40 mph Cub....
if what you say has even a grain of truth in it.
I've successfully flown thousands of hours on the ragged edge
of stall crop dusting and I attribute that more to being competent
at stall recognition than some $50 huckster claim of a life saving
device for dummies.
FWIW..
I've been hearing and reading about cheapy AOA indicators
for the better part of 50 years. If they were worth a hoot, you or
somebody would be selling them for $100 and getting rich....
or getting your ass sued into oblivion.
P.S.
Have you installed the $50 AOA on your, yet to fly, Tango?
BE HONEST or you will crash and burn behind a Piper Cub.
P.S.S.
What is it with you Information System Engineers that make
you brag about your credentials in a pilot oriented community?
From what I have seen in the last 24 hours....
It's hardly an asset when garbage in = garbage out.
Barnyard BOb - please don't 'ax' me to talk to dead men
Old July 25th 03, 06:51 PM
BRUCE FRANK
Since there seems to be a thought that we all need an AOA indicator, I have
missed something. Are there planes that give no indication of an impending
stall? Isn't a large part of flight training concentrated on recognizing
that impending stall? The people with whom I have flown who regularly fly
the ragged edge of the bottom end of the airspeed ignore the stall warning
horn and just fly the plane. That isn't flying by the seat of one's pants,
its understanding the what the normally present indicators are telling you.
I will have to agree that no one survives all those years crop dusting by
looking at some kind of gauge. It is flying skill and knowledge. On a much
smaller scale it's like getting to the point as a student when you realize
you are flying approach and discovering you're not having to watch the
airspeed indicator gauge...and you're squeaking it on.
Bruce A. Frank
"Barnyard BOb --" wrote in message
Bob, Bob, Bob,
DEAD.
Bart D. Hull
Jezus...
device for dummies.
FWIW..
P.S.
P.S.S.
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 10:20 PM
