C172N Flap indicator problem
Old July 2nd 06, 11:47 AM posted to rec.aviation.owning
onesto
Default C172N Flap indicator problem
My 172N has suddenly developed a problem where Flap actuation switch
does not work during 1st 10 degree position and requires lever to be
around 12 degree before flaps work. Flap indicator will not return to
zero and remains at above 10 degrees. Flaps travel to 40 degrees OK and
work well as long as actuating lever is used between say 12 and 40
degree positions. Can the flap position follower cable jam/fail?
Seems like something has slipped or stuck. thx, Arthur
Negative flaps for better low speed aileron control? [email protected] Soaring 41 August 25th 05 07:01 AM
Stuck cowl flap cable Jim Burns Owning 7 March 24th 05 03:07 PM
Flap Hinge Moment Calc Bo Home Built 2 February 2nd 05 11:26 AM
Flap Hinge Moment Calc Bo Home Built 0 February 2nd 05 07:01 AM
Flap angles DeltaDeltaDelta Piloting 34 May 18th 04 01:09 AM
